Commit fd17629f authored by Arnaud Legrand's avatar Arnaud Legrand
Regenerate html files for the MOOC.
parent 76acc1b6
...@@ -4,47 +4,47 @@ ...@@ -4,47 +4,47 @@
<h2>Table of Contents</h2> <h2>Table of Contents</h2>
<div id="text-table-of-contents"> <div id="text-table-of-contents">
<ul style="margin:0 0;"> <ul style="margin:0 0;">
<li style="margin-bottom:0;"><a href="#org0620a23">Installing emacs, org-mode, ess, and auctex.</a> <li style="margin-bottom:0;"><a href="#org945f839">Installing emacs, org-mode, ess, and auctex.</a>
<li style="margin-bottom:0;"><a href="#org3c63e2d">Linux (Debian, Ubuntu)</a></li> <li style="margin-bottom:0;"><a href="#orge325516">Linux (Debian, Ubuntu)</a></li>
<li style="margin-bottom:0;"><a href="#orgd341044">macOS</a></li> <li style="margin-bottom:0;"><a href="#org95706b9">macOS</a></li>
<li style="margin-bottom:0;"><a href="#org9f08150">Windows</a> <li style="margin-bottom:0;"><a href="#orgb87390f">Windows</a>
<li style="margin-bottom:0;"><a href="#org627e96b">Directory naming conventions</a></li> <li style="margin-bottom:0;"><a href="#org69f7d5a">Directory naming conventions</a></li>
<li style="margin-bottom:0;"><a href="#org023804e">Making R and Python available to the console</a></li> <li style="margin-bottom:0;"><a href="#orgfe267c7">Making R and Python available to the console</a></li>
<li style="margin-bottom:0;"><a href="#org89abfd4">Installing and configuring Matplotlib (graphic python library)</a></li> <li style="margin-bottom:0;"><a href="#orgc458b5a">Installing and configuring Matplotlib (graphic python library)</a></li>
</ul> </ul>
</li> </li>
<li style="margin-bottom:0;"><a href="#org88182bc">All platforms: pretty code in HTML export</a></li> <li style="margin-bottom:0;"><a href="#org47ff448">All platforms: pretty code in HTML export</a></li>
</ul> </ul>
</li> </li>
<li style="margin-bottom:0;"><a href="#org82a9da6">A simple "<i>reproducible research</i>" emacs configuration</a> <li style="margin-bottom:0;"><a href="#org98a8b7e">A simple "<i>reproducible research</i>" emacs configuration</a>
<li style="margin-bottom:0;"><a href="#orge1f5003">Step 0: Backup and download our configuration</a></li> <li style="margin-bottom:0;"><a href="#orgd0815e9">Step 0: Backup and download our configuration</a></li>
<li style="margin-bottom:0;"><a href="#orgd93d06a">Step 1: Prepare your journal</a></li> <li style="margin-bottom:0;"><a href="#org9008837">Step 1: Prepare your journal</a></li>
<li style="margin-bottom:0;"><a href="#orgc8799c3">Step 2: Set up Emacs configuration</a></li> <li style="margin-bottom:0;"><a href="#orgd3b10f7">Step 2: Set up Emacs configuration</a></li>
<li style="margin-bottom:0;"><a href="#org3a69cf6">Step 3: Adapt the configuration to your specific needs if required</a></li> <li style="margin-bottom:0;"><a href="#org73ef313">Step 3: Adapt the configuration to your specific needs if required</a></li>
<li style="margin-bottom:0;"><a href="#org6e757d6">Step 4: Check whether the installation is working or not</a></li> <li style="margin-bottom:0;"><a href="#orgc85363f">Step 4: Check whether the installation is working or not</a></li>
<li style="margin-bottom:0;"><a href="#org7b5b368">Step 5: Open and play with your journal:</a></li> <li style="margin-bottom:0;"><a href="#orgadd0750">Step 5: Open and play with your journal:</a></li>
</ul> </ul>
</li> </li>
<li style="margin-bottom:0;"><a href="#orgc07c3d5">A stub of a replicable article</a></li> <li style="margin-bottom:0;"><a href="#org7b9442b">A stub of a replicable article</a></li>
