Learning Lab
91dc1d7a
Commit
91dc1d7a
by
Konrad Hinsen
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
Nouvelle partie 2 du tutoriel snakemake
parent
34dddc74
Changes
8
Expand all
Hide whitespace changes
Inline
Side-by-side
Showing
8 changed files
with
362 additions
and
427 deletions
+362
-427
Snakefile
...incidence_syndrome_grippal_par_region_snakemake/Snakefile
+0
-58
annual-incidence-histogram.R
...par_region_snakemake/scripts/annual-incidence-histogram.R
+0
-11
annual-incidence.R
...e_grippal_par_region_snakemake/scripts/annual-incidence.R
+0
-23
incidence-plots.R
...me_grippal_par_region_snakemake/scripts/incidence-plots.R
+0
-13
peak-years.py
...ndrome_grippal_par_region_snakemake/scripts/peak-years.py
+0
-21
preprocess.py
...ndrome_grippal_par_region_snakemake/scripts/preprocess.py
+0
-65
split-by-region.py
...e_grippal_par_region_snakemake/scripts/split-by-region.py
+0
-37
snakemake_tutorial_fr.org
module6/ressources/snakemake_tutorial_fr.org
+362
-199
No files found.
module6/ressources/incidence_syndrome_grippal_par_region_snakemake/Snakefile
deleted
100644 → 0
View file @
34dddc74
rule all:
input:
"data/peak-year-all-regions.txt"
rule download:
output:
"data/weekly-incidence-all-regions.csv"
shell:
"wget -O {output} http://www.sentiweb.fr/datasets/incidence-RDD-3.csv"
checkpoint split_by_region:
input:
output:
directory("data/by-region")
script:
"scripts/split-by-region.py"
rule preprocess:
input:
"data/by-region/weekly-incidence-{region}.csv"
output:
data="data/preprocessed-weekly-incidence-{region}.csv",
errorlog="data/errors-from-preprocessing-{region}.txt"
script:
"scripts/preprocess.py"
rule plot:
input:
output:
"data/weekly-incidence-plot-{region}.png",
"data/weekly-incidence-plot-last-years-{region}.png"
script:
"scripts/incidence-plots.R"
rule annual_incidence:
input:
output:
"data/annual-incidence-{region}.csv"
script:
"scripts/annual-incidence.R"
def annual_incidence_files(wildcards):
directory = checkpoints.split_by_region.get().output[0]
pattern = os.path.join(directory, "weekly-incidence-{region}.csv")
print("Pattern:", pattern)
return expand("data/annual-incidence-{region}.csv",
region=glob_wildcards(pattern).region)
rule peak_years:
input:
output:
script:
"scripts/peak-years.py"
module6/ressources/incidence_syndrome_grippal_par_region_snakemake/scripts/annual-incidence-histogram.R
deleted
100644 → 0
View file @
34dddc74
# Read in the data and convert the dates
data
read.csv
snakemake
input
1
# Plot the histogram
png
filename
snakemake
output
1
hist
data
incidence
breaks
10
xlab
"Annual incidence"
ylab
"Number of observations"
main
dev.off
module6/ressources/incidence_syndrome_grippal_par_region_snakemake/scripts/annual-incidence.R
deleted
100644 → 0
View file @
34dddc74
data
read.csv
snakemake
input
1
names
data
c
"date"
"incidence"
data
date
as.Date
data
date
# A function that extracts the peak for year N
yearly_peak
function
year
start
paste0
year
-1
"-08-01"
end
paste0
year
"-08-01"
records
data
date
start
data
date
end
sum
data
incidence
records
# The years for which we have the full peak
years
1986
2018
# Make a new data frame for the annual incidences
annual_data
data.frame
year
years
incidence
sapply
years
yearly_peak
# write output file
write.csv
annual_data
file
snakemake
output
1
row.names
FALSE
module6/ressources/incidence_syndrome_grippal_par_region_snakemake/scripts/incidence-plots.R
deleted
100644 → 0
View file @
34dddc74
data
read.csv
snakemake
input
1
data
week_starting
as.Date
data
week_starting
# Plot the complete incidence dataset
png
filename
snakemake
output
1
plot
data
type
"l"
xlab
"Date"
ylab
"Weekly incidence"
dev.off
# Zoom on the last four years
png
filename
snakemake
output
2
plot
tail
data
4
52
type
"l"
xlab
"Date"
ylab
"Weekly incidence"
dev.off
module6/ressources/incidence_syndrome_grippal_par_region_snakemake/scripts/peak-years.py
deleted
100644 → 0
View file @
34dddc74
# Libraries used by this script:
import
csv
# for reading CSV files
import
os
# for path manipulations
with
open
snakemake
output
'w'
as
result_file
for
filename
in
snakemake
input
region
join
os
path
splitext
filename
split
2
with
open
filename
'r'
as
csv_file
csv_reader
csv
reader
csv_file
csv_reader
__next__
peak_year
None
peak_incidence
for
year
incidence
in
csv_reader
incidence
int
incidence
if
incidence
peak_incidence
peak_incidence
incidence
peak_year
year
result_file
write
region
result_file
write
result_file
write
peak_year
result_file
write
\n
module6/ressources/incidence_syndrome_grippal_par_region_snakemake/scripts/preprocess.py
deleted
100644 → 0
View file @
34dddc74
import
datetime
# for date conversion
import
csv
# for writing output to a CSV file
# Read the CSV file into memory
data
open
snakemake
input
'r'
