Learning Lab
d96f0eae
Commit
d96f0eae
by
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
Have a single script to handle both org and md conversion
parent
42a2a7dd
Changes
2
Hide whitespace changes
Inline
Side-by-side
Showing
2 changed files
with
35 additions
and
25 deletions
+35
-25
.gitlab-ci.yml
.gitlab-ci.yml
+6
-10
pandoc_fixer.pl
bin/pandoc_fixer.pl
+29
-15
No files found.
.gitlab-ci.yml
View file @
d96f0eae
@@ -3,19 +3,15 @@ pages:
stage
deploy
script
pandoc --version
pandoc --help
- pandoc --help
# - pandoc --list-input-formats # Broken as pandoc dates from 2013 on this image! :(
for file in $(find -name "*.md"); do
pandoc -s -f gfm -t html -o ${file%.*}.html $file && echo "Exported ${file%.*}.html" && echo "<li><a href='https://learninglab.gitlabpages.inria.fr/mooc-rr/mooc-rr-ressources/${file%.*}.html'>${file%.*}.html</a></li>" >> index.html || echo "ERROR $file"
bin/pandoc_fixer.pl ${file} > ${file}.new;
mv ${file
}.new ${file%.*}.html;
$(find -name "*.org")
; do
mkdir -p public/`dirname ${file}`
mv ${file
%.*}.html public/`dirname ${file}`
done
# The next part is broken because pandoc is way too old on this image :(
# - for file in $(find -name "*.org"); do
# pandoc -s -f org -t html -o ${file%.*}.html $file && echo "Exported ${file%.*}.html" || echo "ERROR $file";
# done
shopt -s extglob
mv !(public) public
- mv !(public) public
artifacts
paths
public
bin/pandoc_fixer.pl
View file @
d96f0eae
#!/usr/bin/perl -w
use
strict
if
$#ARGV
die
"Usage: pandox_fixer.pl input.md"
my
$usage
$#ARGV
or
die
$usage
my
$input
shift
@ARGV
if
$input
/.md$/
die
my
$line
########### Git date #################
my
$gitdate
`git log $input | grep Date | head -n 1`
chomp
$gitdate
$gitdate
s/Date: *//g
$gitdate
s/\s*\+.*$//g
$input
s/.md/.html/
########### Input file ###############
my
$type
my
$output
$input
if
$input
/.md$/
$type
"gfm"
$output
s/.md$/.html/
elsif
$input
/.org$/
$type
"org"
$output
s/.org$/.html/
else
die
my
$output_temp
$output
"tmp"
open
INPUT
$input
or
die
########### URL Fixing ###############
my
$input_path
$input
$input_path
s
g
# print $input."\n\n";
my
$url_path
"https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/raw/master/"
$input_path
my
$gitlab_origin
"https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/"
while
defined
$line
INPUT
########### Pandoc #################
print
"Exporting $input\n"
my
$pandoc_output
`LANG=C ; pandoc -s -f $type -t html -o $output_temp $input`
open
INPUT
$output_temp
or
die
open
OUTPUT
$output
or
die
while
defined
my
$line
INPUT
# $line =~ s|https://gitlab.inria.fr/learninglab/|https://learninglab.gitlabpages.inria.fr/|g; ## Not such a good idea!
if
$input
/_fr.html/
$line
s
body
body
Les
a
href
'$gitlab_origin/$input'
sources
de
ce
document
sont
disponibles
sur
gitlab
a
g
@@ -48,6 +62,6 @@ while(defined($line=<INPUT>)) {
# $line = "\t".$line;
if
$line
/<p>AUTHOR:/
next
print
$line
print
OUTPUT
$line
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
You are about to add
people
to the discussion. Proceed with caution.
Finish editing this message first!
Please
register
or
sign in
to comment