<li style="margin-bottom:0;"><a href="#org307cdb9">Emacs tips and tricks</a> <li style="margin-bottom:0;"><a href="#orgdde4be6">Emacs tips and tricks</a>
<li style="margin-bottom:0;"><a href="#orgd5d3ba1">Cheat-sheets</a> <li style="margin-bottom:0;"><a href="#org152ca8a">Cheat-sheets</a>
<li style="margin-bottom:0;"><a href="#org9ae5f18">Emacs</a></li> <li style="margin-bottom:0;"><a href="#org8a94d36">Emacs</a></li>
<li style="margin-bottom:0;"><a href="#org6571d83">Org-mode</a></li> <li style="margin-bottom:0;"><a href="#org1765514">Org-mode</a></li>
</ul> </ul>
</li> </li>
<li style="margin-bottom:0;"><a href="#orgde8cbd9">Video tutorials</a></li> <li style="margin-bottom:0;"><a href="#org4cc7124">Video tutorials</a></li>
<li style="margin-bottom:0;"><a href="#orgcc0edda">Additional useful emacs packages</a> <li style="margin-bottom:0;"><a href="#orgd5c8443">Additional useful emacs packages</a>
<li style="margin-bottom:0;"><a href="#org3b26a95">Company-mode</a></li> <li style="margin-bottom:0;"><a href="#orgb58b5a8">Company-mode</a></li>
<li style="margin-bottom:0;"><a href="#org7fcac5c">Magit</a></li> <li style="margin-bottom:0;"><a href="#orgc20d2e9">Magit</a></li>
</ul> </ul>
</li> </li>
<li style="margin-bottom:0;"><a href="#orgc6ce93f">Other resources</a></li> <li style="margin-bottom:0;"><a href="#org9260c82">Other resources</a></li>
</ul> </ul>
</li> </li>
</ul> </ul>
...@@ -65,13 +65,13 @@ the <a href="https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/ ...@@ -65,13 +65,13 @@ the <a href="https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/
The next section provides information on how to install emacs. The next section provides information on how to install emacs.
</p> </p>
<div id="outline-container-org0620a23" class="outline-2"> <div id="outline-container-org945f839" class="outline-2">
<h2 id="org0620a23">Installing emacs, org-mode, ess, and auctex.</h2> <h2 id="org945f839">Installing emacs, org-mode, ess, and auctex.</h2>
<div class="outline-text-2" id="text-org0620a23"> <div class="outline-text-2" id="text-org945f839">
</div> </div>
<div id="outline-container-org3c63e2d" class="outline-3"> <div id="outline-container-orge325516" class="outline-3">
<h3 id="org3c63e2d">Linux (Debian, Ubuntu)</h3> <h3 id="orge325516">Linux (Debian, Ubuntu)</h3>
<div class="outline-text-3" id="text-org3c63e2d"> <div class="outline-text-3" id="text-orge325516">
<p> <p>
We provide here only instructions for Debian-based distributions. Feel We provide here only instructions for Debian-based distributions. Feel
free to contribute to this document to provide up-to-date information free to contribute to this document to provide up-to-date information
...@@ -133,9 +133,9 @@ which is now deprecated. ...@@ -133,9 +133,9 @@ which is now deprecated.
</p> </p>
</div> </div>
</div> </div>
<div id="outline-container-orgd341044" class="outline-3"> <div id="outline-container-org95706b9" class="outline-3">
<h3 id="orgd341044">macOS</h3> <h3 id="org95706b9">macOS</h3>
<div class="outline-text-3" id="text-orgd341044"> <div class="outline-text-3" id="text-org95706b9">
<p> <p>
<b>Note:</b> macOS comes with a prehistoric command-line-only version of Emacs located at <code>/usr/bin/emacs</code>. It's best to forget about it. <b>Note:</b> macOS comes with a prehistoric command-line-only version of Emacs located at <code>/usr/bin/emacs</code>. It's best to forget about it.
