Learning Lab
8e60f707
8e60f707
Damn!
1d9b100e
12 additions
9 deletions
+12
-9
jupyter.org
module2/ressources/jupyter.org
+12
-9
8e60f707
@@ -19,8 +19,8 @@ installed the =python3-rpy2= debian package with =apt-get install=. E.g.,
sudo apt-get install python3-rpy2 python3-tzlocal
An other (not really recomm
anded) alternative consists in going
ended if the first one is available)
through the python package manager with
pip3 install rpy2
pip3 install rpy2
@@ -31,7 +31,7 @@ Then you'll be able to use both languages in the same notebook by:
2. Using the =%R= Ipython magic:
%R
R
Python objects can then even be passed to R as follows (assuming =df=
@@ -40,6 +40,9 @@ Then you'll be able to use both languages in the same notebook by:
%%R -i df
%%R -i df
plot(df)
plot(df)
Note that this =%%R= notation allows you to use R for the whole cell but
an other possibility is to use =%R= to have a single line of R within a
python cell.
** Exporting a notebook
Obviously, you can convert to html or pdf using the using the =File >
Download as > HTML= (or =PDF=) menu option. This can also be done from
@@ -49,12 +52,12 @@ the command line with the following command:
ipython3 nbconvert --to pdf Untitled.ipynb
If you want to use a specific style, then the
nbconvert
exporter
=nbconvert=
exporter
should be customi
s
ed. This is discussed and demoed [[http://markus-beuckelmann.de/blog/customizing-nbconvert-pdf.html][here]]. We encourage
should be customi
z
you to simply read the [[https://nbconvert.readthedocs.io/en/latest/][doc of nbconvert]].
Instead of going directly through LaTeX and playing too much with the
nbconvert
exporter, an other option consists in exporting to Markdown
=nbconvert=
and playing with [[https://pandoc.org/][pandoc]]. Both approaches work, it's rather a matter of
taste.
taste.
* Installing Jupyter on your own machine
@@ -122,12 +125,12 @@ This being said, you may have noticed that Jupyter keeps a perfect
track of the sequence in which cells have been run by updating the
"output index". This is a very good property from the reproducibility
point of view but depending on your usage, you may find it a bit
painful when commit
ing. Some people have thus develop
ped [[https://gist.github.com/pbugnion/ea2797393033b54674af][specific git
painful when commit
ting. Some people have thus develo
hooks]] to ignore these numbers when comitting Jupyter notebooks. There
m
is a long an interesting discussion about various options on
[[https://stackoverflow.com/questions/18734739/using-ipython-notebooks-under-version-control][StackOverflow]].
Last but not least, rememb
t
er that Jupyter notebooks are only a small
Last but not least, remember that Jupyter notebooks are only a small
part of the picture and that Jupyter is now part of a bigger project:
[[https://blog.jupyter.org/jupyterlab-is-ready-for-users-5a6f039b8906][JupyterLab]], which allows you to mix various components (including
notebooks) in your browser. A specific [[https://github.com/jupyterlab/jupyterlab-git][JupyterLab git plugin]] has been
