Open the =matplotlibrc= file and modify the line starting with =backend=
to make it =backend : Agg=.
* Python and R
Computational documents contain code, which in the case of our MOOC use the languages Python and R. So you must install Python and R in addition to Emacs, unless of course they are already installed on your computer. Note that when we say Python, we mean the Python 3 language, not its predecessors Python 1 and Python 2, which are similar but not quite compatible. More precisely, the examples in the MOOC require Python 3.6 or later, the current official version being 3.7.3. For R, we have used version 3.4, but somewhat older versions are probably fine as well.
Like for Emacs, there are many ways to install Python and R. Worse, there are good reasons for there being many ways, because there is no single best one for everybody. The following guidelines should help you pick a good one for you.
* Python, R, and LaTeX
Computational documents contain code, which in the case of our MOOC use the languages Python and R. So you must install Python and R in addition to Emacs, unless of course they are already installed on your computer. Since Python and R are also used in the other paths of our MOOC, we explain their installation in a separate resource.
*Linux users* should start by checking the packages provided by their Linux distribution. It almost certainly contains Python and R, but the versions may not be sufficiently recent. For example, Debian 9 (named "stretch"), the current stable release, proposes Python 3.5. The exact names of the packages you need to install unfortunately varies among distributions, but they should be similar to =python3= and =r-base=.
That same resource also explains how to install LaTeX, which you must have if you want to produce PDF versions of org-mode documents. For example, if you want to work with the replicable article stub (shown in [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4][this video]]), you must install LaTeX. However, it is a rather big piece of software (several GB), so you may prefer to skip its installation. It is not required to follow the MOOC.
*macOS* users who already use one of the package managers for macOS, i.e. one of [[https://brew.sh/][Homebrew]], [[https://www.macports.org/][MacPorts]], or [[http://www.finkproject.org/][fink]], should also look for Python and R in their distributions. However, it's not worth installing any of these package managers just for Python and R.
Users of *Windows*, as well as *Linux* and *macOS* users who don't find sufficiently recent versions in their package manager's distributions, should consider the [[https://www.anaconda.com/distribution/][Anaconda distribution]] that contains both Python and R plus a huge collection of add-on packages for both languages. Anaconda is particularly recommended for those who plan to use Python more regularly, as it is the most convenient approach to managing Python environments.
Finally, you can follow the installation procedures proposed by the development teams of [[https://www.python.org/][Python]] and [[https://www.r-project.org/][R]] for their respective languages. Compared to the approaches described above, the main inconvenience is the absence of simple strategies for updating and for installing add-on packages. But if you install Python and/or R just for the MOOC, this is not much of an issue.
* LaTeX (optional)
If you want to work with the replicable article stub (shown in [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4][this video]]), you also need an installation of LaTeX. This is a rather big piece of software (several GB), so you may prefer to skip its installation. It is not required to follow the MOOC, but if you end up producing real-life computational documents with Emacs, you will have to install it eventually.
As for Python and R, *Linux* users, and also *macOS* users with a package manager, should start by checking their distribution's package list for packages called =tex=, =latex=, or better yet =texlive= or =miktex=, the two main TeX distributions that already contain almost everything you are likely to need.
Otherwise, pick one of [[https://tug.org/texlive/][TeX Live]] or [[https://miktex.org/][MiKTeX]] and follow the installation instructions they provide. [[https://www.tug.org/mactex/][MacTeX]] for macOS is TeX Live plus a few macOS-specific add-ons. The differences between MiKTeX and TeX Live are not very important, so if you don't know which one to pick, toss a coin!
* A simple "reproducible research" emacs configuration
This section is illustrated in a [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4][video tutorial]] (/"Mise en place
Emacs/Orgmode"/ in French). Watching it before following the
Computational documents contain code, which in the case of our MOOC use the languages Python and R. If you follow the RStudio or Emacs/Orgmode paths, or if you want to install Jupyter on your own computer, you must install Python and R.
LaTeX is a document typesetting language that is widely used to write scientific articles. We do not use LaTeX directly in this MOOC, but it is used both by Jupyter and Emacs/Orgmode to produce PDF output. LaTeX is a rather big piece of software (a complete installation takes one to five GB), so you may prefer not to install it. That will not prevent you from following the MOOC, you just lose the ability to produce PDF versions of your computational documents.
* Version requirements
For Python, the examples in the MOOC require version 3.6 or later. The current version is 3.7.3. Python 3.6 was released more than two years ago, but older versions are still very common. For example, the current stable release of Debian Linux (Debian 9, named "stretch"), proposes Python 3.5. Make sure you have Python 3.6 or later, if necessary by installing it in addition to an older version you might already have. Note that multiple Python versions co-exist very well on a single computer, but you must be careful to always run the right one.
LaTeX evolves much more slowly, so even a installation that is a few years old should be fine.
* Installation
There are many ways to install Python, R, and LaTeX. Worse, there are good reasons for there being many ways, because there is no single best one for everybody. The following guidelines should help you pick a good one for you.
1. Use a package manager you already have.
*Linux users* should start by checking the packages provided by their Linux distribution. It almost certainly contains Python, R, and LaTeX. Unless you use a very conservative distribution (such as [[https://www.centos.org/][CentOS]]), you can expect to find sufficiently recent versions of R and LaTeX, but for Python, make sure you get 3.6 or later.
The exact names of the packages you need to install unfortunately vary among distributions, but they should be similar to =python3=, =r-base=, and =texlive=.
*macOS* users who already use one of the package managers for macOS, i.e. one of [[https://brew.sh/][Homebrew]], [[https://www.macports.org/][MacPorts]], or [[http://www.finkproject.org/][fink]], should also look for Python and R in their distributions. However, it's probably not worth installing any of these package managers just for Python, R, or LaTeX.
2. Anaconda
Users of *Windows*, as well as *Linux* and *macOS* users who don't find sufficiently recent versions in their package manager's distributions, should consider the [[https://www.anaconda.com/distribution/][Anaconda distribution]] that contains both Python and R plus a huge collection of add-on packages for both languages. Anaconda is particularly recommended for those who plan to use Python more regularly, as it is the most convenient approach to managing Python environments. It is also the method we recommend for a local installation of Jupyter.
3. Follow the instructions proposed by each language's developers
Finally, you can install [[https://www.python.org/][Python]] and [[https://www.r-project.org/][R]] following the installation procedures proposed by their development teams. Compared to the approaches described above, the main inconvenience is the absence of simple strategies for updating and for installing add-on packages. But if you install Python and/or R just for the MOOC, this is not much of an issue.
LaTeX is a bit different because it is already an add-on package to another piece of software called TeX, and then requires additional add-ons to be of practical use. You should therefore use one of [[https://tug.org/texlive/][TeX Live]] or [[https://miktex.org/][MiKTeX]], the two major TeX distributions that come with their own package managers, and follow the installation instructions they provide. [[https://www.tug.org/mactex/][MacTeX]] for macOS is TeX Live plus a few macOS-specific add-ons. The differences between MiKTeX and TeX Live are not very important, so if you don't know which one to pick, toss a coin!