</p> </p>
...@@ -190,9 +190,9 @@ in order to make Emacs accessible directly from <code>/Applications</code>. ...@@ -190,9 +190,9 @@ in order to make Emacs accessible directly from <code>/Applications</code>.
</ul> </ul>
</div> </div>
</div> </div>
<div id="outline-container-org9f08150" class="outline-3"> <div id="outline-container-orgb87390f" class="outline-3">
<h3 id="org9f08150">Windows</h3> <h3 id="orgb87390f">Windows</h3>
<div class="outline-text-3" id="text-org9f08150"> <div class="outline-text-3" id="text-orgb87390f">
<p> <p>
Install the <code>.exe</code> file from <a href="http://vgoulet.act.ulaval.ca/">Vincent Goulet</a>: Install the <code>.exe</code> file from <a href="http://vgoulet.act.ulaval.ca/">Vincent Goulet</a>:
<a href="https://vigou3.gitlab.io/emacs-modified-windows/">https://vigou3.gitlab.io/emacs-modified-windows/</a>. It ships with recent <a href="https://vigou3.gitlab.io/emacs-modified-windows/">https://vigou3.gitlab.io/emacs-modified-windows/</a>. It ships with recent
...@@ -205,9 +205,9 @@ versions: ...@@ -205,9 +205,9 @@ versions:
</ul> </ul>
</div> </div>
<div id="outline-container-org627e96b" class="outline-4"> <div id="outline-container-org69f7d5a" class="outline-4">
<h4 id="org627e96b">Directory naming conventions</h4> <h4 id="org69f7d5a">Directory naming conventions</h4>
<div class="outline-text-4" id="text-org627e96b"> <div class="outline-text-4" id="text-org69f7d5a">
<p> <p>
In the following instructions, we refer to your home In the following instructions, we refer to your home
directory through the (UNIX) <code>~/</code> notation. On Windows, your home directory through the (UNIX) <code>~/</code> notation. On Windows, your home
...@@ -218,9 +218,9 @@ means we are referring to <code>C:\Users\yourname\org</code> (resp. ...@@ -218,9 +218,9 @@ means we are referring to <code>C:\Users\yourname\org</code> (resp.
</p> </p>
</div> </div>
</div> </div>
<div id="outline-container-org023804e" class="outline-4"> <div id="outline-container-orgfe267c7" class="outline-4">
<h4 id="org023804e">Making R and Python available to the console</h4> <h4 id="orgfe267c7">Making R and Python available to the console</h4>
<div class="outline-text-4" id="text-org023804e"> <div class="outline-text-4" id="text-orgfe267c7">
<p> <p>
When running a command, Windows will look for the command in the When running a command, Windows will look for the command in the
directories indicated in the <code>PATH</code> environment variable. If none of directories indicated in the <code>PATH</code> environment variable. If none of
...@@ -237,9 +237,9 @@ explained <a href="http://sametmax.com/ajouter-un-chemin-a-la-variable-denvironn ...@@ -237,9 +237,9 @@ explained <a href="http://sametmax.com/ajouter-un-chemin-a-la-variable-denvironn
</p> </p>
</div> </div>
</div> </div>
<div id="outline-container-org89abfd4" class="outline-4"> <div id="outline-container-orgc458b5a" class="outline-4">
<h4 id="org89abfd4">Installing and configuring Matplotlib (graphic python library)</h4> <h4 id="orgc458b5a">Installing and configuring Matplotlib (graphic python library)</h4>
<div class="outline-text-4" id="text-org89abfd4"> <div class="outline-text-4" id="text-orgc458b5a">
<p> <p>
Open an DOS console and type the following command: Open an DOS console and type the following command:
</p> </p>
...@@ -275,9 +275,9 @@ starting with <code>backend</code>, which amounts to use the default <code>Agg</ ...@@ -275,9 +275,9 @@ starting with <code>backend</code>, which amounts to use the default <code>Agg</
