Commit 39443083 authored by Arnaud Legrand's avatar Arnaud Legrand
[HTML] Move all the grunt work to perl and produce a nice looking index
parent 0b07a331
......@@ -5,14 +5,11 @@ pages:
- pandoc --version
# - pandoc --help
# - pandoc --list-input-formats # Broken as pandoc dates from 2013 on this image! :(
- bin/pandoc_fixer.pl html_src_files.lst;
- for file in `cat html_src_files.lst | sed 's/#.*//g' `; do
bin/pandoc_fixer.pl ${file};
echo "Creating" public/`dirname ${file}`;
mkdir -p public/`dirname ${file}`;
mv ${file%.*}.html public/`dirname ${file}`/;
done
- cat html_src_files.lst | sed -e 's|\.md |.html |' -e 's|\.org |\.html |' -e 's|^./\([^ ]*\) *# *\([^ ]*\)|- [[./\1]] (\2)|' > index.org
- pandoc -s -f org -t html -o public/index.html index.org
- cd module2/ressources/; tar zcf rr_org_archive.tgz rr_org/init.el rr_org/journal.org rr_org/init.org ; cd ../.. ; mv module2/ressources/rr_org_archive.tgz public/module2/ressources/
- cd module2/ressources/; make -C replicable_article/ all ../replicable_article.tgz ; cd ../.. ; mv module2/ressources/replicable_article.tgz public/module2/ressources/
artifacts:
#!/usr/bin/perl -w
use strict;
my($usage) = "Usage: pandox_fixer.pl input.md";
my($usage) = "Usage: pandox_fixer.pl org_md_files.lst";
($#ARGV==0) or die $usage;
my($input)=shift(@ARGV);
########### Git date #################
my($gitdate)=`git log --date=short $input | grep Date | head -n 1`;
chomp($gitdate);
$gitdate =~ s/Date: *//g;
$gitdate =~ s/\s*\+.*$//g;
########### Input file ###############
my($type) = "";
my($output) = $input;
if($input =~ /.md$/) {
$type = "gfm";
$output =~ s/.md$/.html/;
} elsif ($input =~ /.org$/) {
$type = "org";
$output =~ s/.org$/.html/;
} else {
die "Usage: pandox_fixer.pl input.md";
my($output_temp) = $output."tmp";
########### URL Fixing ###############
my($input_path)=$input;
$input_path =~ s|/[^/]*$||g;
my($raw_path) = "https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/raw/master/".$input_path;
my($raw_path_percent) = $raw_path; $raw_path_percent =~ s/^http/%/g;
my($tree_path) = "https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/tree/master/".$input_path;
my($pages_path) = "https://learninglab.gitlabpages.inria.fr/mooc-rr/mooc-rr-ressources/".$input_path;
my($pages_path_percent) = $pages_path; $pages_path_percent =~ s/^http/%/g;
my($gitlab_origin)= "https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/";
########### Pandoc #################
print "Exporting $input\n";
my($pandoc_output) = `LANG=C ; pandoc -s --mathjax -f $type -t html -o $output_temp $input`;open INPUT, $output_temp or die;
open OUTPUT, "> ".$output or die;
while(defined(my $line=<INPUT>)) {
if($line =~ /<p class="author"/) { next; }
if($line =~ /<h1 class="title"/) { next; }
if($line =~ /<p class="date"/) { next; }
if($line =~ /<p>.*broken-links:nil/) { next; }
# $line =~ s|https://gitlab.inria.fr/learninglab/|https://learninglab.gitlabpages.inria.fr/|g; ## Not such a good idea!
if($line =~ /<body>/) {
if($output=~ /_fr.html/) {
$line =~ s|<body>|<body>Les <a href='$gitlab_origin/$input'>sources de ce document sont disponibles sur gitlab</a>.|g;
$line .= "<br><i>Version du $gitdate.</i><br><hr/>\n"
} else {
$line =~ s|<body>|<body>The <a href='$gitlab_origin/$input'>source of this document is available on gitlab</a>.|g;
$line .= "<br><i>Last version: $gitdate</i><br><hr/>\n"
sub pandoc_export {
my($input)=shift(@_);
chomp($gitdate);
my($type) = "";
$type = "gfm";
$type = "org";
} else {
$line =~ s|<span class="smallcaps">TOC</span>||g;
} else {
$line =~ s|---</p>|<hr/>|g;
