Commit 548469b4 authored by Arnaud Legrand's avatar Arnaud Legrand
Remove all html generated files (from the 1st edition) and automate org -> markdown generation
parent a5fc7359
ressources-md:
for i in module1/ressources module2/ressources module3/ressources \
module4/ressources; do \
make -C $$i; \
done
%.md: %.org
pandoc -f org -t markdown_github -o $@ $^
# %.html: %.org
# emacs -batch $^ --funcall org-html-export-to-html
# sed -i -e 's/<pre /<pre style="padding-left: 30px; background-color: #f6f8fa;" /g' \
# -e 's/<li>/<li style="margin-bottom:0;">/g' \
# -e 's/<ul>/<ul style="margin:0 0;">/g' $@
# mv $@ $@.bak
# html_png_inliner.pl < $@.bak | grep -A $(NLINES) -e '<body>' | grep -B $(NLINES) -e '<div id="postamble" class="status">' | grep -v -e '<body>' -e '<div id="postamble" class="status">' > $@
# rm $@.bak
clean:
rm -f *~
all: introduction_to_markdown.html
all: introduction_to_markdown.md
NLINES=10000000
%.html: %.org
mv $@ $@.bak
cat $@.bak | grep -A $(NLINES) -e '<body>' | grep -B $(NLINES) -e '<div id="postamble" class="status">' | grep -v -e '<body>' -e '<div id="postamble" class="status">' > $@
rm $@.bak
include ../../Makefile.ressources
This diff is collapsed.
all: gitlab.html emacs_orgmode.html jupyter.html rstudio.html maintaining_a_journal.html
all: emacs_orgmode.md jupyter.md maintaining_a_journal.md gitlab.md gitlab_fr.md rstudio.md rstudio_fr.md video_examples/README.md
NLINES=10000000
%.html: %.org
mv $@ $@.bak
rm $@.bak
clean:
rm -f *~
all:
all: resources_refs.html resources_environment.html exo1.html exo2.html exo3.html
all: resources_refs.md resources_environment.md resources_refs_fr.md resources_environment_fr.md # exo1.html exo2.html exo3.html
NLINES=10000000
%.html: %.org
mv $@ $@.bak
rm $@.bak
clean:
rm -f *~
#!/usr/bin/perl -w
use strict;
my($line);
while(defined($line=<STDIN>)) {
if($line =~ /^(.*)<img *src="([^"]*)"(.*)$/g) {
my($pre,$image,$post) = ($1,$2,$3);
$image =~ s|file://||;
# print "$image\n";
my $base64=`base64 -w 0 $image`;
my $format=$image;
$format =~ s/.*\.//g;
print $pre."<img src=\"data:image/$format;base64,".$base64.'"'.$post;
} else {
print $line;
......@@ -6,6 +6,19 @@
#+OPTIONS: num:nil toc:t
#+PROPERTY: header-args :eval never-export
* Table of Contents :TOC:
- [[#getting-information-about-your-git-repository][Getting information about your Git repository]]
- [[#getting-information-about-python3-libraries][Getting information about Python(3) libraries]]
- [[#getting-information-about-your-system][Getting information about your system]]
- [[#getting-the-list-of-installed-packages-and-their-version][Getting the list of installed packages and their version]]
- [[#how-to-list-imported-modules][How to list imported modules?]]
- [[#saving-and-restoring-an-environment-with-pip][Saving and restoring an environment with pip]]
- [[#installing-a-new-package-or-a-specific-version][Installing a new package or a specific version]]
- [[#getting-information-about-r-libraries][Getting information about R libraries]]
- [[#getting-the-list-imported-modules-and-their-version][Getting the list imported modules and their version]]
- [[#getting-the-list-of-installed-packages-and-their-version-1][Getting the list of installed packages and their version]]
- [[#installing-a-new-package-or-a-specific-version-1][Installing a new package or a specific version]]
* Getting information about your Git repository
When taking notes, it may be difficult to remember which version of
the code or of a file was used. This is what version control is useful
......@@ -6,10 +6,18 @@
* Table des matières
- Obtenir des informations sur votre dépôt Git
- Obtenir des informations sur les librairies Python 3
- Obtenir des informations sur les packages R
* Table des matières :TOC:
- [[#obtenir-des-informations-sur-votre-dépôt-git][Obtenir des informations sur votre dépôt Git]]
- [[#obtenir-des-informations-sur-les-librairies-python-3][Obtenir des informations sur les librairies Python 3]]
- [[#obtenir-des-informations-sur-votre-système][Obtenir des informations sur votre système]]
- [[#lister-les-packages-installés-et-leur-version][Lister les packages installés et leur version]]
- [[#lister-les-packages-importés-chargés-dans-une-session-python-et-leur-version][Lister les packages importés (chargés dans une session Python) et leur version]]
- [[#sauvegarder-et-restaurer-un-environnement-avec-pip][Sauvegarder et restaurer un environnement avec pip]]
- [[#installer-un-nouveau-package-ou-une-version-spécifique][Installer un nouveau package ou une version spécifique]]
- [[#obtenir-des-informations-sur-les-packages-r][Obtenir des informations sur les packages R]]
- [[#lister-les-packages-installés-et-leur-version-1][Lister les packages installés et leur version]]
- [[#lister-les-packages-importés-chargés-dans-une-session-r-et-leur-version][Lister les packages importés (chargés dans une session R) et leur version]]
- [[#installer-un-nouveau-package-ou-une-version-spécifique-1][Installer un nouveau package ou une version spécifique]]
* Obtenir des informations sur votre dépôt Git
Lorsqu'on prend des notes, il peut être difficile de se rappeler
