Commit bfbf4f51 authored by Arnaud Legrand's avatar Arnaud Legrand
Final (?) reorganization and link to FUN video tutorials
parent f73a0879
...@@ -4,39 +4,39 @@ ...@@ -4,39 +4,39 @@
<h2>Table of Contents</h2> <h2>Table of Contents</h2>
<div id="text-table-of-contents"> <div id="text-table-of-contents">
<ul style="margin:0 0;"> <ul style="margin:0 0;">
<li style="margin-bottom:0;"><a href="#org8e60217">Installing emacs, org-mode, ess, and auctex.</a> <li style="margin-bottom:0;"><a href="#org6cfce99">Installing emacs, org-mode, ess, and auctex.</a>
<li style="margin-bottom:0;"><a href="#org90ba83d">Linux (Debian, Ubuntu)</a></li> <li style="margin-bottom:0;"><a href="#org8d53875">Linux (Debian, Ubuntu)</a></li>
<li style="margin-bottom:0;"><a href="#orgc1dd1e3">Mac OS X</a></li> <li style="margin-bottom:0;"><a href="#org944c375">Mac OS X</a></li>
<li style="margin-bottom:0;"><a href="#org62cb87b">Windows</a></li> <li style="margin-bottom:0;"><a href="#org64b96e7">Windows</a></li>
</ul> </ul>
</li> </li>
<li style="margin-bottom:0;"><a href="#org71d5afd">A simple "<i>reproducible research</i>" emacs configuration</a> <li style="margin-bottom:0;"><a href="#orgf731fcb">A simple "<i>reproducible research</i>" emacs configuration</a>
<li style="margin-bottom:0;"><a href="#org8c38e5f">Step 0: Backup and download our configuration</a></li> <li style="margin-bottom:0;"><a href="#org1212448">Step 0: Backup and download our configuration</a></li>
<li style="margin-bottom:0;"><a href="#org5d0c52b">Step 1: Prepare your journal</a></li> <li style="margin-bottom:0;"><a href="#orga58da00">Step 1: Prepare your journal</a></li>
<li style="margin-bottom:0;"><a href="#org04abd1a">Step 2: Set up Emacs configuration</a></li> <li style="margin-bottom:0;"><a href="#org5f660e7">Step 2: Set up Emacs configuration</a></li>
<li style="margin-bottom:0;"><a href="#org2ac8291">Step 3: Check whether the installation is working or not</a></li> <li style="margin-bottom:0;"><a href="#orgcfcc2ff">Step 3: Check whether the installation is working or not</a></li>
<li style="margin-bottom:0;"><a href="#orgc0e8300">Step 4: Open and play with your journal:</a></li> <li style="margin-bottom:0;"><a href="#orged2e102">Step 4: Open and play with your journal:</a></li>
</ul> </ul>
</li> </li>
<li style="margin-bottom:0;"><a href="#orgec2f0d0">A stub of replicable article</a></li> <li style="margin-bottom:0;"><a href="#org2c8a2b3">A stub of replicable article</a></li>
<li style="margin-bottom:0;"><a href="#orge37f27c">Emacs Tips and tricks</a> <li style="margin-bottom:0;"><a href="#org6025dd0">Emacs Tips and tricks</a>
<li style="margin-bottom:0;"><a href="#org3c808db">Cheat-sheets</a> <li style="margin-bottom:0;"><a href="#org9df9d92">Cheat-sheets</a>
<li style="margin-bottom:0;"><a href="#orgbbb0dee">Emacs</a></li> <li style="margin-bottom:0;"><a href="#org76a8ca9">Emacs</a></li>
<li style="margin-bottom:0;"><a href="#org35b96e8">Org-mode</a></li> <li style="margin-bottom:0;"><a href="#orgc325c7b">Org-mode</a></li>
</ul> </ul>
</li> </li>
<li style="margin-bottom:0;"><a href="#orgebb57d1">Video tutorials</a></li> <li style="margin-bottom:0;"><a href="#org70f6690">Video tutorials</a></li>
<li style="margin-bottom:0;"><a href="#org538c45f">Additional useful emacs packages</a> <li style="margin-bottom:0;"><a href="#org365abd5">Additional useful emacs packages</a>
