- [[#making-sure-jupyter-allows-you-to-use-r][Making sure Jupyter allows you to use R]]
- [[#latex-for-pdf-export][LaTeX for PDF export]]
- [[#additional-tips][Additional tips]]
- [[#interacting-with-gitlab-and-github][Interacting with GitLab and GitHub]]
* Jupyter tips and tricks
The following [[https://www.dataquest.io/blog/jupyter-notebook-tips-tricks-shortcuts/][webpage]] lists several Jupyter tricks (in particular, it
@@ -344,14 +345,17 @@ Here are a few extensions that can ease your life:
#+END_CENTER
NB: In the first edition of the MOOC some people had issues making
it work under Windows.
*** • Interacting with GitLab and GitHub
To ease your experience, we added pull/push buttons that allow
you to commit and sync with GitLab. This development was specific to
the MOOC but inspired from a previous [[https://github.com/Lab41/sunny-side-up][proof of concept]]. We have
recently discovered that someone else developed about at the same time
a [[https://github.com/sat28/githubcommit][rather generic version of this Jupyter plugin]]. Otherwise, remember
that it is very easy to insert a shell cell in Jupyter in which you
can easily issue git commands. This is how we work most of the time.
can easily issue git commands. This is how we work most of the time. If you choose this solution, *we strongly advise that you
follow [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/d132a854b0464ad29085cedaded23136][our tutorial on using git from RStudio]]* (/"RStudio et Gitlab"/
). Before proceeding, make sure you also have followed the
[[interaction-avec-gitlab-et-github][Interaction avec GitLab et GitHub]]
* Jupyter : Trucs et astuces
Cette [[https://www.dataquest.io/blog/jupyter-notebook-tips-tricks-shortcuts/][page web]] (en anglais) recense un certain nombre d'astuces
@@ -381,7 +382,7 @@ vie :
N.B. : Dans la première édition de ce MOOC, certains participants nous
ont rapporté avoir eu des difficultés à faire fonctionner cette
extension sous Windows.
*** • Interaction avec GitLab et GitHub
Pour rendre vous simplifier la vie, nous avons rajouté des boutons
=pull/push= dans Jupyter qui vous permettent de synchroniser vos
modifications avec GitLab. Ce développement spécifique pour ce MOOC
@@ -393,7 +394,10 @@ intéresse, c'est donc une piste intéressante à explorer. Sinon,
souvenez-vous qu'il est très simple d'insérer une cellule shell dans
Jupyter et vous pouvez facilement y insérer des commandes
Git. C'est la façon dont nous travaillons en pratique la majorité du
temps.
temps. Si vous optez pour cette solution, il vous faudra configurer Git sur votre
ordinateur. Pour ce faire, vous pouvez suivre la vidéo
[[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/7508aece244548349424dfd61ee3ba85][configurer Git pour Gitlab]] et le document
[[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/module2/ressources/gitlab_fr.org][Git et Gitlab]] correspondant.
Ceci étant dit, vous avez certainement remarqué que Jupyter conserve
une trace parfaite de l'ordre dans lequel les cellules ont été