</div> </div>
</div> </div>
<div id="outline-container-org88182bc" class="outline-3"> <div id="outline-container-org47ff448" class="outline-3">
<h3 id="org88182bc">All platforms: pretty code in HTML export</h3> <h3 id="org47ff448">All platforms: pretty code in HTML export</h3>
<div class="outline-text-3" id="text-org88182bc"> <div class="outline-text-3" id="text-org47ff448">
<p> <p>
To have code pretty printing when exporting to HTML, you should To have code pretty printing when exporting to HTML, you should
install the <code>htmlize</code> package, which is done by opening emacs and install the <code>htmlize</code> package, which is done by opening emacs and
...@@ -290,9 +290,9 @@ M-x package-install RET htmlize RET # where M-x means pressing the "Esc" key ...@@ -290,9 +290,9 @@ M-x package-install RET htmlize RET # where M-x means pressing the "Esc" key
</div> </div>
</div> </div>
<div id="outline-container-org82a9da6" class="outline-2"> <div id="outline-container-org98a8b7e" class="outline-2">
<h2 id="org82a9da6">A simple "<i>reproducible research</i>" emacs configuration</h2> <h2 id="org98a8b7e">A simple "<i>reproducible research</i>" emacs configuration</h2>
<div class="outline-text-2" id="text-org82a9da6"> <div class="outline-text-2" id="text-org98a8b7e">
<p> <p>
This section is illustrated in a <a href="https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4">video tutorial</a> (<i>"Mise en place This section is illustrated in a <a href="https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4">video tutorial</a> (<i>"Mise en place
Emacs/Orgmode"</i> in French). Watching it before following the Emacs/Orgmode"</i> in French). Watching it before following the
...@@ -311,14 +311,13 @@ adding a few org-mode specific configurations. ...@@ -311,14 +311,13 @@ adding a few org-mode specific configurations.
</p> </p>
</div> </div>
<div id="outline-container-orge1f5003" class="outline-3"> <div id="outline-container-orgd0815e9" class="outline-3">
<h3 id="orge1f5003">Step 0: Backup and download our configuration</h3> <h3 id="orgd0815e9">Step 0: Backup and download our configuration</h3>
<div class="outline-text-3" id="text-orge1f5003"> <div class="outline-text-3" id="text-orgd0815e9">
<p> <p>
The procedure we propose will wipe your already existing custom Emacs The procedure we propose will wipe your already existing custom Emacs
configuration if you have one. <b>You should thus beforehand make configuration if you have one. <b>You should thus beforehand make a
a backup of <code>~/.emacs</code> and of <code>~/.emacs.d/init.el</code></b> (if these files backup</b> of <code>~/.emacs</code> and of <code>~/.emacs.d/init.el</code> (if these files exist).
exist).
</p> </p>
<p> <p>
...@@ -331,12 +330,15 @@ rr_org/init.el ...@@ -331,12 +330,15 @@ rr_org/init.el
rr_org/journal.org rr_org/journal.org
</pre> </pre>
<p>
Alternatively, <a href="rr_org/">the files you are looking for are available here</a>.
</p>
</div> </div>
</div> </div>
<div id="outline-container-org9008837" class="outline-3">
<div id="outline-container-orgd93d06a" class="outline-3"> <h3 id="org9008837">Step 1: Prepare your journal</h3>
<h3 id="orgd93d06a">Step 1: Prepare your journal</h3> <div class="outline-text-3" id="text-org9008837">
<div class="outline-text-3" id="text-orgd93d06a">
<p> <p>
Create an <code>org/</code> directory in the top of your home: Create an <code>org/</code> directory in the top of your home:
</p> </p>
...@@ -353,9 +355,9 @@ should give a try. ...@@ -353,9 +355,9 @@ should give a try.
