Learning Lab
856b8a32
856b8a32
Konrad Hinsen
Revision of the Git/GitLab resources (module 2)
0859d634
14 additions
14 deletions
+14
-14
gitlab.org
module2/ressources/gitlab.org
+14
-14
856b8a32
@@ -6,9 +6,9 @@
#+OPTIONS: num:nil toc:t
#+PROPERTY: header-args :eval never-export
*This document is particularly important if you follow the R
s
tudio or
the Org-Mode
course.* *If you follow the Jupyter course
, it can be
ignored
in a first step
* *as we have closely integrated Jupyter and
S
tudio or
the Org-Mode
path.* *If you follow the Jupyter path
, it can be
ignored
at first
GitLab in the context of this MOOC.*
So far, you only used git via the web interface from the GitLab we
@@ -30,10 +30,10 @@ Please read all these instructions carefully, in particular the one on
"Configuring your password on GitLab".
* Installing Git
** Linux (
debian, u
buntu)
We provide here only instructions for
d
ebian-based distributions. Feel
** Linux (
Debian, U
buntu)
D
free to contribute to this document to provide up-to-date information
for other distributions (e.g.,
redhat, f
edora).
RedHat, F
edora).
Run (as root):
#+begin_src sh :results output :exports both
@@ -42,7 +42,7 @@ apt-get update ; apt-get install git
** Mac OSX and Windows
- Download and install Git from the [[https://git-scm.com/downloads][Git website]].
- Optional Git clients (should not be needed if you work within
R
s
tudio):
R
S
tudio):
- [[https://www.sourcetreeapp.com/][SourceTree]]
- [[https://desktop.github.com/][GitHub Desktop]]
#+BEGIN_QUOTE
@@ -50,7 +50,7 @@ apt-get update ; apt-get install git
#+END_QUOTE
* Configuring Git
** Telling Git who you are: Name and Email
1. Open
T
erminal.
1. Open
t
erminal.
2. Set a Git username and email:
git config --global user.name "Mona Lisa"
@@ -158,16 +158,16 @@ installing SSH, creating a pair or private/public keys, and uploading
your SSH public key on GitLab. This section provides with information
on how to do this.
*** Installing SSH
**** Linux (
debian, u
buntu)
**** Linux (
Debian, U
buntu)
We provide here only instructions for debian-based distributions. Feel
redhat, f
edora).
RedHat, F
edora).
Run (as root):
apt-get update ; apt-get install openssh-client
Mac OSX
macOS
You do not have anything to do as it is installed by default.
**** Windows
You should install the [[https://www.ssh.com/ssh/putty/windows/][Putty]] client. Once it is installed, look for
@@ -182,9 +182,9 @@ video:
* Using Git through the command line to synchronize your local files with Gitlab
This section describes a generic (through the command line) way to
synchronize your local files with Gitlab. You will not need this if
course. If you follow the Rstudio course
, all
these operations can be done through R
s
tudio and you may want to read
[[file:rstudio.org][the corresponding instructions]]. If you follow the Org-Mode
course
, all
path. If you follow the RStudio path
, all
S
path
, all
these operations can be done through Magit and you may want to read
[[file:emacs_orgmode.org][the corresponding instructions]].
