Update toy_document_en.Rmd
parent f619a48d
...@@ -11,14 +11,14 @@ knitr::opts_chunk$set(echo = TRUE) ...@@ -11,14 +11,14 @@ knitr::opts_chunk$set(echo = TRUE)
## Asking the maths library ## Asking the maths library
My computer tells me that $\pi$ is approximatively My computer tells me that $\pi$ is *approximatively*
```{r} ```{r}
pi pi
## Buffons needle ## Buffon's needle
Applying the method of [Buffon’s needle](https://en.wikipedia.org/wiki/Buffon%27s_needle_problem), we get the approximation Applying the method of [Buffon's needle](https://en.wikipedia.org/wiki/Buffon%27s_needle_problem), we get the **approximation**
```{r} ```{r}
set.seed(42) set.seed(42)
...@@ -30,7 +30,7 @@ theta = pi/2*runif(N) ...@@ -30,7 +30,7 @@ theta = pi/2*runif(N)
## Using a surface fraction argument ## Using a surface fraction argument
A method that is easier to understand and does not make use of the $\sin$ function is based on the fact that if $X\sim U(0,1)$ and $Y\sim U(0,1)$, then $P[X^2+Y^2\leq 1]=\pi /4$ (see [“Monte Carlo method” on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach: A method that is easier to understand and does not make use of the $\sin$ function is based on the fact that if $X\sim U(0,1)$ and $Y\sim U(0,1)$, then $P[X^2+Y^2\leq 1]=\pi /4$ (see ["Monte Carlo method" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:
```{r} ```{r}
