Commit 5c9dbef1 authored by Arnaud Legrand's avatar Arnaud Legrand
Finally fix the uncertainty of the regressions using the correct method and function calls.
parent d5a4fcff
No preview for this file type
...@@ -59,12 +59,71 @@ rmv <- predict(logistic_reg,list(Temperature=tempv),type="response") ...@@ -59,12 +59,71 @@ rmv <- predict(logistic_reg,list(Temperature=tempv),type="response")
plot(tempv,rmv,type="l",ylim=c(0,1)) plot(tempv,rmv,type="l",ylim=c(0,1))
points(data=data, Malfunction/Count ~ Temperature) points(data=data, Malfunction/Count ~ Temperature)
This figure is very similar to the Figure 4 of Dalal et al. **I have managed to replicate the Figure 4 of the Dalal et al. article.** This figure is very similar to the Figure 4 of Dalal et al. **I have managed to replicate the Figure 4 of the Dalal et al. article.**
Let's try to plot confidence intervals although I am not sure exactly how they are computed. # Confidence on the prediction
Let's try to plot confidence intervals with ggplot2.
```{r, fig.height=3.3}
ggplot(data, aes(y=Malfunction/Count, x=Temperature)) + geom_point(alpha=.2, size = 2, color="blue") +
geom_smooth(method = "glm", method.args = list(family = "binomial"), fullrange=T) +
xlim(30,90) + ylim(0,1) + theme_bw()
Mmmh, I have a warning from ggplot2 indicating *"non-integer #successes in a binomial glm!"*. This seems fishy. Furthermore, this confidence region seems huge... It seems strange to me that the uncertainty grows so large for higher temperatures. And compared to my previous call to glm, I haven't indicated the weight which accounts for the fact that each ratio Malfunction/Count corresponds to Count observations (if someone knows how to do this...). There must be something wrong.
So let's provide the "raw" data to ggplot2.
```{r} ```{r}
ggplot(data, aes(y=Malfunction/Count, x=Temperature)) + geom_point(alpha=.2, size = 2) + data_flat=data.frame()
for(i in 1:nrow(data)) {
temperature = data[i,"Temperature"];
malfunction = data[i,"Malfunction"];
d = data.frame(Temperature=temperature,Malfunction=rep(0,times = data[i,"Count"]))
if(malfunction>0) {
d[1:malfunction, "Malfunction"]=1;
data_flat=rbind(data_flat,d)
dim(data_flat)
str(data_flat)
Let's check whether I obtain the same regression or not:
```{r}
logistic_reg_flat = glm(data=data_flat, Malfunction ~ Temperature, family=binomial(link='logit'))
summary(logistic_reg)
Perfect. The estimates and the standard errors are the same although the Residual deviance is difference since the distance is now measured with respect to each 0/1 measurement and not to ratios. Let's use plot the regression for *data_flat* along with the ratios (*data*).
ggplot(data=data_flat, aes(y=Malfunction, x=Temperature)) +
geom_smooth(method = "glm", method.args = list(family = "binomial"), fullrange=T) + geom_smooth(method = "glm", method.args = list(family = "binomial"), fullrange=T) +
geom_point(data=data, aes(y=Malfunction/Count, x=Temperature),alpha=.2, size = 2, color="blue") +
geom_point(alpha=.5, size = .5) +
xlim(30,90) + ylim(0,1) + theme_bw() xlim(30,90) + ylim(0,1) + theme_bw()
No confidence region was given in the original article. **Let's hope this confidence region estimation is correct.**
This confidence interval seems much more reasonable (in accordance with the data) than the previous one. Let's check whether it corresponds to the prediction obtained when calling directly predict. Obtaining the prediction can be done directly or through the link function.
Here is the "direct" (response) version I used in my very first plot:
```{r}
pred = predict(logistic_reg_flat,list(Temperature=30),type="response",se.fit = T)
pred
The estimated Failure probability for 30° is thus $0.834$. However, the $se.fit$ value seems pretty hard to use as I can obviously not simply add $\pm 2 se.fit$ to $fit$ to compute a confidence interval.
Here is the "link" version:
```{r}
pred_link = predict(logistic_reg_flat,list(Temperature=30),type="link",se.fit = T)
pred_link
logistic_reg$family$linkinv(pred_link$fit)
I recover $0.834$ for the estimated Failure probability at 30°. But now, going through the *linkinv* function, we can use $se.fit$:
```{r}
critval = 1.96
logistic_reg$family$linkinv(c(pred_link$fit-critval*pred_link$se.fit,
pred_link$fit+critval*pred_link$se.fit))
The 95% confidence interval for our estimation is thus [0.163,0.992]. This is what ggplot2 just plotted me. This seems coherent.
**I am now rather confident that I have managed to correctly compute and plot the uncertainty of my prediction.** Let's be honnest, it took me a while. My first attempts were plainly wrong (I didn't know how to do this so I trusted ggplot2, which I was misusing) and did not use the correct statistical method. I also feel confident now because this has been somehow validated by other colleagues but it will be interesting that you collect other kind of plots values that you obtained, that differ and that you would probably have kept if you didn't have a reference to compare to. Please provide us with as many versions as you can.
Markdown is supported
0% or
You are about to add 0 people to the discussion. Proceed with caution.
Finish editing this message first!
Please register or to comment