<li style="margin-bottom:0;"><a href="#orga430a9e">Company-mode</a></li> <li style="margin-bottom:0;"><a href="#orgd4c07e0">Company-mode</a></li>
<li style="margin-bottom:0;"><a href="#orga2a61a4">Magit</a></li> <li style="margin-bottom:0;"><a href="#org49509c0">Magit</a></li>
</ul> </ul>
</li> </li>
<li style="margin-bottom:0;"><a href="#org7097ad4">Other resources</a></li> <li style="margin-bottom:0;"><a href="#orgd1052e7">Other resources</a></li>
</ul> </ul>
</li> </li>
</ul> </ul>
...@@ -45,25 +45,24 @@ ...@@ -45,25 +45,24 @@
<p> <p>
<b>Disclaimer:</b> The two sections <span class="underline">A simple "<i>reproducible research</i>" emacs <b>Disclaimer:</b> The two sections <span class="underline">A simple "<i>reproducible research</i>" emacs
configuration</span> and <span class="underline">A stub of replicable article</span> explain how to set up configuration</span> and <span class="underline">A stub of replicable article</span> explain how to set up
org-mode for this MOOC. <b>I have prepared two video tutorials (here and org-mode for this MOOC. <b>These sections are illustrated in two out of
here) for each, which you really should follow carefully</b>. <b>Otherwise, the <a href="https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/courseware/66bc811404b8481da5f794de54681c5e/aefd774dcd2342c6aa769c87e2d0993a/3">three video tutorials of this sequence</a>, and</b> <b>which you really
you may have trouble doing the exercises later on</b>. Likewise, I should follow carefully</b>. <b>Otherwise, you may have trouble doing the
strongly encourage you to watch the "emacs and git" video tutorial. exercises later on</b>. Likewise, I strongly encourage you to watch the
<a href="https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/courseware/66bc811404b8481da5f794de54681c5e/aefd774dcd2342c6aa769c87e2d0993a/3">"emacs and git" video tutorial available at the same place</a>.
</p> </p>
<p> <p>
The next sections provide information on how to install emacs. Before The next section provides information on how to install emacs.
proceeding, make sure you have read the "Git and GitLab" instructions
(tutorial and resources from the 4th sequence of the 2nd module).
</p> </p>
<div id="outline-container-org8e60217" class="outline-2"> <div id="outline-container-org6cfce99" class="outline-2">
<h2 id="org8e60217">Installing emacs, org-mode, ess, and auctex.</h2> <h2 id="org6cfce99">Installing emacs, org-mode, ess, and auctex.</h2>
<div class="outline-text-2" id="text-org8e60217"> <div class="outline-text-2" id="text-org6cfce99">
</div> </div>
<div id="outline-container-org90ba83d" class="outline-3"> <div id="outline-container-org8d53875" class="outline-3">
<h3 id="org90ba83d">Linux (Debian, Ubuntu)</h3> <h3 id="org8d53875">Linux (Debian, Ubuntu)</h3>
<div class="outline-text-3" id="text-org90ba83d"> <div class="outline-text-3" id="text-org8d53875">
<p> <p>
We provide here only instructions for debian-based distributions. Feel We provide here only instructions for debian-based distributions. Feel
free to contribute to this document to provide up-to-date information free to contribute to this document to provide up-to-date information
...@@ -125,9 +124,9 @@ which is now deprecated. ...@@ -125,9 +124,9 @@ which is now deprecated.
