Learning Lab
d8da1106
Commit
d8da1106
by
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
Modif sur le test de l'installation d'emacs
parent
fcd8f222
Changes
1
Hide whitespace changes
Inline
Side-by-side
Showing
1 changed file
with
2 additions
and
2 deletions
+2
-2
emacs_orgmode.org
module2/ressources/emacs_orgmode.org
+2
-2
No files found.
View file @
d8da1106
@@ -266,14 +266,14 @@ quit Emacs (=C-x C-c=, meaning =Ctrl + x= followed by =Ctrl + c=) and
restart it. At worst, repeat this until you get no more errors on
startup.
startup.
Next,
open
a file =foo.org=. Copy the following lines into this file:
Next,
create
: #+begin_src shell :session foo :results output :exports both
: ls -la # or dir under windows
: #+end_src
: #+end_src
Put your cursor inside this code block and execute it with the
following command: =C-c C-c= (If you are not familiar with Emacs
commands, this one means '=Ctrl +
C
=' twice)
c
=' twice)
A =#+RESULTS:= block with the result of the command should appear if it
worked.
worked.
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
You are about to add
people
to the discussion. Proceed with caution.
Finish editing this message first!
Please
register
or
sign in
to comment