</p> </p>
</div> </div>
</div> </div>
<div id="outline-container-orgc8799c3" class="outline-3"> <div id="outline-container-orgd3b10f7" class="outline-3">
<h3 id="orgc8799c3">Step 2: Set up Emacs configuration</h3> <h3 id="orgd3b10f7">Step 2: Set up Emacs configuration</h3>
<div class="outline-text-3" id="text-orgc8799c3"> <div class="outline-text-3" id="text-orgd3b10f7">
<p> <p>
Copy <code>rr_org/init.el</code> in your <code>~/.emacs.d/</code> directory. Copy <code>rr_org/init.el</code> in your <code>~/.emacs.d/</code> directory.
</p> </p>
...@@ -367,9 +369,9 @@ configuration with the following command: <code>emacs -q -l rr_org/init.el</code ...@@ -367,9 +369,9 @@ configuration with the following command: <code>emacs -q -l rr_org/init.el</code
</p> </p>
</div> </div>
</div> </div>
<div id="outline-container-org3a69cf6" class="outline-3"> <div id="outline-container-org73ef313" class="outline-3">
<h3 id="org3a69cf6">Step 3: Adapt the configuration to your specific needs if required</h3> <h3 id="org73ef313">Step 3: Adapt the configuration to your specific needs if required</h3>
<div class="outline-text-3" id="text-org3a69cf6"> <div class="outline-text-3" id="text-org73ef313">
<p> <p>
There are two situations in which it might be necessary to modify There are two situations in which it might be necessary to modify
<code>init.el</code>: <code>init.el</code>:
...@@ -398,9 +400,9 @@ beginning of the file for instructions. ...@@ -398,9 +400,9 @@ beginning of the file for instructions.
</p> </p>
</div> </div>
</div> </div>
<div id="outline-container-org6e757d6" class="outline-3"> <div id="outline-container-orgc85363f" class="outline-3">
<h3 id="org6e757d6">Step 4: Check whether the installation is working or not</h3> <h3 id="orgc85363f">Step 4: Check whether the installation is working or not</h3>
<div class="outline-text-3" id="text-org6e757d6"> <div class="outline-text-3" id="text-orgc85363f">
<p> <p>
Open a new instance of Emacs and open a <code>foo.org</code> file. Copy the Open a new instance of Emacs and open a <code>foo.org</code> file. Copy the
following lines in this file: following lines in this file:
...@@ -431,9 +433,9 @@ is demonstrated in the <a href="https://app-learninglab.inria.fr/gitlab/learning ...@@ -431,9 +433,9 @@ is demonstrated in the <a href="https://app-learninglab.inria.fr/gitlab/learning
</p> </p>
</div> </div>
</div> </div>
<div id="outline-container-org7b5b368" class="outline-3"> <div id="outline-container-orgadd0750" class="outline-3">
<h3 id="org7b5b368">Step 5: Open and play with your journal:</h3> <h3 id="orgadd0750">Step 5: Open and play with your journal:</h3>
<div class="outline-text-3" id="text-org7b5b368"> <div class="outline-text-3" id="text-orgadd0750">
<p> <p>
In step 1, you were told to create an journal in In step 1, you were told to create an journal in
<code>~org/journal.org</code>. First you probably want to make sure this file is <code>~org/journal.org</code>. First you probably want to make sure this file is
...@@ -444,9 +446,9 @@ FUN forums. ...@@ -444,9 +446,9 @@ FUN forums.
</div> </div>
</div> </div>
</div> </div>
<div id="outline-container-orgc07c3d5" class="outline-2"> <div id="outline-container-org7b9442b" class="outline-2">
<h2 id="orgc07c3d5">A stub of a replicable article</h2> <h2 id="org7b9442b">A stub of a replicable article</h2>
<div class="outline-text-2" id="text-orgc07c3d5"> <div class="outline-text-2" id="text-org7b9442b">
<p> <p>
This section is illustrated in a <a href="https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4">video tutorial</a> (<i>"Écrire un article This section is illustrated in a <a href="https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4">video tutorial</a> (<i>"Écrire un article
réplicable avec Emacs/Orgmode"</i> in French). Watching it before réplicable avec Emacs/Orgmode"</i> in French). Watching it before
...@@ -510,22 +512,22 @@ chunk of code when exporting. ...@@ -510,22 +512,22 @@ chunk of code when exporting.
