Commit cd1c724d authored by Arnaud Legrand's avatar Arnaud Legrand
Regenerate Markdown files with a newer version of pandoc and with correct metadata
parent c2ee844b
This diff is collapsed.
TITLE: Document Examples title: Document Examples
AUTHOR: Arnaud Legrand author: Arnaud Legrand
Date: Wed Mar 20 13:03:17 2019 date: Wed Mar 20 13:03:17 2019
Table of Contents<span class="tag" data-tag-name="TOC"></span> # Table of Contents <span class="tag" data-tag-name="TOC"><span class="smallcaps">TOC</span></span>
- [Examples from the Video](#examples-from-the-video) - [Examples from the Video](#examples-from-the-video)
- [Other examples](#other-examples) - [Other examples](#other-examples)
Examples from the Video # Examples from the Video
In the MOOC video, I quickly demo how org-mode can be used in various contexts. Here are the (sometimes trimmed) corresponding org-files. These documents depend on many other external data files and are not meant to lead to reproducible documents but it will give you an idea of how it can be organized: In the MOOC video, I quickly demo how org-mode can be used in various
1. [journal.org](journal.org): an excerpt (I've only left a few code samples and links to some resources on R, Stats, ...) from my own journal. This is a personal document where everything (meeting notes, hacking, random thoughts, ...) goes by default. Entries are created with the `C-c c` shortcut. 1. [journal.org](journal.org): an excerpt (I've only left a few code
2. [labbook<sub>single</sub>.org](labbook_single.org): this is an excerpt from the laboratory notebook [Tom Cornebize](https://cornebize.net/) wrote during his Master thesis internship under my supervision. This a personal labbook. I consider this notebook to be excellent and was the ideal level of details for us to communicate without any ambiguity and for him to move forward with confidence. samples and links to some resources on R, Stats, …) from my own
3. [paper.org](paper.org): this is an ongoing paper based on the previous labbook of Tom Cornebize. As such it is not reproducible as there are hardcoded paths and uncleaned dependencies but writing it from the labbook was super easy as we just had to cut and paste the parts we needed. What may be interesting is the organization and the org tricks to export to the right LaTeX style. As you may notice, in the end of the document, there is a commented section with emacs commands that are automatically executed when opening the file. It is an effective way to depend less on the `.emacs/init.el` which is generally customized by everyone. journal. This is a personal document where everything (meeting
4. [labbook<sub>several</sub>.org](labbook_several.org): this is a labbook for a specific project shared by several persons. As a consequence it starts with information about installation, common scripts, has section with notes about all our meetings, a section with information about experiments and an other one about analysis. Entries could have been labeled by who wrote them but there were only a few of us and this information was available in git so we did not bother. In such labbook, it is common to find annotations indicating that such experiment was `:FLAWED:` as it had some issues. notes, hacking, random thoughts, …) goes by default. Entries are
5. [technical<sub>report</sub>.org](technical_report.org): this is a short technical document I wrote after a colleague sent me a PDF describing an experiment he was conducting and asked me about how reproducible I felt it was. It turned out I had to cut and paste the C code from the PDF, then remove all the line numbers and fix syntax, etc. Obviously I got quite different performance results but writing everything in org-mode made it very easy to generate both HTML and PDF and to explicitly explain how the measurements were done. created with the `C-c c` shortcut.
with confidence.
issues.
done.
