Update mooc-notes.md
parent b384ae7c
...@@ -9,8 +9,8 @@ we now collectively strieve to make reproductible research. ...@@ -9,8 +9,8 @@ we now collectively strieve to make reproductible research.
Why ? Why ?
- **Legitimacy = reproductibility now** Perhaps in past centuries, legitimacy of the research and truths uncovered came hand in hand with - **Legitimacy = reproductibility now** Perhaps in past centuries, legitimacy of the research and truths uncovered came hand in hand with
- the legitimacy and reputation of scientists that made such discoveries, because there were few of them. Now, legitimacy is about consensus and there cannot - the legitimacy and reputation of scientists that made such discoveries, because there were few of them.
- be consensus if _*others*_ cannot verify your assertions - Now, legitimacy is about consensus and there cannot be consensus if _*others*_ cannot verify your assertions
- **Transparency** A new movement of transparency in science also influences the need for reproductibility - **Transparency** A new movement of transparency in science also influences the need for reproductibility
- **Pragmatism** My own point of view is that, for some research areas, if an experiment or a method is not reproductible then it's not useful - **Pragmatism** My own point of view is that, for some research areas, if an experiment or a method is not reproductible then it's not useful
