Commit 6fe7d46b authored by Arnaud Legrand's avatar Arnaud Legrand
Source files demoed in sequence 3
parent bd4f8a6d
title: "Mon premier document"
author: "Arnaud Legrand"
date: "10 octobre 2017"
output: word_document
## R Markdown
This is an R Markdown document. Markdown is a simple formatting syntax for authoring HTML, PDF, and MS Word documents. For more details on using R Markdown see <http://rmarkdown.rstudio.com>.
When you click the **Knit** button a document will be generated that includes both content as well as the output of any embedded R code chunks within the document. You can embed an R code chunk like this:
```{r cars}
summary(cars)
## Including Plots
You can also embed plots, for example:
```{r pressure, echo=FALSE}
plot(pressure)
Note that the `echo = FALSE` parameter was added to the code chunk to prevent printing of the R code that generated the plot.
## Ma propre section
```{r}
x=1
x
```{r}
x = x + 10
x
```{r}
hist(rnorm(1000))
```{r}
hist(rnorm(100,mean = 2, sd = .2))
## Un petit exemple avec d'autres langages
```{python}
from math import *
x = 3.14
print(sin(x))
```{python}
print(sin(x))
This diff is collapsed.
# -*- coding: utf-8 -*-
# -*- mode: org -*-
#+TITLE: Une petite démo d'Org-Mode
#+AUTHOR: Arnaud Legrand
#+STARTUP: overview indent inlineimages logdrawer
#+LANGUAGE: en
#+HTML_HEAD: <link rel="stylesheet" title="Standard" href="http://orgmode.org/worg/style/worg.css" type="text/css" />
#+PROPERTY: header-args :eval never-export
* Section 1
** Sous-section
* Section 2
** Foo
*** Hello
Avec du texte
- ici du *gras*
- et là, de /l'italique/
*** Salut
*** Etc
** Bar
** Baz
* Exécution de calculs :noexport:
#+begin_src R :results output :session *R* :exports both
cars
#+end_src
#+RESULTS:
#+begin_example
speed dist
1 4 2
2 4 10
3 7 4
4 7 22
5 8 16
6 9 10
7 10 18
8 10 26
9 10 34
10 11 17
11 11 28
12 12 14
13 12 20
14 12 24
15 12 28
16 13 26
17 13 34
18 13 34
19 13 46
20 14 26
21 14 36
22 14 60
23 14 80
24 15 20
25 15 26
26 15 54
27 16 32
28 16 40
29 17 32
30 17 40
31 17 50
32 18 42
33 18 56
34 18 76
35 18 84
36 19 36
37 19 46
38 19 68
39 20 32
40 20 48
41 20 52
42 20 56
43 20 64
44 22 66
45 23 54
46 24 70
47 24 92
48 24 93
49 24 120
50 25 85
#+end_example
#+begin_src R :results output graphics :file (org-babel-temp-file "figure" ".png") :exports results :width 600 :height 400 :session *R*
plot(cars)
#+end_src
#+RESULTS:
[[file:/tmp/babel-148945lI/figure14894n0r.png]]
(x=10)
#+end_src
#+RESULTS:
: [1] 10
(x = x+10)
#+end_src
#+RESULTS:
: [1] 20
* Autres langages
#+begin_src python :results output :exports both
print(2+2)
#+end_src
#+RESULTS:
: 4
#+begin_src shell :results output :exports both
ls /tmp
#+end_src
#+RESULTS:
#+begin_example
babel-148945lI
babel-1933r-E
babel-7506nSG
emacs1000
emacs14894axZ
firefox-esr_alegrand
mozilla_alegrand0
pulse-PKdhtXMmr18n
RtmpsK10QZ
RtmpvMPlZs
ScientificMethodologyProjectGithub.ipynb
ssh-KQXcWTA8Cx6u
systemd-private-0461cab7d3944a9e974b73d23efc09af-apache2.service-QPpUU4
systemd-private-0461cab7d3944a9e974b73d23efc09af-colord.service-wdsVAi
systemd-private-0461cab7d3944a9e974b73d23efc09af-iio-sensor-proxy.service-UYGEGU
systemd-private-0461cab7d3944a9e974b73d23efc09af-ModemManager.service-FKfsh9
systemd-private-0461cab7d3944a9e974b73d23efc09af-rtkit-daemon.service-43AVDL
systemd-private-0461cab7d3944a9e974b73d23efc09af-systemd-timesyncd.service-4pB1fo
thunderbird_alegrand
tracker-extract-files.1000
tutoriel.pdf
#+end_example
#+begin_src shell :session *shell* :results output :exports both
hostname
#+end_src
#+RESULTS:
: icarus
ssh nipmuk
#+end_src
#+RESULTS:
: The programs included with the Debian GNU/Linux system are free software;
: the exact distribution terms for each program are described in the
: individual files in /usr/share/doc/*/copyright.
: Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
: permitted by applicable law.
: Last login: Tue Apr 10 12:10:47 2018 from ligone.imag.fr
hostname
ls /tmp/
#+end_src
#+RESULTS:
: nipmuk
: ATN452-P5785-Linux-X64.bin tina_update vgauthsvclog.txt.0
: P57 tn_pipe vmware-root
: ssh-0xgYrn2tUz upgrade_linux.batch
Markdown is supported
0% or
You are about to add 0 people to the discussion. Proceed with caution.
Finish editing this message first!
Please register or to comment