Other examples # Other examples
Here are a few links to other kind of examples: Here are a few links to other kind of examples:
- Slides: all my slides for a series of lectures is available here: <https://github.com/alegrand/SMPE>. Here is a [typical source](https://raw.githubusercontent.com/alegrand/SMPE/master/lectures/lecture_central_limit_theorem.org) and the [resulting PDF](https://raw.githubusercontent.com/alegrand/SMPE/master/lectures/lecture_central_limit_theorem.pdf) - Slides: all my slides for a series of lectures is available here:
- Lucas Schnorr, a colleague, maintains: <https://github.com/alegrand/SMPE>. Here is a [typical
- a set of templates for various computer science journals/conferences: [IEEE](https://github.com/schnorr/ieeeorg), [Wiley](https://github.com/schnorr/wileyorg), [ACM](https://github.com/schnorr/acmorg), [LNCS](https://github.com/schnorr/llncsorg) source](https://raw.githubusercontent.com/alegrand/SMPE/master/lectures/lecture_central_limit_theorem.org)
- his lecture on programming languages for undergrads: <https://github.com/schnorr/mlp/tree/master/conteudo> and the [resulting
- John Kitchin is an expert org-mode user and he maintains a very interesting [blog with many interesting tips](http://kitchingroup.cheme.cmu.edu/blog/). You may want to check this [seminar he gave at SciPy](https://www.youtube.com/watch?v=IsSMs-4GlT8&list=FLQp2VLAOlvq142YN3JO3y8w&app=desktop). PDF](https://raw.githubusercontent.com/alegrand/SMPE/master/lectures/lecture_central_limit_theorem.pdf)
TITLE: Computational Documents title: Computational Documents
Date: Wed Mar 20 13:19:19 2019 date: Wed Mar 20 13:19:19 2019
This document gathers most references mentioned in the videos. This is a rather crude list. This document gathers most references mentioned in the videos. This is a
rather crude
list.
- [M2-S0: Computational Documents](#m2-s0-computational-documents) - [M2-S0: Computational Documents](#m2-s0-computational-documents)
- [M2-S1: A few Recent Controversial Studies](#m2-s1-a-few-recent-controversial-studies) - [M2-S1: A few Recent Controversial
- [Economy: Austerity in Fiscal Policy](#economy-austerity-in-fiscal-policy) Studies](#m2-s1-a-few-recent-controversial-studies)
- [Functional MRI](#functional-mri) - [Economy: Austerity in Fiscal
- [Incorrect Protein Structures](#incorrect-protein-structures) Policy](#economy-austerity-in-fiscal-policy)
- [Other domains](#other-domains) - [Functional MRI](#functional-mri)
- [M2-S2: Why is This so Difficult?](#m2-s2-why-is-this-so-difficult) - [Incorrect Protein Structures](#incorrect-protein-structures)
- [Mistakes](#mistakes) - [Other domains](#other-domains)
- [Going Public?](#going-public) - [M2-S2: Why is This so Difficult?](#m2-s2-why-is-this-so-difficult)
- [M2-S3: Computational Documents: Principles](#m2-s3-computational-documents-principles) - [Mistakes](#mistakes)
- [M2-S5: Collaborating](#m2-s5-collaborating) - [Going Public?](#going-public)
- [Preparing a Document for a Journal or a Conference](#preparing-a-document-for-a-journal-or-a-conference) - [M2-S3: Computational Documents:
- [M2-S6: Comparative Study](#m2-s6-comparative-study) Principles](#m2-s3-computational-documents-principles)
- [Exemples of Org-Mode documents](#exemples-of-org-mode-documents) - [M2-S5: Collaborating](#m2-s5-collaborating)
M2-S0: Computational Documents # M2-S0: Computational Documents
M2-S1: A few Recent Controversial Studies # M2-S1: A few Recent Controversial Studies
Economy: Austerity in Fiscal Policy ## Economy: Austerity in Fiscal Policy
- [Reinhart et Rogoff](https://en.wikipedia.org/wiki/Growth_in_a_Time_of_Debt): *Growth in a Time of Debt* - [Reinhart et
- Herndon, Ash et Pollin Rogoff](https://en.wikipedia.org/wiki/Growth_in_a_Time_of_Debt):
- Wray: combining data across centuries, exchange rate regimes, *Growth in a Time of Debt*
