Commit bfbf4f51 authored by Arnaud Legrand's avatar Arnaud Legrand
Final (?) reorganization and link to FUN video tutorials
parent f73a0879
This diff is collapsed.
...@@ -8,14 +8,13 @@ ...@@ -8,14 +8,13 @@
*Disclaimer:* The two sections _A simple "/reproducible research/" emacs *Disclaimer:* The two sections _A simple "/reproducible research/" emacs
configuration_ and _A stub of replicable article_ explain how to set up configuration_ and _A stub of replicable article_ explain how to set up
org-mode for this MOOC. *I have prepared two video tutorials (here and org-mode for this MOOC. *These sections are illustrated in two out of
here) for each, which you really should follow carefully*. *Otherwise, the [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/courseware/66bc811404b8481da5f794de54681c5e/aefd774dcd2342c6aa769c87e2d0993a/3][three video tutorials of this sequence]], and* *which you really
you may have trouble doing the exercises later on*. Likewise, I should follow carefully*. *Otherwise, you may have trouble doing the
strongly encourage you to watch the "emacs and git" video tutorial. exercises later on*. Likewise, I strongly encourage you to watch the
[[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/courseware/66bc811404b8481da5f794de54681c5e/aefd774dcd2342c6aa769c87e2d0993a/3]["emacs and git" video tutorial available at the same place]].
The next sections provide information on how to install emacs. Before The next section provides information on how to install emacs.
proceeding, make sure you have read the "Git and GitLab" instructions
(tutorial and resources from the 4th sequence of the 2nd module).
* Installing emacs, org-mode, ess, and auctex. * Installing emacs, org-mode, ess, and auctex.
** Linux (Debian, Ubuntu) ** Linux (Debian, Ubuntu)
...@@ -83,7 +82,7 @@ versions: ...@@ -83,7 +82,7 @@ versions:
- Org-mode 9.1.13 - Org-mode 9.1.13
- ESS 17.11 - ESS 17.11
* A simple "/reproducible research/" emacs configuration * A simple "/reproducible research/" emacs configuration
This section is illustrated in a video tutorial (in French). Watching This section is illustrated in a [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/courseware/66bc811404b8481da5f794de54681c5e/aefd774dcd2342c6aa769c87e2d0993a/3][video tutorial]] (in French). Watching
it before following the instructions given in this section may help. it before following the instructions given in this section may help.
Emacs comes with very basic default configuration and it appears like Emacs comes with very basic default configuration and it appears like
...@@ -159,7 +158,7 @@ backed up in a revision control system like git. We leave it up to set ...@@ -159,7 +158,7 @@ backed up in a revision control system like git. We leave it up to set
this up but if you have any trouble, feel free to ask on the FUN this up but if you have any trouble, feel free to ask on the FUN
forums. forums.
* A stub of replicable article * A stub of replicable article
Remember, you need a working LaTeX and R environment. If you can't Remember, you need a working LaTeX and R environment. If you can't
...@@ -229,16 +228,15 @@ have smart completion in emacs for the most common languages. If you ...@@ -229,16 +228,15 @@ have smart completion in emacs for the most common languages. If you
feel this is needed, you should follow the instructions from the feel this is needed, you should follow the instructions from the
official Web page: http://company-mode.github.io/ official Web page: http://company-mode.github.io/
*** Magit *** Magit
Magit]] is an emacs interface for Git. It is briefly illustrated in a [[https://magit.vc/][Magit]] is an emacs interface for Git. Its usage is briefly illustrated
video tutorial. in the context of this MOOC in a [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/courseware/66bc811404b8481da5f794de54681c5e/aefd774dcd2342c6aa769c87e2d0993a/3][video tutorial]] (in French).
It is very powerful and we use It is very powerful and we use it on a daily basis but you should
it on a daily basis but you should definitely understand what git does definitely understand what git does behind the scene beforehand. If
behind the scene beforehand. If you feel this would be useful for you, you feel this would be useful for you, you should follow [[https://magit.vc/screenshots/][this visual
you should follow the instructions from here: walk-through]] or [[https://www.emacswiki.org/emacs/Magit][this really short "crash course"]]. If you installed the
https://www.emacswiki.org/emacs/Magit. If you installed the previous previous "/reproducible research/" emacs configuration, you can easily
"/reproducible research/" emacs configuration, you can easily invoke invoke magit by using ~C-x g~.
** Other resources ** Other resources
- [[https://orgmode.org/orgguide.pdf][The compact Org-mode Guide]] - [[https://orgmode.org/orgguide.pdf][The compact Org-mode Guide]]
- [[https://github.com/dfeich/org-babel-examples][Many examples illustrating the use of different languages in org-mode]] - [[https://github.com/dfeich/org-babel-examples][Many examples illustrating the use of different languages in org-mode]]