</div> </div>
</div> </div>
<div id="outline-container-org307cdb9" class="outline-2"> <div id="outline-container-orgdde4be6" class="outline-2">
<h2 id="org307cdb9">Emacs tips and tricks</h2> <h2 id="orgdde4be6">Emacs tips and tricks</h2>
<div class="outline-text-2" id="text-org307cdb9"> <div class="outline-text-2" id="text-orgdde4be6">
</div> </div>
<div id="outline-container-orgd5d3ba1" class="outline-3"> <div id="outline-container-org152ca8a" class="outline-3">
<h3 id="orgd5d3ba1">Cheat-sheets</h3> <h3 id="org152ca8a">Cheat-sheets</h3>
<div class="outline-text-3" id="text-orgd5d3ba1"> <div class="outline-text-3" id="text-org152ca8a">
<p> <p>
Learning Emacs and Org-Mode can be difficult as there is an inordinate Learning Emacs and Org-Mode can be difficult as there is an inordinate
amount of shortcuts. Many people have thus come up with amount of shortcuts. Many people have thus come up with
cheat-sheats. Here is a selection in case it helps: cheat-sheats. Here is a selection in case it helps:
</p> </p>
</div> </div>
<div id="outline-container-org9ae5f18" class="outline-4"> <div id="outline-container-org8a94d36" class="outline-4">
<h4 id="org9ae5f18">Emacs</h4> <h4 id="org8a94d36">Emacs</h4>
<div class="outline-text-4" id="text-org9ae5f18"> <div class="outline-text-4" id="text-org8a94d36">
<ul class="org-ul"> <ul class="org-ul">
<li style="margin-bottom:0;"><a href="https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org">Common and step-by-step Emacs shortcuts for our <i>reproducible research</i> configuration</a></li> <li style="margin-bottom:0;"><a href="https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org">Common and step-by-step Emacs shortcuts for our <i>reproducible research</i> configuration</a></li>
<li style="margin-bottom:0;"><a href="https://www.gnu.org/software/emacs/refcards/pdf/refcard.pdf">The official GNU emacs refcard</a></li> <li style="margin-bottom:0;"><a href="https://www.gnu.org/software/emacs/refcards/pdf/refcard.pdf">The official GNU emacs refcard</a></li>
...@@ -534,9 +536,9 @@ cheat-sheats. Here is a selection in case it helps: ...@@ -534,9 +536,9 @@ cheat-sheats. Here is a selection in case it helps:
</ul> </ul>
</div> </div>
</div> </div>
<div id="outline-container-org6571d83" class="outline-4"> <div id="outline-container-org1765514" class="outline-4">
<h4 id="org6571d83">Org-mode</h4> <h4 id="org1765514">Org-mode</h4>
<div class="outline-text-4" id="text-org6571d83"> <div class="outline-text-4" id="text-org1765514">
<li style="margin-bottom:0;"><a href="https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org">Common and step-by-step org-mode shortcuts for our <i>reproducible research</i> configuration</a></li> <li style="margin-bottom:0;"><a href="https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/rr_org/journal.org">Common and step-by-step org-mode shortcuts for our <i>reproducible research</i> configuration</a></li>
<li style="margin-bottom:0;"><a href="https://orgmode.org/worg/orgcard.html">The official org-mode refcard</a></li> <li style="margin-bottom:0;"><a href="https://orgmode.org/worg/orgcard.html">The official org-mode refcard</a></li>
...@@ -545,22 +547,22 @@ cheat-sheats. Here is a selection in case it helps: ...@@ -545,22 +547,22 @@ cheat-sheats. Here is a selection in case it helps:
</div> </div>
</div> </div>
</div> </div>
<div id="outline-container-orgde8cbd9" class="outline-3"> <div id="outline-container-org4cc7124" class="outline-3">
<h3 id="orgde8cbd9">Video tutorials</h3> <h3 id="org4cc7124">Video tutorials</h3>
<div class="outline-text-3" id="text-orgde8cbd9"> <div class="outline-text-3" id="text-org4cc7124">
<p> <p>
For those of you who prefer video explanations, here is a <a href="https://www.youtube.com/playlist?list=PL9KxKa8NpFxIcNQa9js7dQQIHc81b0-Xg">Youtube For those of you who prefer video explanations, here is a <a href="https://www.youtube.com/playlist?list=PL9KxKa8NpFxIcNQa9js7dQQIHc81b0-Xg">Youtube
channel with many step by step emacs tutorials</a>. channel with many step by step emacs tutorials</a>.
