- [[#version-control-with-gitlab-and-git-in-the-Reproducible-research-mooc][Version control with GitLab and Git]]
- [[#version-control-with-libreoffice-or-dokuwiki][Version control with LibreOffice or DokuWiki]]
* Version control with GitLab and Git in the "Reproducible research" MOOC
We have created a GitLab server especially for this MOOC so that you can smoothly learn how to implement version control.
This section describes the successive steps involved. The following [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/5571950188c946e790f06d4bc90fb5f6#InterfaceGitlab][video]] shows how to use GitLab. We strongly recommend that you watch it if you've never used GitLab before.
- Go to [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/5571950188c946e790f06d4bc90fb5f6#FormAccesGitlab][GitLab]] from the FUN platform (click on *Accédez à
Gitlab / Access to Gitlab*)
- You reach the following form :
#+BEGIN_CENTER
[[file:gitlab_images/sign_in.png]]
#+END_CENTER
- NB : You must reach GitLab from the FUN platform. You are likely to get a "405 error" if you are using the following address: https://app-learninglab.inria.fr/gitlab/users/sign_in.
#+BEGIN_CENTER
[[file:gitlab_images/erreur405.png]]
#+END_CENTER
- Click on **Sign in**. Authentication is automatic at that stage.
#+BEGIN_CENTER
[[file:gitlab_images/projects.png]]
#+END_CENTER
The long string replaced here by =xxx= is the login you will have to use in Git to synchronize with GitLab.
- To recover a predefined password you must use [[https://app-learninglab.inria.fr/jupyterhub/services/password][Gitlab
credentials retrieval tool]]. One gets then the login and password.
#+BEGIN_CENTER
[[file:gitlab_images/password_retrieval.png]]
#+END_CENTER
- You can change this password in "Account /
Paramètres / Mot de passe". We do not recommend doing it since that will block you from using the Jupyter notebooks of this MOOC.
#+BEGIN_CENTER
[[file:gitlab_images/password.png]]
#+END_CENTER
If you want to go further, few tutorial videos are gathered in [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/7508aece244548349424dfd61ee3ba85][sequence "7. Installations, configurations, references" of module 2]]
of this MOOC.
* Version control with LibreOffice or DokuWiki
Modification tracking in files generated and managed by =LibreOffice= is briefly described on the [[https://help.libreoffice.org/Common/Recording_Changes][wiki page]] of this software. A [[https://help.libreoffice.org/Common/Navigating_Changes][table of contents]] of the pages dedicated to this subject is available.
