Commit 37f16a28 authored by Konrad Hinsen's avatar Konrad Hinsen
Liens vers gitlab pour replicable_article
parent 817940f9
......@@ -305,11 +305,11 @@ tar zcf replicable_article.tgz $FILE_LIST
#+RESULTS:
Download the following [[file:replicable_article.tgz][archive]] and uncompress it. The archive contains the compiled article, so you can start by looking at it.
Download the following [[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/raw/master/module2/ressources/replicable_article.tgz][archive]] and uncompress it. The archive contains the compiled article, so you can start by looking at it.
To rebuild the article, delete =article.pdf=, or rename it to something else. Otherwise the rebuild procedure will simply tell you that the article is already up to date. Then type =make= to build everything from scratch. Open the freshly built =article.pdf= to see if it looks OK.
If you get tired of always re-executing all the source code when exporting, look for the following line in [[file:replicable_article/article.org][article.org]]:
If you get tired of always re-executing all the source code when exporting, look for the following line in [[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.org][article.org]]:
#+BEGIN_EXAMPLE
# #+PROPERTY: header-args :eval never-export
#+END_EXAMPLE
Markdown is supported
0% or
You are about to add 0 people to the discussion. Proceed with caution.
Finish editing this message first!
Please register or to comment