</p> </p>
</div> </div>
</div> </div>
<div id="outline-container-orgcc0edda" class="outline-3"> <div id="outline-container-orgd5c8443" class="outline-3">
<h3 id="orgcc0edda">Additional useful emacs packages</h3> <h3 id="orgd5c8443">Additional useful emacs packages</h3>
<div class="outline-text-3" id="text-orgcc0edda"> <div class="outline-text-3" id="text-orgd5c8443">
</div> </div>
<div id="outline-container-org3b26a95" class="outline-4"> <div id="outline-container-orgb58b5a8" class="outline-4">
<h4 id="org3b26a95">Company-mode</h4> <h4 id="orgb58b5a8">Company-mode</h4>
<div class="outline-text-4" id="text-org3b26a95"> <div class="outline-text-4" id="text-orgb58b5a8">
<p> <p>
<a href="http://company-mode.github.io/">Company-mode</a> is a text completion framework for Emacs. It allows to <a href="http://company-mode.github.io/">Company-mode</a> is a text completion framework for Emacs. It allows to
have smart completion in emacs for the most common languages. If you have smart completion in emacs for the most common languages. If you
...@@ -569,9 +571,9 @@ official Web page: <a href="http://company-mode.github.io/">http://company-mode. ...@@ -569,9 +571,9 @@ official Web page: <a href="http://company-mode.github.io/">http://company-mode.
</p> </p>
</div> </div>
</div> </div>
<div id="outline-container-org7fcac5c" class="outline-4"> <div id="outline-container-orgc20d2e9" class="outline-4">
<h4 id="org7fcac5c">Magit</h4> <h4 id="orgc20d2e9">Magit</h4>
<div class="outline-text-4" id="text-org7fcac5c"> <div class="outline-text-4" id="text-orgc20d2e9">
<p> <p>
<a href="https://magit.vc/">Magit</a> is an Emacs interface for Git. Its usage is briefly illustrated <a href="https://magit.vc/">Magit</a> is an Emacs interface for Git. Its usage is briefly illustrated
in the context of this MOOC in a <a href="https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4">video tutorial</a> (<i>"Utilisation in the context of this MOOC in a <a href="https://www.fun-mooc.fr/courses/course-v1:inria+41016+session01bis/jump_to_id/9cfc7500f0ef46d288d2317ec7b037b4">video tutorial</a> (<i>"Utilisation
...@@ -589,9 +591,9 @@ invoke magit by using <code>C-x g</code>. ...@@ -589,9 +591,9 @@ invoke magit by using <code>C-x g</code>.
</div> </div>
</div> </div>
</div> </div>
<div id="outline-container-orgc6ce93f" class="outline-3"> <div id="outline-container-org9260c82" class="outline-3">
<h3 id="orgc6ce93f">Other resources</h3> <h3 id="org9260c82">Other resources</h3>
<div class="outline-text-3" id="text-orgc6ce93f"> <div class="outline-text-3" id="text-org9260c82">
<li style="margin-bottom:0;"><a href="https://orgmode.org/orgguide.pdf">The compact Org-mode Guide</a></li> <li style="margin-bottom:0;"><a href="https://orgmode.org/orgguide.pdf">The compact Org-mode Guide</a></li>
<li style="margin-bottom:0;"><a href="https://github.com/dfeich/org-babel-examples">Many examples illustrating the use of different languages in org-mode</a></li> <li style="margin-bottom:0;"><a href="https://github.com/dfeich/org-babel-examples">Many examples illustrating the use of different languages in org-mode</a></li>
