Replace toy_notebook_en.ipynb
parent cbbca545
......@@ -9,9 +9,7 @@
"hideCode": false
"## Asking the maths library\n",
......@@ -20,11 +18,7 @@
"execution_count": 1,
"hideCode": false,
"hidePrompt": false,
"scrolled": true
......@@ -41,9 +35,7 @@
"hidePrompt": false
"## Buffon's needle\n",
"Applying the method of [Buffon's needle](https://en.wikipedia.org/wiki/Buffon%27s_needle_problem), we get the __approximation__"
......@@ -52,11 +44,7 @@
"execution_count": 2,
"hideCode": false,
"scrolled": true
......@@ -65,10 +53,7 @@
"hideCode": false,
......@@ -83,9 +68,7 @@
"hideCode": false
"A method that is easier to understand and does not make use of the $\\sin$ function is based on the fact that if $X\\sim U(0,1)$ and $Y\\sim U(0,1)$, then $P[X^2+Y^2\\leq 1] = \\pi/4$ (see [\"Monte Carlo method\" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:"
......@@ -94,7 +77,9 @@
"execution_count": 3,
"scrolled": true