Functional MRI ## Functional MRI
- 2010: [Bennett et al. and the dead salmon](https://www.researchgate.net/publication/255651552_Neural_correlates_of_interspecies_perspective_taking_in_the_post-mortem_Atlantic_Salmon_an_argument_for_multiple_comparisons_correction) ☺ - 2010: [Bennett et al. and the dead
- 2016: [Eklund, Nichols, and Knutsson](http://www.pnas.org/content/113/28/7900.abstract). [A bug in fmri software could invalidate 15 years of brain research](http://www.sciencealert.com/a-bug-in-fmri-software-could-invalidate-decades-of-brain-research-scientists-discover) (*40 000 articles*) salmon](https://www.researchgate.net/publication/255651552_Neural_correlates_of_interspecies_perspective_taking_in_the_post-mortem_Atlantic_Salmon_an_argument_for_multiple_comparisons_correction)
- 2016: But it's [more subtle than it looks like](https://www.cogneurosociety.org/debunking-the-myth-that-fmri-studies-are-invalid/). [Nichols](http://blogs.warwick.ac.uk/nichols/entry/bibliometrics_of_cluster/). *≈ 3 600 impacted studies* ☺
(*40 000 articles*)
Incorrect Protein Structures ## Incorrect Protein Structures
[A "buggy software"](https://people.ligo-wa.caltech.edu/~michael.landry/calibration/S5/getsignright.pdf). [A "buggy
Other domains ## Other domains
- [Oncology](http://www.nature.com/nrd/journal/v10/n9/full/nrd3439-c1.html?foxtrotcallback=true): "*half of published studies, even in prestigious journals, can't be reproduced in industrial labs*" - [Oncology](http://www.nature.com/nrd/journal/v10/n9/full/nrd3439-c1.html?foxtrotcallback=true):
- [Psychology](http://theconversation.com/we-found-only-one-third-of-published-psychology-research-is-reliable-now-what-46596): "*attempting to reproduce 100 previously published findings*, *only one-third of published psychology research was found to be reliable*" "*half of published studies, even in prestigious journals, can't be
labs*"
reliable*"
M2-S2: Why is This so Difficult? # M2-S2: Why is This so Difficult?
Mistakes ## Mistakes
- [Computers broke science](http://theconversation.com/how-computers-broke-science-and-what-we-can-do-to-fix-it-49938) - [Computers broke
- [Programming and data manipulation mistakes in Genomics](https://qz.com/768334/years-of-genomics-research-is-riddled-with-errors-thanks-to-a-bunch-of-botched-excel-spreadsheets/) science](http://theconversation.com/how-computers-broke-science-and-what-we-can-do-to-fix-it-49938)
Going Public? ## Going Public?
- Someone may [benefit from my hard work](http://www.nature.com/news/the-top-100-papers-1.16224) - Someone may [benefit from my hard
M2-S3: Computational Documents: Principles # M2-S3: Computational Documents: Principles
M2-S5: Collaborating # M2-S5: Collaborating
Preparing a Document for a Journal or a Conference ## Preparing a Document for a Journal or a Conference
Requirements for producing a **pdf**: Requirements for producing a **pdf**:
- Internally, *pandoc*, *knitr* or *emacs/org-mode* - Internally, *pandoc*, *knitr* or *emacs/org-mode*
- *LaTeX* should be installed
- <http://blog.juliusschulz.de/blog/ultimate-ipython-notebook> - *LaTeX* should be installed
- <https://github.com/kirbs-/hide_code> is a must-have
- <http://svmiller.com/blog/2016/02/svm-r-markdown-manuscript/> - <http://blog.juliusschulz.de/blog/ultimate-ipython-notebook>
- <https://github.com/balouf/Kleinberg/blob/master/KleinbergsGridSimulator.ipynb> - <https://github.com/kirbs-/hide_code> is a
must-have
M2-S6: Comparative Study # M2-S6: Comparative Study
[Exemples of Org-Mode documents](../ressources/orgmode_examples/README.org) ## [Exemples of Org-Mode documents](../ressources/orgmode_examples/README.org)
Markdown is supported
0% or
You are about to add 0 people to the discussion. Proceed with caution.
Finish editing this message first!
Please register or to comment
