kk
parent 42877cc6
"cells": [
"execution_count": 3,
"execution_count": 2,
......@@ -21,7 +36,9 @@
"execution_count": 4,
"scrolled": false
......@@ -43,6 +60,14 @@
"execution_count": 5,
......@@ -79,6 +104,34 @@
"ax.set_aspect('equal')"
"execution_count": 6,
"ename": "NameError",
"evalue": "name 'accept' is not defined",
"output_type": "error",
"traceback": [
"\u001b[0;31mNameError\u001b[0m Traceback (most recent call last)",
"\u001b[0;32m<ipython-input-6-b03d6d9f8ffa>\u001b[0m in \u001b[0;36m<module>\u001b[0;34m\u001b[0m\n\u001b[0;32m----> 1\u001b[0;31m \u001b[0;36m4\u001b[0m\u001b[0;34m*\u001b[0m\u001b[0mnp\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mmean\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0maccept\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m",
"\u001b[0;31mNameError\u001b[0m: name 'accept' is not defined"
"4*np.mean(accept)"
"execution_count": null,
......@@ -92,18 +145,6 @@
"display_name": "Python 3",
"language": "python",
"name": "python3"
"language_info": {
"codemirror_mode": {
"name": "ipython",
"version": 3
"file_extension": ".py",
"mimetype": "text/x-python",
"name": "python",
"pygments_lexer": "ipython3",
"version": "3.6.4"
"nbformat": 4,