</p> </p>
</div> </div>
</div> </div>
<div id="outline-container-orgc1dd1e3" class="outline-3"> <div id="outline-container-org944c375" class="outline-3">
<h3 id="orgc1dd1e3">Mac OS X</h3> <h3 id="org944c375">Mac OS X</h3>
<div class="outline-text-3" id="text-orgc1dd1e3"> <div class="outline-text-3" id="text-org944c375">
<ul class="org-ul"> <ul class="org-ul">
<li style="margin-bottom:0;"><p> <li style="margin-bottom:0;"><p>
<b>Option 1</b>: Install the <code>.dmg</code> file from <a href="http://vgoulet.act.ulaval.ca/">Vincent Goulet</a>: <b>Option 1</b>: Install the <code>.dmg</code> file from <a href="http://vgoulet.act.ulaval.ca/">Vincent Goulet</a>:
...@@ -160,9 +159,9 @@ brew install wget ...@@ -160,9 +159,9 @@ brew install wget
</ul> </ul>
</div> </div>
</div> </div>
<div id="outline-container-org62cb87b" class="outline-3"> <div id="outline-container-org64b96e7" class="outline-3">
<h3 id="org62cb87b">Windows</h3> <h3 id="org64b96e7">Windows</h3>
<div class="outline-text-3" id="text-org62cb87b"> <div class="outline-text-3" id="text-org64b96e7">
<p> <p>
Install the <code>.exe</code> file from <a href="http://vgoulet.act.ulaval.ca/">Vincent Goulet</a>: Install the <code>.exe</code> file from <a href="http://vgoulet.act.ulaval.ca/">Vincent Goulet</a>:
<a href="https://vigou3.github.io/emacs-modified-windows/">https://vigou3.github.io/emacs-modified-windows/</a>. It ships with recent <a href="https://vigou3.github.io/emacs-modified-windows/">https://vigou3.github.io/emacs-modified-windows/</a>. It ships with recent
...@@ -176,11 +175,11 @@ versions: ...@@ -176,11 +175,11 @@ versions:
</div> </div>
</div> </div>
</div> </div>
<div id="outline-container-org71d5afd" class="outline-2"> <div id="outline-container-orgf731fcb" class="outline-2">
<h2 id="org71d5afd">A simple "<i>reproducible research</i>" emacs configuration</h2> <h2 id="orgf731fcb">A simple "<i>reproducible research</i>" emacs configuration</h2>
<div class="outline-text-2" id="text-org71d5afd"> <div class="outline-text-2" id="text-orgf731fcb">
<p> <p>
This section is illustrated in a video tutorial (in French). Watching This section is illustrated in a <a href="https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/courseware/66bc811404b8481da5f794de54681c5e/aefd774dcd2342c6aa769c87e2d0993a/3">video tutorial</a> (in French). Watching
it before following the instructions given in this section may help. it before following the instructions given in this section may help.
</p> </p>
...@@ -196,9 +195,9 @@ adding a few org-mode specific configurations. ...@@ -196,9 +195,9 @@ adding a few org-mode specific configurations.
</p> </p>
</div> </div>
<div id="outline-container-org8c38e5f" class="outline-3"> <div id="outline-container-org1212448" class="outline-3">
<h3 id="org8c38e5f">Step 0: Backup and download our configuration</h3> <h3 id="org1212448">Step 0: Backup and download our configuration</h3>
<div class="outline-text-3" id="text-org8c38e5f"> <div class="outline-text-3" id="text-org1212448">
<p> <p>
The procedure we propose will wipe your already existing custom emacs The procedure we propose will wipe your already existing custom emacs
configuration if you already have one. <b>You should thus beforehand make configuration if you already have one. <b>You should thus beforehand make
...@@ -219,9 +218,9 @@ rr_org/journal.org ...@@ -219,9 +218,9 @@ rr_org/journal.org
</div> </div>
</div> </div>
<div id="outline-container-org5d0c52b" class="outline-3"> <div id="outline-container-orga58da00" class="outline-3">
<h3 id="org5d0c52b">Step 1: Prepare your journal</h3> <h3 id="orga58da00">Step 1: Prepare your journal</h3>
<div class="outline-text-3" id="text-org5d0c52b"> <div class="outline-text-3" id="text-orga58da00">
<p> <p>
Create an <code>org/</code> directory in the top of your home: Create an <code>org/</code> directory in the top of your home:
</p> </p>
...@@ -238,9 +237,9 @@ should give a try. ...@@ -238,9 +237,9 @@ should give a try.
