Ajout de mon test
parent ba72e4b0
...@@ -88,4 +88,5 @@ Non functional (expected values are $`5.085`$ and $`-0.1156`$) ...@@ -88,4 +88,5 @@ Non functional (expected values are $`5.085`$ and $`-0.1156`$)
| Python | 3.6.4 | matplotlib 2.2.3 numpy 1.15.2 pandas 0.22.0 statsmodel 0.9.0 seaborn 0.8.1 | Jupyter | Windows 10 x64 (build 19042) | Identical | Identical | Identical | Very slightly changed | Slightly shifted upwards at low temperature | [ipynb](https://app-learninglab.inria.fr/moocrr/gitlab/7eba932125d7468e05c00632ef18215f/mooc-rr/blob/master/module4/src_Python3_challenger__1_-Copy1.ipynb) | 7eba932125d7468e05c00632ef18215f | | Python | 3.6.4 | matplotlib 2.2.3 numpy 1.15.2 pandas 0.22.0 statsmodel 0.9.0 seaborn 0.8.1 | Jupyter | Windows 10 x64 (build 19042) | Identical | Identical | Identical | Very slightly changed | Slightly shifted upwards at low temperature | [ipynb](https://app-learninglab.inria.fr/moocrr/gitlab/7eba932125d7468e05c00632ef18215f/mooc-rr/blob/master/module4/src_Python3_challenger__1_-Copy1.ipynb) | 7eba932125d7468e05c00632ef18215f |
| R | 3.6.1 | ggplot2_3.1.1 | Rstudio |Windows >= 8 x64 (build 9200) | Identical | Identical | Identical | Identical | Identical |[Rmd](https://app-learninglab.inria.fr/moocrr/gitlab/36cf6267d1f8856c85d87f0f287ea039/mooc-rr/blob/master/module4/EXO1.Rmd) [Pdf](https://app-learninglab.inria.fr/moocrr/gitlab/36cf6267d1f8856c85d87f0f287ea039/mooc-rr/blob/master/module4/test.pdf) | 36cf6267d1f8856c85d87f0f287ea039 | | R | 3.6.1 | ggplot2_3.1.1 | Rstudio |Windows >= 8 x64 (build 9200) | Identical | Identical | Identical | Identical | Identical |[Rmd](https://app-learninglab.inria.fr/moocrr/gitlab/36cf6267d1f8856c85d87f0f287ea039/mooc-rr/blob/master/module4/EXO1.Rmd) [Pdf](https://app-learninglab.inria.fr/moocrr/gitlab/36cf6267d1f8856c85d87f0f287ea039/mooc-rr/blob/master/module4/test.pdf) | 36cf6267d1f8856c85d87f0f287ea039 |
| Python | 3.6.4 | matplotlib 2.2.3 numpy 1.15.2 pandas 0.22.0 statsmodel 0.9.0 seaborn 0.8.1 | Jupyter | Linux Ubuntu SMP Fri Sep 13 12:02:50 UTC 2019 | Identical | Identical | Identical | Similar | Similar | [ipynb](https://app-learninglab.inria.fr/moocrr/gitlab/2207ee6c4b0763c29ab8f98156e3343c/mooc-rr/blob/master/module4/Module4-exercice1.ipynb) | @2207ee6c4b0763c29ab8f98156e3343c | Python | 3.6.4 | matplotlib 2.2.3 numpy 1.15.2 pandas 0.22.0 statsmodel 0.9.0 seaborn 0.8.1 | Jupyter | Linux Ubuntu SMP Fri Sep 13 12:02:50 UTC 2019 | Identical | Identical | Identical | Similar | Similar | [ipynb](https://app-learninglab.inria.fr/moocrr/gitlab/2207ee6c4b0763c29ab8f98156e3343c/mooc-rr/blob/master/module4/Module4-exercice1.ipynb) | @2207ee6c4b0763c29ab8f98156e3343c
| Python | 3.6.5 | matplotlib 3.1.1 numpy 1.19.1 pandas 1.0.3 statsmodel 0.12.2 seaborn 0.9.0 | Jupyter | MacOS Catalina 10.15.7 | Identical | Identical | Identical | Similar | Similar | [pdf](module4/Module4-exercice1.pdf) | @2207ee6c4b0763c29ab8f98156e3343c | Python | 3.6.5 | matplotlib 3.1.1 numpy 1.19.1 pandas 1.0.3 statsmodel 0.12.2 seaborn 0.9.0 | Jupyter | MacOS Catalina 10.15.7 | Identical | Identical | Identical | Similar | Similar | [pdf](module4/Module4-exercice1.pdf) | @2207ee6c4b0763c29ab8f98156e3343c
\ No newline at end of file | Python | 3.8.11 | matplotlib 3.4.2 numpy 1.20.3 pandas 1.3.3 statsmodel 0.12.2 seaborn 0.11.2 | Jupyter | Windows 10.0.17763 -64 bits | Identical | Identical | Identical | Identical after changes of codes | Similar (display only the center) | [pdf](https://app-learninglab.inria.fr/moocrr/jupyter/user/96941f17518054310dda274f17ef8e5e/files/work/module4/exercice1/src_Python3_challenger.pdf) | 96941f17518054310dda274f17ef8e5e
Markdown is supported
0% or
You are about to add 0 people to the discussion. Proceed with caution.
Finish editing this message first!
Please register or to comment
