A few spaces changes to make it identical
parent 70e108ea
...@@ -71,12 +71,12 @@ ...@@ -71,12 +71,12 @@
"source": [ "source": [
"## Using a surface fraction argument\n", "## Using a surface fraction argument\n",
"A method that is easier to understand and does not make use of the $\\sin$ function is based on the fact that if $X\\sim U(0, 1)$ and $Y\\sim U(0, 1)$, then $P[X^2+Y^2\\leq 1] = \\pi/4$ (see [\"Monte Carlo method\" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:" "A method that is easier to understand and does not make use of the $\\sin$ function is based on the fact that if $X\\sim U(0,1)$ and $Y\\sim U(0,1)$, then $P[X^2+Y^2\\leq 1] = \\pi/4$ (see [\"Monte Carlo method\" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:"
"execution_count": 9, "execution_count": 11,
"outputs": [ "outputs": [
...@@ -93,7 +93,7 @@ ...@@ -93,7 +93,7 @@
"%matplotlib inline\n", "%matplotlib inline \n",
"import matplotlib.pyplot as plt\n", "import matplotlib.pyplot as plt\n",
"\n", "\n",
"np.random.seed(seed=42)\n", "np.random.seed(seed=42)\n",