</p> </p>
</div> </div>
</div> </div>
<div id="outline-container-org04abd1a" class="outline-3"> <div id="outline-container-org5f660e7" class="outline-3">
<h3 id="org04abd1a">Step 2: Set up Emacs configuration</h3> <h3 id="org5f660e7">Step 2: Set up Emacs configuration</h3>
<div class="outline-text-3" id="text-org04abd1a"> <div class="outline-text-3" id="text-org5f660e7">
<p> <p>
Copy <code>rr_org/init.el</code> in your <code>~/.emacs.d/</code> directory. Copy <code>rr_org/init.el</code> in your <code>~/.emacs.d/</code> directory.
</p> </p>
...@@ -252,9 +251,9 @@ configuration with the following command: <code>emacs -q -l rr_org/init.el</code ...@@ -252,9 +251,9 @@ configuration with the following command: <code>emacs -q -l rr_org/init.el</code
</p> </p>
</div> </div>
</div> </div>
<div id="outline-container-org2ac8291" class="outline-3"> <div id="outline-container-orgcfcc2ff" class="outline-3">
<h3 id="org2ac8291">Step 3: Check whether the installation is working or not</h3> <h3 id="orgcfcc2ff">Step 3: Check whether the installation is working or not</h3>
<div class="outline-text-3" id="text-org2ac8291"> <div class="outline-text-3" id="text-orgcfcc2ff">
<p> <p>
Open a new instance of Emacs and open a <code>foo.org</code> file. Copy the Open a new instance of Emacs and open a <code>foo.org</code> file. Copy the
following lines in this file: following lines in this file:
...@@ -285,9 +284,9 @@ is demonstrated in the <a href="https://app-learninglab.inria.fr/gitlab/learning ...@@ -285,9 +284,9 @@ is demonstrated in the <a href="https://app-learninglab.inria.fr/gitlab/learning
</p> </p>
</div> </div>
</div> </div>
<div id="outline-container-orgc0e8300" class="outline-3"> <div id="outline-container-orged2e102" class="outline-3">
<h3 id="orgc0e8300">Step 4: Open and play with your journal:</h3> <h3 id="orged2e102">Step 4: Open and play with your journal:</h3>
<div class="outline-text-3" id="text-orgc0e8300"> <div class="outline-text-3" id="text-orged2e102">
<p> <p>
In step 1, you were told to create an journal in In step 1, you were told to create an journal in
<code>~org/journal.org</code>. First you probably want to make sure this file is <code>~org/journal.org</code>. First you probably want to make sure this file is
...@@ -298,11 +297,11 @@ forums. ...@@ -298,11 +297,11 @@ forums.
</div> </div>
</div> </div>
</div> </div>
<div id="outline-container-orgec2f0d0" class="outline-2"> <div id="outline-container-org2c8a2b3" class="outline-2">
<h2 id="orgec2f0d0">A stub of replicable article</h2> <h2 id="org2c8a2b3">A stub of replicable article</h2>
<div class="outline-text-2" id="text-orgec2f0d0"> <div class="outline-text-2" id="text-org2c8a2b3">
<p> <p>
</p> </p>
...@@ -363,22 +362,22 @@ chunk of code when exporting. ...@@ -363,22 +362,22 @@ chunk of code when exporting.
