Learning Lab
038bcec6
Commit
038bcec6
by
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
A few information on tracking dependency in python and R
parent
6399576d
Changes
1
Hide whitespace changes
Inline
Side-by-side
Showing
1 changed file
with
194 additions
and
0 deletions
+194
-0
resources.org
module4/ressources/resources.org
+194
-0
No files found.
0 → 100644
View file @
038bcec6
mode
org
TITLE
AUTHOR
Arnaud
Legrand
DATE
June
2018
STARTUP
overview
indent
OPTIONS
num
nil
toc
t
PROPERTY
header
args
eval
never
export
Getting
information
about
Python
3
libraries
Getting
the
list
of
installed
packages
and
their
version
https
stackoverflow
com
questions
20180543
how
to
check
version
of
python
modules
begin_src
shell
results
output
exports
both
pip3
freeze
end_src
RESULTS
begin_example
asn1crypto
0.24.0
attrs
17.4.0
bcrypt
3.1.4
beautifulsoup4
4.6.0
bleach
2.1.3
pandas
0.22.0
pandocfilters
1.4.2
paramiko
2.4.0
patsy
0.5.0
pexpect
4.2.1
traitlets
4.3.2
tzlocal
1.5.1
urllib3
1.22
wcwidth
0.1.7
webencodings
0.5
end_example
begin_src
shell
results
output
exports
both
pip3
show
pandas
echo
pip3
show
statsmodels
end_src
RESULTS
begin_example
Name
pandas
Version
0.22.0
Summary
Powerful
data
structures
for
data
analysis
time
series
and
statistics
Home
page
http
pandas
pydata
org
Author
None
Author
email
None
License
BSD
Location
usr
lib
python3
dist
packages
Requires
Name
statsmodels
Version
0.9.0
Summary
Statistical
computations
and
models
for
Python
Home
page
http
www
statsmodels
org
Author
None
Author
email
None
License
BSD
License
Location
home
alegrand
local
lib
python3
.6
site
packages
Requires
patsy
pandas
end_example
begin_src
python
results
output
exports
both
end_src
How
to
list
imported
modules
Inspiring
from
https
stackoverflow
com
questions
4858100
how
to
list
imported
modules
StackOverflow
here
is
a
simple
function
that
lists
loaded
package
that
have
a
__version__
attribute
which
is
unfortunately
not
completely
standard
begin_src
python
results
output
exports
both
def
print_imported_modules
import
sys
for
name
val
in
sys
modules
items
if
hasattr
val
'__version__'
print
val
__name__
val
__version__
print
"**** Package list in the beginning ****"
print
"**** Package list after loading pandas ****"
import
pandas
end_src
RESULTS
begin_example
Package
list
in
the
beginning
Package
list
after
loading
pandas
pandas
0.22.0
numpy
1.14.5
numpy
lib
1.14.5
numpy
core
1.14.5
numpy
core
multiarray
3.1
numpy
core
umath
b
'0.4.0'
re
2.2.1
ctypes
1.1.0
_ctypes
1.1.0
logging
0.5.1.2
argparse
1.1
zlib
1.0
numpy
linalg
_umath_linalg
b
'0.1.5'
decimal
1.70
decimal
1.70
pytz
2018.5
dateutil
2.7.3
distutils
3.6.5
rc1
platform
1.0.8
ipaddress
1.0
six
1.11.0
json
2.0.9
csv
1.0
_csv
1.0
urllib
request
3.6
matplotlib
2.1.1
pyparsing
2.2.0
cycler
0.10.0
_libjson
1.33
end_example
Setting
up
an
environment
with
pip
The
easiest
way
to
go
is
as
follows
begin_src
shell
results
output
exports
both
pip3
freeze
requirements
txt
to
obtain
the
list
of
packages
with
their
version
pip3
install
r
requirements
txt
to
install
the
previous
list
of
packages
possibly
on
an
other
machine
end_src
If
you
want
to
have
several
installed
python
environments
you
may
want
to
use
https
docs
pipenv
org
Pipenv
I
doubt
it
allows
to
track
correctly
FORTRAN
or
C
dynamic
libraries
that
are
wrapped
by
Python
Getting
information
about
R
libraries
The
best
way
seems
to
be
to
rely
on
the
devtools
package
begin_src
R
results
output
session
R
exports
both
sessionInfo
devtools
session_info
end_src
RESULTS
begin_example
R
version
3.5.1
2018
07
02
Platform
x86_64
pc
linux
gnu
64
bit
Running
under
Debian
GNU
Linux
buster
sid
Matrix
products
default
BLAS
usr
lib
x86_64
linux
gnu
blas
libblas
so
.3.8.0
LAPACK
usr
lib
x86_64
linux
gnu
lapack
liblapack
so
.3.8.0
locale
1
LC_CTYPE
fr_FR
UTF
8
LC_NUMERIC
C
3
LC_TIME
fr_FR
UTF
8
LC_COLLATE
fr_FR
UTF
8
5
LC_MONETARY
fr_FR
UTF
8
LC_MESSAGES
fr_FR
UTF
8
7
LC_PAPER
fr_FR
UTF
8
LC_NAME
C
9
LC_ADDRESS
C
LC_TELEPHONE
C
11
LC_MEASUREMENT
fr_FR
UTF
8
LC_IDENTIFICATION
C
attached
base
packages
1
stats
graphics
grDevices
utils
datasets
methods
base
loaded
via
a
namespace
and
not
attached
1
compiler_3
.5.1
Session
info
setting
value
version
R
version
3.5.1
2018
07
02
system
x86_64
linux
gnu
ui
X11
language
EN
collate
fr_FR
UTF
8
tz
Europe
Paris
date
2018
08
01
Packages
package
version
date
source
base
3.5.1
2018
07
02
local
compiler
3.5.1
2018
07
02
local
datasets
3.5.1
2018
07
02
local
devtools
1.13.6
2018
06
27
CRAN
R
3.5.1
digest
0.6.15
2018
01
28
CRAN
R
3.5.0
graphics
3.5.1
2018
07
02
local
grDevices
3.5.1
2018
07
02
local
memoise
1.1.0
2017
04
21
CRAN
R
3.5.1
methods
3.5.1
2018
07
02
local
stats
3.5.1
2018
07
02
local
utils
3.5.1
2018
07
02
local
withr
2.1.2
2018
03
15
CRAN
R
3.5.0
end_example
Some
actually
advocate
that
https
github
com
ropensci
rrrpkg
writing
a
reproducible
research
compendium
can
be
done
by
writing
an
R
package
Those
of
you
willing
to
have
a
clean
R
dependency
management
should
thus
have
a
look
at
https
rstudio
github
io
packrat
Packrat
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
You are about to add
people
to the discussion. Proceed with caution.
Finish editing this message first!
Please
register
or
sign in
to comment
