Learning Lab
f214aeb4
f214aeb4
ajout png + titres anglais
f6462162
3
3 changed files
7 additions
7 deletions
+7
-7
+7
-7
module2/exo5/freq_temp_python.png
+0
module2/exo5/proba_estimate_python.png
+0
f214aeb4
#+TITLE: Analys
e du risque de défaillance des joints toriques de la navette Challenger
#+TITLE: Analys
is of the risk of failure of the O-rings on the Challenger shuttle
@@ -26,12 +26,12 @@ had been performed at this temperature.
The following study therefore takes up some of the analyses carried out in this study
night and whose objective was to assess the potential influence of
the temperature and pressure to which the seals are subjected
toric
s on their probability of malfunction. To do this, we
O-ring
have the results of the experiments carried out by the engineers
of NASA during the 6 years preceding the launch of the shuttle
Chargement des données
Data loading
So we start by loading this data:
@@ -166,9 +166,9 @@ and the standard error of this estimator is 0.122, in other words we
* Estimation of the probability of malfunctioning
toric seal
s
O-ring
s
The expected temperature on take-off day is 31°F. Let's try to
estimate the probability of malfunctioning
toric seal
s at
O-ring
s at
@@ -189,7 +189,7 @@ print(matplot_lib_filename)
toric seal
s. It will be about 0.2, as in the tests
O-ring
where we had a failure of at least one joint. Let's get back to the subject
to the set of initial data to estimate the probability of
failure of a seal:
@@ -213,7 +213,7 @@ tomorrow as planned.
Only the next day, the Challenger shuttle will explode and take away
with her seven crew members. Public opinion is
affected and in the subsequent investigation, the reliability of the
toric seal
s will be directly implicated. Beyond the problems
O-ring
of internal communication at NASA, which have a lot to do with this
fiasco, the previous analysis includes (at least) a small
problem.... Can you find it? You are free to modify this
f214aeb4
f214aeb4
