00457cfdbb94b4c89e4b2ff8b27dc825
0f90d80d
0f90d80d
Clément Courageux
exo2 and 3
28ea4a3b
6
Expand all
6 changed files
456 additions
13 deletions
+456
-13
module2/exo1/cosxsx.png
+0
toy_document_orgmode_python_fr.html
module2/exo1/toy_document_orgmode_python_fr.html
+11
-11
toy_document_orgmode_python_fr.html~
module2/exo1/toy_document_orgmode_python_fr.html~
+381
data.txt
module2/exo2/data.txt
+1
exercice_python_fr.org
module2/exo2/exercice_python_fr.org
+22
-1
module2/exo3/exercice_python_fr.org
+41
-1
View replaced file @
28ea4a3b
0f90d80d
19 KB
W:
H:
21.9 KB
W:
H:
2-up
Swipe
Onion skin
0f90d80d
@@ -3,7 +3,7 @@
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html
xmlns=
"http://www.w3.org/1999/xhtml"
lang=
"fr"
xml:lang=
"fr"
<head>
<!-- 2020-04-01 Wed 10:
17
20
<meta
http-equiv=
"Content-Type"
content=
"text/html;charset=utf-8"
<meta
name=
"viewport"
content=
"width=device-width, initial-scale=1"
<title>
À propos du calcul de
π
</title>
@@ -273,15 +273,15 @@ for the JavaScript code in this tag.
<h2>
Table des matières
</h2>
<div
id=
"text-table-of-contents"
<ul>
<li><a
href=
"#org
3de6e6c
1. En demandant à la lib maths
</a></li>
<li><a
href=
"#org
833fcbb
2. En utilisant la méthode des aiguilles de Buffon
</a></li>
<li><a
href=
"#org
9658f1f
3. Avec un argument "fréquentiel" de surface
</a></li>
<li><a
href=
"#org
e71b253
</a></li>
<li><a
href=
"#org
16efc18
</a></li>
<li><a
href=
"#org
1c65bd9
</a></li>
</ul>
</div>
</div>
<div
id=
"outline-container-org
3de6e6c
class=
"outline-2"
<h2
id=
"org
3de6e6c
><span
class=
"section-number-2"
</span>
</h2>
<div
id=
e71b253
class=
"outline-2"
<h2
id=
"org
e71b253
><span
class=
"section-number-2"
</span>
</h2>
<div
class=
"outline-text-2"
id=
"text-1"
<p>
Mon ordinateur m'indique que
π
vaut
<i>
approximativement
</i>
@@ -299,8 +299,8 @@ pi
</div>
</div>
<div
id=
833fcbb
class=
"outline-2"
<h2
id=
"org
833fcbb
><span
class=
"section-number-2"
2
</span>
</h2>
<div
id=
16efc18
class=
"outline-2"
<h2
id=
"org
16efc18
><span
class=
"section-number-2"
2
</span>
</h2>
<div
class=
"outline-text-2"
id=
"text-2"
<p>
Mais calculé avec la
<b>
méthode
</b>
des
<a
href=
"https://fr.wikipedia.org/wiki/Aiguille_de_Buffon"
aiguilles de Buffon
</a>
, on obtiendrait comme
@@ -323,8 +323,8 @@ np.random.seed(seed=42)
</div>
</div>
<div
id=
9658f1f
class=
"outline-2"
<h2
id=
"org
9658f1f
><span
class=
"section-number-2"
3
</span>
</h2>
<div
id=
1c65bd9
class=
"outline-2"
<h2
id=
"org
1c65bd9
><span
class=
"section-number-2"
3
</span>
</h2>
<div
class=
"outline-text-2"
id=
"text-3"
<p>
Sinon, une méthode plus simple à comprendre et ne faisant pas intervenir d'appel
@@ -374,7 +374,7 @@ combien de fois, en moyenne, \(X^2+Y^2\) est inférieur à 1 :
<div
id=
"postamble"
class=
"status"
<p
class=
"date"
Date: 01/04/2020
</p>
<p
class=
"author"
Auteur: Clément
</p>
<p
class=
"date"
Created: 2020-04-01 Wed 10:
17
</p>
<p
class=
"date"
20
</p>
<p
class=
"validation"
><a
href=
"http://validator.w3.org/check?uri=referer"
Validate
</a></p>
</div>
</body>
0f90d80d
This diff is collapsed.
0f90d80d
14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0
0f90d80d
@@ -11,7 +11,28 @@
* Quelques explications
data = [14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]
print("Average: "+str(np.average(data)))
print("Std: "+str(np.std(data, ddof=1)))
print("Min: "+str(np.min(data)))
print("Max: "+str(np.max(data)))
print("Median: "+str(np.median(data)))
: Average: 14.113000000000001
: Std: 4.334094455301447
: Min: 2.8
: Max: 23.4
: Median: 14.5
* Quelques explications :noexport:
0f90d80d
@@ -11,7 +11,47 @@
#+begin_src python :results file :session :var matplot_lib_filename=(org-babel-temp-file "figure1" ".png") :exports both
import numpy
x=numpy.linspace(-15,15)
plt.figure(figsize=(10,5))
plt.plot(data)
plt.tight_layout()
[[file:/tmp/babel-AQqtCi/figureR2yZWS.png]]
#+begin_src python :results file :session :var matplot_lib_filename=(org-babel-temp-file "figurehist" ".png") :exports both
import numpy
plt.hist(data, facecolor='blue',alpha=0.5, edgecolor='black')
plt.grid(b='True', linestyle='--')
plt.tight_layout()
[[file:/tmp/babel-AQqtCi/figurehist6XxvCK.png]]
