Learning Lab
f214aeb4
Commit
f214aeb4
by
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
ajout png + titres anglais
parent
f6462162
Changes
3
Hide whitespace changes
Inline
Side-by-side
Showing
3 changed files
with
7 additions
and
7 deletions
+7
-7
exo5_python-en.org
module2/exo5/exo5_python-en.org
+7
-7
module2/exo5/freq_temp_python.png
+0
-0
module2/exo5/proba_estimate_python.png
+0
-0
No files found.
View file @
f214aeb4
#+TITLE: Analys
e du risque de défaillance des joints toriques de la navette Challenger
#+TITLE: Analys
is of the risk of failure of the O-rings on the Challenger shuttle
#+AUTHOR: Arnaud Legrand
#+LANGUAGE: fr
@@ -26,12 +26,12 @@ had been performed at this temperature.
The following study therefore takes up some of the analyses carried out in this study
night and whose objective was to assess the potential influence of
the temperature and pressure to which the seals are subjected
toric
s on their probability of malfunction. To do this, we
O-ring
have the results of the experiments carried out by the engineers
of NASA during the 6 years preceding the launch of the shuttle
Challenger.
Chargement des données
Data loading
So we start by loading this data:
#+begin_src python :results value :session *python* :exports both
import numpy as np
@@ -166,9 +166,9 @@ and the standard error of this estimator is 0.122, in other words we
cannot distinguish any particular impact and we must take our
estimates with caution.
* Estimation of the probability of malfunctioning
toric seal
s
O-ring
s
The expected temperature on take-off day is 31°F. Let's try to
estimate the probability of malfunctioning
toric seal
s at
O-ring
s at
this temperature from the model we just built:
#+begin_src python :results output file :var matplot_lib_filename="proba_estimate_python.png" :exports both :session *python*
@@ -189,7 +189,7 @@ print(matplot_lib_filename)
As expected from the initial data, the
temperature has no significant impact on the probability of failure of the
toric seal
s. It will be about 0.2, as in the tests
O-ring
where we had a failure of at least one joint. Let's get back to the subject
to the set of initial data to estimate the probability of
failure of a seal:
@@ -213,7 +213,7 @@ tomorrow as planned.
Only the next day, the Challenger shuttle will explode and take away
with her seven crew members. Public opinion is
affected and in the subsequent investigation, the reliability of the
toric seal
s will be directly implicated. Beyond the problems
O-ring
of internal communication at NASA, which have a lot to do with this
fiasco, the previous analysis includes (at least) a small
problem.... Can you find it? You are free to modify this
0 → 100644
View file @
f214aeb4
0 → 100644
View file @
f214aeb4
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
You are about to add
people
to the discussion. Proceed with caution.
Finish editing this message first!
Please
register
or
sign in
to comment
