The =proxyPassword= will be stored in plain text (unencrypted) in your ~.gitconfig~ file,
which you may not want. In that case, remove it from the URL and you
will be prompted for it every time it is needed.
To stop using a proxy, simply use the following command:
#+begin_src shell :results output :exports both
git config --global --unset http.proxy
#+end_src
** Getting your default password on GitLab (and possibly changing it)
*Warning (Jupyter users) :* changing your default Gitlab password will
prevent you from committing in Jupyter. You will have to do the extra
@@ -160,6 +170,25 @@ git config credential.helper store
Your password will be then stored in a =.git-credentials= file in plain
text. On a perfectly secured machine, it may be fine... or not... ;)
Use it at your own risk.
To delete all the passwords that may have been stored, simply use the
following command:
git config --system --unset credential.helper
#+end_src
Finally, those of you using Windows may get the following error
message:
#+BEGIN_EXAMPLE
git: 'credential-cache' is not a git command. See 'get --help'.
#+END_EXAMPLE
This issue is mentioned on [[https://stackoverflow.com/questions/11693074/git-credential-cache-is-not-a-git-command][stackoverflow]]. In such case, try the
following command:
git config --global --unset credential.helper
#+end_src
If the problem persists, do not hesitate to describe your problem on
the MOOC forum to get some help.
** Optional: authenticating through SSH
There are two ways of authenticating and synchronizing your local
repository with GitLab: through HTTPS or through SSH. The first one is
Ces deux paramètres sont obligatoire pour pouvoir commiter sinon
vous obtiendrez le message suivant:
#+BEGIN_CENTER
[[file:gitlab_images/commit3.png]]
#+END_CENTER
3. Confirmer que vous avez correctement défini le nom d'utilisateur et
l'email Git :
@@ -97,6 +102,13 @@ Le =proxyPassword= sera stocké en texte brut (non crypté) dans votre
fichier ~.gitconfig~, ce que vous ne souhaitez peut-être pas. Dans ce
cas, supprimez-le de l'URL et vous serez invité à le saisir chaque fois
que vous en aurez besoin.
Pour effacer l'utilisation de ce proxy, il vous suffit d'utiliser cette
commande :
#+end_src
** Récupérer votre mot de passe par défaut sur GitLab (et le changer éventuellement)
*Avertissement (utilisateurs Jupyter) :* changer votre mot de passe
Gitlab par défaut vous empêchera de commiter les notebooks Jupyter que
@@ -179,6 +191,25 @@ Votre mot de passe sera alors stocké dans un fichier =.git-credentials=
en texte brut (non-crypté). Sur une machine parfaitement sécurisée,
cela peut être très bien... ou pas... ;) Utilisez cette possibilité à
vos risques et périls.
Si vous souhaitez effacer les mots de passe enregistrés, il vous
suffit d'utiliser cette commande :
#+end_src
Enfin, il peut arriver que vous ayez le message d'erreur suivant sous
Windows:
#+BEGIN_EXAMPLE
#+END_EXAMPLE
Ce problème est évoqué sur [[https://stackoverflow.com/questions/11693074/git-credential-cache-is-not-a-git-command][stackoverflow]]. Dans ce cas, tentez la
commande suivante :
#+end_src
Si ça ne marche toujours pas, n'hésitez pas à décrire votre problème
sur le forum du MOOC.
** Optionnel : authentification par SSH
Il existe deux manières d'authentifier et de synchroniser votre
dépôt local avec GitLab : via HTTPS ou via SSH. Le premier est ce