read
# Remove white space at both ends,
# and split into lines.
lines
data
strip
split
\n
# Split each line into columns
table
line
split
for
line
in
lines
# Remove records with missing data and write
# the removed records to a separate file for inspection.
with
open
snakemake
output
errorlog
"w"
as
errorlog
valid_table
for
row
in
table
missing
any
column
for
column
in
row
if
missing
errorlog
write
"Missing data in record
\n
errorlog
write
str
row
errorlog
write
\n
else
valid_table
append
row
# Extract the two relevant columns, "week" and "inc"
week
row
for
row
in
valid_table
assert
week
'week'
del
week
inc
row
2
for
row
in
valid_table
assert
inc
'inc'
del
inc
data
list
zip
week
inc
# Check for obviously out-of-range values
with
open
snakemake
output
errorlog
"a"
as
errorlog
for
week
inc
in
data
if
len
week
6
or
not
week
isdigit
errorlog
write
"Suspect value in column 'week': {week}
\n
if
not
inc
isdigit
errorlog
write
"Suspect value in column 'inc': {inc}
\n
# Convert year/week by date of the corresponding Monday,
# then sort by increasing date
converted_data
datetime
datetime
strptime
year_and_week
":1"
G
V:
u'
date
inc
for
year_and_week
inc
in
data
converted_data
sort
key
lambda
record
record
# Check that consecutive dates are seven days apart
with
open
snakemake
output
errorlog
"a"
as
errorlog
dates
date
for
date
_
in
converted_data
for
date1
date2
in
zip
dates
1
dates
1
if
date2
date1
datetime
timedelta
weeks
1
errorlog
write
f
"{date2-date1} between {date1} and {date2}
\n
# Write data to a CSV file with two columns:
# 1. the date of the Monday of each week, in ISO format
# 2. the incidence estimate for that week
with
open
snakemake
output
data
"w"
as
csvfile
csv_writer
csv
writer
csvfile
csv_writer
writerow
"week_starting"
"incidence"
for
row
in
converted_data
csv_writer
writerow
row
module6/ressources/incidence_syndrome_grippal_par_region_snakemake/scripts/split-by-region.py
deleted
100644 → 0
View file @
34dddc74
import
os
data
open
snakemake
input
'rb'
read
# Decode the Latin-1 character set,
# remove white space at both ends,
lines
data
decode
'latin-1'
strip
split
\n
# Separate header from data table
comment
lines
header
lines
1
table
line
split
for
line
in
lines
2
# Find all the regions mentioned in the table
regions
set
record
1
for
record
in
table
# Create the output directory
directory
snakemake
output
if
not
os
path
exists
directory
os
makedirs
directory
# Write CSV files for each region
for
region
in
regions
# Some region names contain spaces which are awkward in filenames
region_name
join
region
split
filename
os
path
join
directory
'weekly-incidence-'
region_name
'.csv'
with
open
filename
'w'
as
output_file
output_file
write
header
output_file
write
\n
for
record
in
table
# Write only the records for right region
if
record
1
region
output_file
write
join
record
output_file
write
\n
View file @
91dc1d7a
This diff is collapsed.
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
You are about to add
people
to the discussion. Proceed with caution.
Finish editing this message first!
Please
register
or
sign in
to comment