</div> </div>
</div> </div>
<div id="outline-container-orge37f27c" class="outline-2"> <div id="outline-container-org6025dd0" class="outline-2">
<h2 id="orge37f27c">Emacs Tips and tricks</h2> <h2 id="org6025dd0">Emacs Tips and tricks</h2>
<div class="outline-text-2" id="text-orge37f27c"> <div class="outline-text-2" id="text-org6025dd0">
</div> </div>
<div id="outline-container-org3c808db" class="outline-3"> <div id="outline-container-org9df9d92" class="outline-3">
<h3 id="org3c808db">Cheat-sheets</h3> <h3 id="org9df9d92">Cheat-sheets</h3>
<div class="outline-text-3" id="text-org3c808db"> <div class="outline-text-3" id="text-org9df9d92">
<p> <p>
Learning emacs and org-mode can be difficult as there is an inordinate Learning emacs and org-mode can be difficult as there is an inordinate
amount of shortcuts. Many people have thus come up with amount of shortcuts. Many people have thus come up with
cheat-sheats. Here is a selection in case it helps: cheat-sheats. Here is a selection in case it helps:
</p> </p>
</div> </div>
<div id="outline-container-orgbbb0dee" class="outline-4"> <div id="outline-container-org76a8ca9" class="outline-4">
<h4 id="orgbbb0dee">Emacs</h4> <h4 id="org76a8ca9">Emacs</h4>
<div class="outline-text-4" id="text-orgbbb0dee"> <div class="outline-text-4" id="text-org76a8ca9">
<li style="margin-bottom:0;"><a href="https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org">Common and step-by-step emacs shortcuts for our <i>reproducible research</i> configuration</a></li> <li style="margin-bottom:0;"><a href="https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org">Common and step-by-step emacs shortcuts for our <i>reproducible research</i> configuration</a></li>
<li style="margin-bottom:0;"><a href="https://www.gnu.org/software/emacs/refcards/pdf/refcard.pdf">The official GNU emacs refcard</a></li> <li style="margin-bottom:0;"><a href="https://www.gnu.org/software/emacs/refcards/pdf/refcard.pdf">The official GNU emacs refcard</a></li>
...@@ -387,9 +386,9 @@ cheat-sheats. Here is a selection in case it helps: ...@@ -387,9 +386,9 @@ cheat-sheats. Here is a selection in case it helps:
</ul> </ul>
</div> </div>
</div> </div>
<div id="outline-container-org35b96e8" class="outline-4"> <div id="outline-container-orgc325c7b" class="outline-4">
<h4 id="org35b96e8">Org-mode</h4> <h4 id="orgc325c7b">Org-mode</h4>
<div class="outline-text-4" id="text-org35b96e8"> <div class="outline-text-4" id="text-orgc325c7b">
<li style="margin-bottom:0;"><a href="https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org">Common and step-by-step org-mode shortcuts for our <i>reproducible research</i> configuration</a></li> <li style="margin-bottom:0;"><a href="https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org">Common and step-by-step org-mode shortcuts for our <i>reproducible research</i> configuration</a></li>
<li style="margin-bottom:0;"><a href="https://orgmode.org/worg/orgcard.html">The official org-mode refcard</a></li> <li style="margin-bottom:0;"><a href="https://orgmode.org/worg/orgcard.html">The official org-mode refcard</a></li>
...@@ -398,22 +397,22 @@ cheat-sheats. Here is a selection in case it helps: ...@@ -398,22 +397,22 @@ cheat-sheats. Here is a selection in case it helps:
</div> </div>
</div> </div>
</div> </div>
<div id="outline-container-orgebb57d1" class="outline-3"> <div id="outline-container-org70f6690" class="outline-3">
<h3 id="orgebb57d1">Video tutorials</h3> <h3 id="org70f6690">Video tutorials</h3>
<div class="outline-text-3" id="text-orgebb57d1"> <div class="outline-text-3" id="text-org70f6690">
<p> <p>
For those of you who prefer video explanations, here is a <a href="https://www.youtube.com/playlist?list=PL9KxKa8NpFxIcNQa9js7dQQIHc81b0-Xg">Youtube For those of you who prefer video explanations, here is a <a href="https://www.youtube.com/playlist?list=PL9KxKa8NpFxIcNQa9js7dQQIHc81b0-Xg">Youtube
channel with many step by step emacs tutorials</a>. channel with many step by step emacs tutorials</a>.
