<listyle="margin-bottom:0;"><ahref="#org2040994">Mac OSX and Windows</a></li>
<listyle="margin-bottom:0;"><ahref="#org83ecc09">Mac OSX and Windows</a></li>
</ul>
</ul>
</li>
</li>
</ul>
</ul>
</div>
</div>
</div>
</div>
<p>
This document provides information on how to install Rstudio.
</p>
<p>
<p>
If you have never used git with Rstudio, <b>we strongly advise that you
follow <ahref="https://youtu.be/mThPqRH9tmA">our tutorial on using git from Rstudio</a></b> (in
follow <ahref="https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/courseware/66bc811404b8481da5f794de54681c5e/d6b5dbe8add046e4bde324ed3fc936fa/3">our tutorial on using git from Rstudio</a></b> (in French). Before
French). Alternatively, you may want to watch <ahref="https://www.youtube.com/embed/uHYcDQDbMY8">this video</a> (in
proceeding, make sure you also have followed the <b><ahref="https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/courseware/66bc811404b8481da5f794de54681c5e/f6580ad8e997400faeffe9af4fd37063/2">"git/GitLab
English). If you do not like videos, you should have a look at the
configuration" tutorial</a></b> (in French).
<ahref="https://swcarpentry.github.io/git-novice/14-supplemental-rstudio/index.html">step-by-step explanations from Software Carpentry</a>. It comes with many
screenshots and is quite progressive.
</p>
</p>
<p>
<p>
The next sections provide information on how to install
Alternatively, you may want to watch <ahref="https://www.youtube.com/embed/uHYcDQDbMY8">this video</a> (in English). If you
Rstudio. Before proceeding, make sure you have followed the <ahref="https://youtu.be/LR6gRpmHWx0">"Git and
do not like videos, you should have a look at the <ahref="https://swcarpentry.github.io/git-novice/14-supplemental-rstudio/index.html">step-by-step
GitLab" tutorial</a> from the 4th sequence of the 2nd module.
explanations from Software Carpentry</a>. It comes with many screenshots
</p>
</p>
<p>
<p>
Finally, you need to know that the Rstudio team has created a lot of
Last, you should know that the Rstudio team has created a lot of very
very good material and tutorials. You should definitively look at the
good material and tutorials. You should definitively look at the <ahref="https://www.rstudio.com/resources/cheatsheets/">Cheat
<ahref="https://www.rstudio.com/resources/cheatsheets/">Cheat sheets webpage</a>. In particular you want to have look at the ones
sheets webpage</a>. In particular you may want to have look at the
<listyle="margin-bottom:0;"><ahref="https://github.com/rstudio/cheatsheets/raw/master/data-visualization-2.1.pdf">Data visualization with ggplot2</a>,</li>
<listyle="margin-bottom:0;"><ahref="https://github.com/rstudio/cheatsheets/raw/master/data-transformation.pdf">Data transformation with dplyr</a></li>
</ul>
</ul>
<p>
<p>
In case it helps, here are some (sometimes outdated) French versions
of these documents:
of these documents:
@@ -58,13 +60,13 @@ of these documents:
<listyle="margin-bottom:0;"><ahref="https://www.fun-mooc.fr/c4x/UPSUD/42001S02/asset/RMarkdown.pdf">Un court document sur R Markdown</a></li>
If you have never used git with Rstudio, *we strongly advise that you
follow [[https://youtu.be/mThPqRH9tmA][our tutorial on using git from Rstudio]]* (in
follow [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/courseware/66bc811404b8481da5f794de54681c5e/d6b5dbe8add046e4bde324ed3fc936fa/3][our tutorial on using git from Rstudio]]* (in French). Before
French). Alternatively, you may want to watch [[https://www.youtube.com/embed/uHYcDQDbMY8][this video]] (in
proceeding, make sure you also have followed the *[[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/courseware/66bc811404b8481da5f794de54681c5e/f6580ad8e997400faeffe9af4fd37063/2]["git/GitLab
configuration" tutorial]]* (in French).
[[https://swcarpentry.github.io/git-novice/14-supplemental-rstudio/index.html][step-by-step explanations from Software Carpentry]]. It comes with many
Alternatively, you may want to watch [[https://www.youtube.com/embed/uHYcDQDbMY8][this video]] (in English). If you
Rstudio. Before proceeding, make sure you have followed the [[https://youtu.be/LR6gRpmHWx0]["Git and
do not like videos, you should have a look at the [[https://swcarpentry.github.io/git-novice/14-supplemental-rstudio/index.html][step-by-step
GitLab" tutorial]] from the 4th sequence of the 2nd module.
explanations from Software Carpentry]]. It comes with many screenshots
good material and tutorials. You should definitively look at the [[https://www.rstudio.com/resources/cheatsheets/][Cheat
[[https://www.rstudio.com/resources/cheatsheets/][Cheat sheets webpage]]. In particular you want to have look at the ones
sheets webpage]]. In particular you may want to have look at the
- [[https://github.com/rstudio/cheatsheets/raw/master/rmarkdown-2.0.pdf][R Markdown]] (here is also a [[https://rmarkdown.rstudio.com/][nice step-by-step presentation of Rmarkdown]]),
- The [[https://www.rstudio.com/wp-content/uploads/2015/03/rmarkdown-reference.pdf][R Markdown Reference guide]],
- [[https://github.com/rstudio/cheatsheets/raw/master/data-visualization-2.1.pdf][Data visualization with ggplot2]],
- [[https://github.com/rstudio/cheatsheets/raw/master/data-transformation.pdf][Data transformation with dplyr]]
