Learning Lab
c836b14d
Commit
c836b14d
by
Marie-Gabrielle Dondon
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
Cosmetic
parent
67631705
Changes
1
Hide whitespace changes
Inline
Side-by-side
Showing
1 changed file
with
1 addition
and
2 deletions
+1
-2
jupyter.org
module2/ressources/jupyter.org
+1
-2
No files found.
View file @
c836b14d
@@ -44,8 +44,7 @@ Note that this =%%R= notation allows you to use R for the whole cell but
an other possibility is to use =%R= to have a single line of R within a
python cell.
** Exporting a notebook
Obviously, you can convert to html or pdf using the using the =File >
Download as > HTML= (or =PDF=) menu option. This can also be done from
Obviously, you can convert to html or pdf using the using the =File > Download as > HTML= (or =PDF=) menu option. This can also be done from
the command line with the following command:
#+begin_src sh :results output :exports both
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
You are about to add
people
to the discussion. Proceed with caution.
Finish editing this message first!
Please
register
or
sign in
to comment