</p> </p>
</div> </div>
</div> </div>
<div id="outline-container-org538c45f" class="outline-3"> <div id="outline-container-org365abd5" class="outline-3">
<h3 id="org538c45f">Additional useful emacs packages</h3> <h3 id="org365abd5">Additional useful emacs packages</h3>
<div class="outline-text-3" id="text-org538c45f"> <div class="outline-text-3" id="text-org365abd5">
</div> </div>
<div id="outline-container-orga430a9e" class="outline-4"> <div id="outline-container-orgd4c07e0" class="outline-4">
<h4 id="orga430a9e">Company-mode</h4> <h4 id="orgd4c07e0">Company-mode</h4>
<div class="outline-text-4" id="text-orga430a9e"> <div class="outline-text-4" id="text-orgd4c07e0">
<p> <p>
<a href="http://company-mode.github.io/">Company-mode</a> is a text completion framework for Emacs. It allows to <a href="http://company-mode.github.io/">Company-mode</a> is a text completion framework for Emacs. It allows to
have smart completion in emacs for the most common languages. If you have smart completion in emacs for the most common languages. If you
...@@ -422,29 +421,28 @@ official Web page: <a href="http://company-mode.github.io/">http://company-mode. ...@@ -422,29 +421,28 @@ official Web page: <a href="http://company-mode.github.io/">http://company-mode.
</p> </p>
</div> </div>
</div> </div>
<div id="outline-container-orga2a61a4" class="outline-4"> <div id="outline-container-org49509c0" class="outline-4">
<h4 id="orga2a61a4">Magit</h4> <h4 id="org49509c0">Magit</h4>
<div class="outline-text-4" id="text-orga2a61a4"> <div class="outline-text-4" id="text-org49509c0">
<p> <p>
Magit]] is an emacs interface for Git. It is briefly illustrated in a <a href="https://magit.vc/">Magit</a> is an emacs interface for Git. Its usage is briefly illustrated
video tutorial. in the context of this MOOC in a <a href="https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/courseware/66bc811404b8481da5f794de54681c5e/aefd774dcd2342c6aa769c87e2d0993a/3">video tutorial</a> (in French).
</p> </p>
<p> <p>
It is very powerful and we use It is very powerful and we use it on a daily basis but you should
it on a daily basis but you should definitely understand what git does definitely understand what git does behind the scene beforehand. If
behind the scene beforehand. If you feel this would be useful for you, you feel this would be useful for you, you should follow <a href="https://magit.vc/screenshots/">this visual
you should follow the instructions from here: walk-through</a> or <a href="https://www.emacswiki.org/emacs/Magit">this really short "crash course"</a>. If you installed the
<a href="https://www.emacswiki.org/emacs/Magit">https://www.emacswiki.org/emacs/Magit</a>. If you installed the previous previous "<i>reproducible research</i>" emacs configuration, you can easily
"<i>reproducible research</i>" emacs configuration, you can easily invoke invoke magit by using <code>C-x g</code>.
</p> </p>
</div> </div>
</div> </div>
</div> </div>
<div id="outline-container-org7097ad4" class="outline-3"> <div id="outline-container-orgd1052e7" class="outline-3">
<h3 id="org7097ad4">Other resources</h3> <h3 id="orgd1052e7">Other resources</h3>
<div class="outline-text-3" id="text-org7097ad4"> <div class="outline-text-3" id="text-orgd1052e7">
<li style="margin-bottom:0;"><a href="https://orgmode.org/orgguide.pdf">The compact Org-mode Guide</a></li> <li style="margin-bottom:0;"><a href="https://orgmode.org/orgguide.pdf">The compact Org-mode Guide</a></li>
<li style="margin-bottom:0;"><a href="https://github.com/dfeich/org-babel-examples">Many examples illustrating the use of different languages in org-mode</a></li> <li style="margin-bottom:0;"><a href="https://github.com/dfeich/org-babel-examples">Many examples illustrating the use of different languages in org-mode</a></li>
...@@ -8,14 +8,13 @@ ...@@ -8,14 +8,13 @@
*Disclaimer:* The two sections _A simple "/reproducible research/" emacs *Disclaimer:* The two sections _A simple "/reproducible research/" emacs
configuration_ and _A stub of replicable article_ explain how to set up configuration_ and _A stub of replicable article_ explain how to set up
org-mode for this MOOC. *I have prepared two video tutorials (here and org-mode for this MOOC. *These sections are illustrated in two out of
here) for each, which you really should follow carefully*. *Otherwise, the [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/courseware/66bc811404b8481da5f794de54681c5e/aefd774dcd2342c6aa769c87e2d0993a/3][three video tutorials of this sequence]], and* *which you really
you may have trouble doing the exercises later on*. Likewise, I should follow carefully*. *Otherwise, you may have trouble doing the
strongly encourage you to watch the "emacs and git" video tutorial. exercises later on*. Likewise, I strongly encourage you to watch the
[[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/courseware/66bc811404b8481da5f794de54681c5e/aefd774dcd2342c6aa769c87e2d0993a/3]["emacs and git" video tutorial available at the same place]].
