Commit 33319110 authored by Alain Leraut's avatar Alain Leraut
HTML seconde version
parent 122fcafb
......@@ -3,7 +3,7 @@
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" lang="fr" xml:lang="fr">
<head>
<!-- 2020-04-20 lun. 18:01 -->
<!-- 2020-04-20 lun. 23:07 -->
<meta http-equiv="Content-Type" content="text/html;charset=utf-8" />
<meta name="viewport" content="width=device-width, initial-scale=1" />
<title>À propos du calcul de π</title>
......@@ -232,6 +232,28 @@ for the JavaScript code in this tag.
</script>
<script type="text/x-mathjax-config">
MathJax.Hub.Config({
displayAlign: "center",
displayIndent: "0em",
"HTML-CSS": { scale: 100,
linebreaks: { automatic: "false" },
webFont: "TeX"
SVG: {scale: 100,
font: "TeX"},
NativeMML: {scale: 100},
TeX: { equationNumbers: {autoNumber: "AMS"},
MultLineWidth: "85%",
TagSide: "right",
TagIndent: ".8em"
</script>
<script type="text/javascript"
src="https://cdnjs.cloudflare.com/ajax/libs/mathjax/2.7.0/MathJax.js?config=TeX-AMS_HTML"></script>
</head>
<body>
<div id="content">
......@@ -240,16 +262,15 @@ for the JavaScript code in this tag.
<h2>Table des matières</h2>
<div id="text-table-of-contents">
<ul>
<li><a href="#orgd10738e">1. En demandant à la lib maths</a></li>
<li><a href="#org50a725d">2. En utilisant la méthode des aiguilles de Buffon</a></li>
<li><a href="#org7d95588">3. Avec un argument "fréquentiel" de surface</a></li>
<li><a href="#orgd450129">1. En demandant à la lib maths</a></li>
<li><a href="#org47c49f1">2. En utilisant la méthode des aiguilles de Buffon</a></li>
<li><a href="#org8fa2318">3. Avec un argument "fréquentiel" de surface</a></li>
</ul>
</div>
</div>
<div id="outline-container-orgd10738e" class="outline-2">
<h2 id="orgd10738e"><span class="section-number-2">1</span> En demandant à la lib maths</h2>
<div id="outline-container-orgd450129" class="outline-2">
<h2 id="orgd450129"><span class="section-number-2">1</span> En demandant à la lib maths</h2>
<div class="outline-text-2" id="text-1">
<p>
Mon ordinateur m'indique que π vaut approximativement:
......@@ -267,12 +288,12 @@ Mon ordinateur m'indique que π vaut approximativement:
</div>
</div>
<div id="outline-container-org50a725d" class="outline-2">
<h2 id="org50a725d"><span class="section-number-2">2</span> En utilisant la méthode des aiguilles de Buffon</h2>
<div id="outline-container-org47c49f1" class="outline-2">
<h2 id="org47c49f1"><span class="section-number-2">2</span> En utilisant la méthode des aiguilles de Buffon</h2>
<div class="outline-text-2" id="text-2">
<p>
Mais calculé avec la méthode des aiguilles de Buffon, on obtiendrait
comme approximation :
Mais calculé avec la <b>méthode</b> des <a href="https://fr.wikipedia.org/wiki/Aiguille_de_Buffon">aiguilles de Buffon</a>, on obtiendrait
comme <b>approximation</b> :
</p>
<div class="org-src-container">
......@@ -292,14 +313,14 @@ np.random.seed(seed=42)
</pre>
</div>
</div>
<div id="outline-container-org7d95588" class="outline-2">
<h2 id="org7d95588"><span class="section-number-2">3</span> Avec un argument "fréquentiel" de surface</h2>
<div id="outline-container-org8fa2318" class="outline-2">
<h2 id="org8fa2318"><span class="section-number-2">3</span> Avec un argument "fréquentiel" de surface</h2>
<div class="outline-text-2" id="text-3">
<p>
Sinon, une méthode plus simple à comprendre et ne faisant pas
intervenir d'appel à la fonction sinus se base sur le fait que si
X∼U(0,1) et Y∼U(0,1) alors P[X2+Y2≤1]=π/4 (voir méthode de Monte
Carlo sur Wikipedia). Le code suivant illustre ce fait :
\(X∼U(0,1) et Y∼U(0,1) \) alors \( P[X2+Y2≤1]=π/4 \) (voir
<a href="https://fr.wikipedia.org/wiki/M%C3%A9thode_de_Monte-Carlo#D%C3%A9termination_de_la_valeur_de_%CF%80">méthode de Monte Carlo</a> sur Wikipedia). Le code suivant illustre ce fait :
</p>
......@@ -324,14 +345,13 @@ plt.savefig(matplot_lib_filename)
<div class="figure">
<p><img src="./valeurpip.png" alt="valeurpip.png" />
<p><img src="./valeurpi.png" alt="valeurpi.png" />
</p>
</div>
<p>
Il est alors aisé d'obtenir une approximation (pas terrible) de π en
comptant combien de fois, en moyenne, X2+Y2 est inférieur à 1 :
Il est alors aisé d'obtenir une approximation (pas terrible) de π en comptant combien de fois, en moyenne, \(X2+Y2\) est inférieur à 1 :
</p>
......@@ -351,12 +371,16 @@ Auteur: Konrad Hinsen
<p>
Created: 2019-03-28 Thu 11:06
</p>
<p>
<a href="http://validator.w3.org/check?uri=referer">Validate</a>
</p>
</div>
</div>
</div>
<div id="postamble" class="status">
<p class="author">Auteur: Leraut Alain</p>
<p class="date">Created: 2020-04-20 lun. 18:01</p>
<p class="date">Created: 2020-04-20 lun. 23:07</p>
<p class="validation"><a href="http://validator.w3.org/check?uri=referer">Validate</a></p>
</div>
</body>
#+TITLE: Votre titre
#+AUTHOR: Votre nom
#+DATE: La date du jour
#+TITLE: À propos du calcul de π
#+AUTHOR: Leraut Alain
......@@ -11,83 +10,72 @@
* Quelques explications
document.
print("Hello world!")
* En demandant à la lib maths
from math import *
print(pi)
: Hello world!
~C-c C-c~).
* En utilisant la méthode des aiguilles de Buffon
import numpy
x=numpy.linspace(-15,15)
print(x)
N = 10000
valeur = 2/(sum((x+np.sin(theta))>1)/N)
print(valeur)
: 3.128911138923655
* Avec un argument "fréquentiel" de surface
#+begin_src python :results output file :session :var matplot_lib_filename="./valeurpip.png" :exports both
N = 1000
plt.figure(figsize=(10,5))
plt.plot(x,numpy.cos(x)/x)
plt.tight_layout()
accept = (x*x+y*y) <= 1
fig, ax = plt.subplots(1)
ax.set_aspect('equal')
[[file:./cosxsx.png]]
compréhensible sur GitLab.
[[file:./valeurpip.png]]
print('{:1.13f}'.format(4*np.mean(accept)))
: 3.1120000000000
