Commit 5c418976 authored by Konrad Hinsen's avatar Konrad Hinsen
Revision of the Jupyter resources (module 2)
parent b5e5438d
...@@ -6,9 +6,9 @@ ...@@ -6,9 +6,9 @@
#+OPTIONS: num:nil toc:t #+OPTIONS: num:nil toc:t
#+PROPERTY: header-args :eval never-export #+PROPERTY: header-args :eval never-export
* 1. Jupyter Tips and tricks * 1. Jupyter tips and tricks
The following [[https://www.dataquest.io/blog/jupyter-notebook-tips-tricks-shortcuts/][webpage]] lists several Jupyter tricks (in particular, it The following [[https://www.dataquest.io/blog/jupyter-notebook-tips-tricks-shortcuts/][webpage]] lists several Jupyter tricks (in particular, it
illustrates many =Ipython magic= commands) that should improve your illustrates many =IPython magic= commands) that should improve your
efficiency (note that this blog post is about two years old so some of efficiency (note that this blog post is about two years old so some of
the tricks may have been integrated in the default behavior of Jupyter the tricks may have been integrated in the default behavior of Jupyter
now). now).
...@@ -33,27 +33,33 @@ Note that this =%%R= notation indicates that R should be used for the whole cell ...@@ -33,27 +33,33 @@ Note that this =%%R= notation indicates that R should be used for the whole cell
an other possibility is to use =%R= to have a single line of R within a an other possibility is to use =%R= to have a single line of R within a
python cell. python cell.
** Other languages ** Other languages
For any reason, you may be unsatisfied with the use of R or of Jupyter is not limited to Pytyhon and R. Many other languages are available:
Python. Many other languages are available:
[[https://github.com/jupyter/jupyter/wiki/Jupyter-kernels][https://github.com/jupyter/jupyter/wiki/Jupyter-kernels]], including [[https://github.com/jupyter/jupyter/wiki/Jupyter-kernels][https://github.com/jupyter/jupyter/wiki/Jupyter-kernels]], including
non-free languages like SAS, Mathematica, Matlab... non-free languages like SAS, Mathematica, Matlab... Note that the maturity of these kernels differs widely.
None of these other languages have been deployed in the context of our None of these other languages have been deployed in the context of our
MOOC but you may want to read the next sections to know more about how MOOC but you may want to read the next sections to learn how
to set up your own Jupyter notebooks on your computer and benefit from these to set up your own Jupyter on your computer and benefit from these extensions.
extensions.
Since the question was asked several times, if you really need to stay
with SAS, you should know that SAS can be used within Jupyter using
either the [[https://sassoftware.github.io/sas_kernel/][Python SASKernel]] or the [[https://sassoftware.github.io/saspy/][Python SASPy]] package (step by step
explanations about this are given [[https://app-learninglab.inria.fr/gitlab/85bc36e0a8096c618fbd5993d1cca191/mooc-rr/blob/master/documents/tuto_jupyter_windows/tuto_jupyter_windows.md][here]]).
Since proprietary software such as SAS cannot easily be inspected, we discourage its use as it hinders reproducibility by
essence. But perfection does not exist anyway and using Jupyter
literate programming approach allied with systematic control version
and environment control will certainly help anyway.
* 2. Installing and configuring Jupyter on your computer * 2. Installing and configuring Jupyter on your computer
In this Section, we provide information on how to set up on your own In this section, we explain how to set up a Jupyter environment on
computer a Jupyter environment similar to the one deployed for this your own computer similar to the one deployed for this MOOC.
MOOC.
Note that Jupyter notebooks are only a small part of the picture and Note that Jupyter notebooks are only a small part of the picture and
that Jupyter is now part of a bigger project: [[https://blog.jupyter.org/jupyterlab-is-ready-for-users-5a6f039b8906][JupyterLab]], which allows that Jupyter is now part of a bigger project: [[https://blog.jupyter.org/jupyterlab-is-ready-for-users-5a6f039b8906][JupyterLab]], which allows
you to mix various components (including notebooks) in your you to mix various components (including notebooks) in your
browser. In the context of this MOOC, our time frame was too short to browser. In the context of this MOOC, our time frame was too short to
benefit from JupyterLab which was still under active development but benefit from JupyterLab which was still under active development. You may, however, prefer JupyterLab when doing an installation on your own computer.
this is probably the best option now if you want to benefit from
cutting-edge Jupyter notebooks.
** 2.1 Installing Jupyter ** 2.1 Installing Jupyter
Follow these instructions if you wish to have a Jupyter environment on Follow these instructions if you wish to have a Jupyter environment on
...@@ -78,9 +84,9 @@ source activate mooc_rr ...@@ -78,9 +84,9 @@ source activate mooc_rr
jupyter notebook jupyter notebook
#+end_src #+end_src
** 2.2 Making sure Jupyter allows you to use R ** 2.2 Making sure Jupyter allows you to use R
The previous environment should ship with R but if you proceeded The environment described in the last section should include R, but if
otherwise and only have python available in Jupyter, you may want to you proceeded otherwise and only have Python available in Jupyter, you
read the following section. may want to read the following section.