* Installing emacs, org-mode, ess, and auctex. * Installing emacs, org-mode, ess, and auctex.
** Linux (Debian, Ubuntu) ** Linux (Debian, Ubuntu)
...@@ -83,7 +82,7 @@ versions: ...@@ -83,7 +82,7 @@ versions:
- Org-mode 9.1.13 - Org-mode 9.1.13
- ESS 17.11 - ESS 17.11
* A simple "/reproducible research/" emacs configuration * A simple "/reproducible research/" emacs configuration
This section is illustrated in a video tutorial (in French). Watching This section is illustrated in a [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/courseware/66bc811404b8481da5f794de54681c5e/aefd774dcd2342c6aa769c87e2d0993a/3][video tutorial]] (in French). Watching
Emacs comes with very basic default configuration and it appears like Emacs comes with very basic default configuration and it appears like
...@@ -159,7 +158,7 @@ backed up in a revision control system like git. We leave it up to set ...@@ -159,7 +158,7 @@ backed up in a revision control system like git. We leave it up to set
this up but if you have any trouble, feel free to ask on the FUN this up but if you have any trouble, feel free to ask on the FUN
forums. forums.
* A stub of replicable article * A stub of replicable article
Remember, you need a working LaTeX and R environment. If you can't Remember, you need a working LaTeX and R environment. If you can't
...@@ -229,16 +228,15 @@ have smart completion in emacs for the most common languages. If you ...@@ -229,16 +228,15 @@ have smart completion in emacs for the most common languages. If you
feel this is needed, you should follow the instructions from the feel this is needed, you should follow the instructions from the
official Web page: http://company-mode.github.io/ official Web page: http://company-mode.github.io/
*** Magit *** Magit
Magit]] is an emacs interface for Git. It is briefly illustrated in a [[https://magit.vc/][Magit]] is an emacs interface for Git. Its usage is briefly illustrated
video tutorial. in the context of this MOOC in a [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/courseware/66bc811404b8481da5f794de54681c5e/aefd774dcd2342c6aa769c87e2d0993a/3][video tutorial]] (in French).
behind the scene beforehand. If you feel this would be useful for you, you feel this would be useful for you, you should follow [[https://magit.vc/screenshots/][this visual
you should follow the instructions from here: walk-through]] or [[https://www.emacswiki.org/emacs/Magit][this really short "crash course"]]. If you installed the
https://www.emacswiki.org/emacs/Magit. If you installed the previous previous "/reproducible research/" emacs configuration, you can easily
"/reproducible research/" emacs configuration, you can easily invoke invoke magit by using ~C-x g~.
** Other resources ** Other resources
- [[https://orgmode.org/orgguide.pdf][The compact Org-mode Guide]] - [[https://orgmode.org/orgguide.pdf][The compact Org-mode Guide]]
- [[https://github.com/dfeich/org-babel-examples][Many examples illustrating the use of different languages in org-mode]] - [[https://github.com/dfeich/org-babel-examples][Many examples illustrating the use of different languages in org-mode]]
