Commit aa38514b authored by Arnaud Legrand's avatar Arnaud Legrand
parent 9e13cb24
...@@ -95,3 +95,62 @@ install knitr and ggplot2: ...@@ -95,3 +95,62 @@ install knitr and ggplot2:
install.packages("knitr") install.packages("knitr")
install.packages("ggplot2") install.packages("ggplot2")
#+END_SRC #+END_SRC
* Using Git from Rstudio
** Cloning a repository
Open RStudio and do the following steps:
- Create a new version controled project: =File / New Project / Version
Control=
#+BEGIN_CENTER
file:rstudio_images/new_project.png
file:rstudio_images/git.png
#+END_CENTER
- Get the url from your gitlab repository:
#+BEGIN_CENTER
file:rstudio_images/adresse_depot.png
#+END_CENTER
- Indicate this URL in the "Repository URL" field (/you may want to
prefix this URL with =xxx@= where =xxx= is/ /your Gitlab id to avoid
repeatedly giving it later on/).
#+BEGIN_CENTER
file:rstudio_images/clone.png
#+END_CENTER
- If you're behind a proxy, git should be configured
accordingly. Check the [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/jump_to_id/7508aece244548349424dfd61ee3ba85]["Dealing with proxies" section]].
- Git will then connect to Gitlab and fetch a whole copy of the
repository.
- RStudio should restart in a mode related to Git:
#+BEGIN_CENTER
file:rstudio_images/rstudio.png
#+END_CENTER
- The file manager on the right, allows you to browse the version
controled repository.
** Modifying a file
- Open =Module2/exo1/toy_document.Rmd= and perform a simple
modification.
- Save
- Go to the Git menu to commit
#+BEGIN_CENTER
file:rstudio_images/commit.png
file:rstudio_images/commit2.png
#+END_CENTER
- Select the lines to commit and then click on =commit=
#+BEGIN_CENTER
file:rstudio_images/commit5.png
#+END_CENTER
Your modifications have now been commited on your local
machine. They haven't been propagated to GitLab yet.
- Click on =push= to propagate them on GitLab
#+BEGIN_CENTER
file:rstudio_images/push.png
file:rstudio_images/push2.png
file:rstudio_images/push3.png
#+END_CENTER
*NB*: You won't be able to propagate your modifications on GitLab if
some modifications have been done on GitLab in the meantime.
file:rstudio_images/push4.png
- You should first merge these remote modifications locally. Click on
=pull= to get these modifications on your machine.
Markdown is supported
0% or
You are about to add 0 people to the discussion. Proceed with caution.
Finish editing this message first!
Please register or to comment