*** • Installing [[https://github.com/IRkernel/IRkernel][IRKernel]] (R package) *** • Installing [[https://github.com/IRkernel/IRkernel][IRKernel]] (R package)
Do the following in R console: Do the following in R console:
...@@ -109,15 +115,15 @@ On Linux, the rpy2 package is available in standard distributions ...@@ -109,15 +115,15 @@ On Linux, the rpy2 package is available in standard distributions
#+begin_src shell :results output :exports both #+begin_src shell :results output :exports both
sudo apt-get install python3-rpy2 python3-tzlocal sudo apt-get install python3-rpy2 python3-tzlocal
#+end_src #+end_src
An other (not really recommended if the first one is available) An alternative (not really recommended if the first one is available)
alternative consists in going through the python package manager with consists in going through the python package manager with
#+begin_src python :results output :exports both #+begin_src python :results output :exports both
pip3 install rpy2 pip3 install rpy2
#+end_src #+end_src
*Windows* *Windows*
Download =rpy2= [[https://www.lfd.uci.edu/~gohlke/pythonlibs/#rpy2][binary file]] by choosing the right operating system. Download the =rpy2= [[https://www.lfd.uci.edu/~gohlke/pythonlibs/#rpy2][binary file]] by choosing the right operating system.
Open a DOS console and type the following command: Open a DOS console and type the following command:
...@@ -130,7 +136,7 @@ python -m pip install tzlocal ...@@ -130,7 +136,7 @@ python -m pip install tzlocal
#+end_src #+end_src
** 2.3 Additional tips ** 2.3 Additional tips
*** • Exporting a notebook *** • Exporting a notebook
Here is what we had to install on our recent debian computer to make sure Here is what we had to install on a recent Debian computer to make sure
the notebook export via LaTeX works: the notebook export via LaTeX works:
sudo apt-get install texlive-xetex wkhtmltopdf sudo apt-get install texlive-xetex wkhtmltopdf
...@@ -154,11 +160,10 @@ taste. ...@@ -154,11 +160,10 @@ taste.
*Windows* *Windows*
Download and install MiKTeX from the [[https://miktex.org/download][MiKTeX webpage]] Download and install MiKTeX from the [[https://miktex.org/download][MiKTeX webpage]] by choosing the
by choosing the right operating system. You will be prompted to install some specific right operating system. You will be prompted to install some specific
packages when exporting to pdf. packages when exporting to pdf.
*** • Side note about Jupyter, JupyterLab, JupyterHub...
*** • Improving notebook readability *** • Improving notebook readability
Here are a few extensions that can ease your life: Here are a few extensions that can ease your life:
- [[https://stackoverflow.com/questions/33159518/collapse-cell-in-jupyter-notebook][Code folding]] to improve readability when browsing the notebook. - [[https://stackoverflow.com/questions/33159518/collapse-cell-in-jupyter-notebook][Code folding]] to improve readability when browsing the notebook.
...@@ -175,14 +180,14 @@ Here are a few extensions that can ease your life: ...@@ -175,14 +180,14 @@ Here are a few extensions that can ease your life:
#+end_src #+end_src
*** • Interacting with GitLab and GitHub *** • Interacting with GitLab and GitHub
To ease your experience, we added some pull/push buttons that allow To ease your experience, we added pull/push buttons that allow
you to commit and sync with GitLab. This development was specific to you to commit and sync with GitLab. This development was specific to
the MOOC but inspired from a previous [[https://github.com/Lab41/sunny-side-up][proof of concept]]. We have the MOOC but inspired from a previous [[https://github.com/Lab41/sunny-side-up][proof of concept]]. We have
recently discovered that someone else developed about at the same time recently discovered that someone else developed about at the same time
a [[https://github.com/sat28/githubcommit][rather generic version of this Jupyter plugin]]. Otherwise, remember a [[https://github.com/sat28/githubcommit][rather generic version of this Jupyter plugin]]. Otherwise, remember
that it is very easy to insert a shell cell in Jupyter in which you that it is very easy to insert a shell cell in Jupyter in which you
can easily issue git commands. This is how we work most of the time. can easily issue git commands. This is how we work most of the time.
This being said, you may have noticed that Jupyter keeps a perfect This being said, you may have noticed that Jupyter keeps a perfect
track of the sequence in which cells have been run by updating the track of the sequence in which cells have been run by updating the
"output index". This is a very good property from the reproducibility "output index". This is a very good property from the reproducibility
...@@ -192,26 +197,5 @@ hooks]] to ignore these numbers when committing Jupyter notebooks. There ...@@ -192,26 +197,5 @@ hooks]] to ignore these numbers when committing Jupyter notebooks. There
is a long an interesting discussion about various options on is a long an interesting discussion about various options on
[[https://stackoverflow.com/questions/18734739/using-ipython-notebooks-under-version-control][StackOverflow]]. [[https://stackoverflow.com/questions/18734739/using-ipython-notebooks-under-version-control][StackOverflow]].
Last but not least, remember that Jupyter notebooks are only a small For those who use [[https://blog.jupyter.org/jupyterlab-is-ready-for-users-5a6f039b8906][JupyterLab]] rather than the plain Jupyter, a specific [[https://github.com/jupyterlab/jupyterlab-git][JupyterLab git plugin]] has been developed to offer a nice version control experience.
part of the picture and that Jupyter is now part of a bigger project:
[[https://blog.jupyter.org/jupyterlab-is-ready-for-users-5a6f039b8906][JupyterLab]], which allows you to mix various components (including
notebooks) in your browser. A specific [[https://github.com/jupyterlab/jupyterlab-git][JupyterLab git plugin]] has been
*** • Using other languages (e.g., SAS, Matlab, Mathematica, etc.)
Since such software cannot easily be opened for inspection not widely
used, we discourage this approach as it hinders reproducibility by