# $line =~ s|Date:.*<br|<i>Date: $gitdate</i><br|g;
# $line =~ s|<p>TITLE:\(.*\)<br|<b>TITLE:$1</b><br|g;
#### Processing links to images, org files, archives, ...
$line =~ s|img src="http|img src="%|g;
$line =~ s|img src="([^%][^"]*)"|img src="$raw_path/$1"|g; # ?inline=false
$line =~ s|img src="%|img src="http|g;
$line =~ s|href="http|href="%|g;
$line =~ s|href="([^%#][^"]*.tgz)"|href="$pages_path_percent/$1"|g;
$line =~ s|href="([^%#][^"]*)"|href="$tree_path/$1"|g; # ?inline=false
$line =~ s|href="%|href="http|g;
# if($line =~ /img src="([^%][^"]*)"/) {
# $line = "\t".$line;
#### Changing headers
foreach my $i (4,3,2,1) {
my($j)=$i+1;
$line =~ s|<h$i|<h$j|g;
$line =~ s|</h$i|</h$j|g;
print OUTPUT $line;
close OUTPUT;
close INPUT;
unlink($output_temp);
my($j)=$i+1;
sub main() {
my($input_list)=shift(@ARGV);
open LIST, $input_list or die;
open INDEX, "> public/index.org" or die;
my($f);
print INDEX "| Gitlab Origin | Pandoc HTML (Gitlab pages) | FUN Outcome |
|---+---+---|\n";
while(defined($f = <LIST>)) {
chomp($f);
if($f =~ /^\s*$/) {
print INDEX "|---+---+---|\n";
next;
my($file,$url) = split(/\s*#\s*/,$f);
if($file eq "" || !defined($url)) { warn "Malformed line"; next;}
# print "'$file' --- '$url'\n";
# pandoc_export($file);
my($html)=$file; $html=~ s/\.[^\.]*$/.html/g;
my($url_id) = $url; $url_id =~ s|^.*jump_to_id/||g;
print INDEX "| [[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/tree/master/$file][$file]] | [[$html]] | [[$url][$url_id]] |\n";
print OUTPUT $line;
close INDEX;
close LIST;
my($pandoc_output) = `LANG=C ; pandoc -s -c http://www.pirilampo.org/styles/readtheorg/css/readtheorg.css -f org -t html -o public/index.html public/index.org`;
close OUTPUT;
close INPUT;
main()
......@@ -13,14 +13,11 @@ pages:
- pandoc --version
# - pandoc --help
done
artifacts:
......@@ -117,115 +114,3 @@ chmod +x ./gitlab-ci.sh
./gitlab-ci.sh
pandoc 2.2.1
Compiled with pandoc-types 1.17.5.1, texmath 0.11.1, skylighting 0.7.5
Default user data directory: /home/alegrand/.pandoc
Copyright (C) 2006-2018 John MacFarlane
Web: http://pandoc.org
This is free software; see the source for copying conditions.
There is no warranty, not even for merchantability or fitness
for a particular purpose.
Exporting ./module2/ressources/maintaining_a_journal.org
Creating public/./module2/ressources
Exporting ./module2/ressources/jupyter_fr.org
Exporting ./module2/ressources/rstudio_fr.org
Exporting ./module2/ressources/gitlab_fr.org
Exporting ./module2/ressources/emacs_orgmode_fr.org
Exporting ./module2/ressources/jupyter.org
Exporting ./module2/ressources/emacs_orgmode.org
Exporting ./module2/ressources/maintaining_a_journal_fr.org
Exporting ./module2/ressources/rstudio.org
Exporting ./module2/ressources/gitlab.org
Exporting ./module2/ressources/orgmode_examples/README.org
Creating public/./module2/ressources/orgmode_examples
Exporting ./module2/ressources/orgmode_examples/README_fr.org
Exporting ./module2/exo4/stat_activity.org
Creating public/./module2/exo4
Exporting ./module2/slides/ressources_fr.org
Creating public/./module2/slides
Exporting ./module2/slides/ressources.org
Exporting ./module3/ressources/iso_date_format.org
Creating public/./module3/ressources
Exporting ./module3/ressources/iso_date_format_fr.org
Exporting ./module3/ressources/influenza-like-illness-analysis-orgmode+R.org
Exporting ./module3/ressources/influenza-like-illness-analysis-orgmode+Lisp+Python+R.org
Exporting ./module3/ressources/influenza-like-illness-analysis-orgmode.org
Exporting ./module3/ressources/analyse-syndrome-grippal-orgmode.org
Exporting ./module3/ressources/analyse-syndrome-grippal-orgmode+R.org
Exporting ./module3/ressources/analyse-syndrome-grippal-orgmode+Lisp+Python+R.org
Exporting ./module1/ressources/Module1_1_MaterielSupplementaire_fr.org
Creating public/./module1/ressources
Exporting ./module1/ressources/Module1_2_MaterielSupplementaire_fr.org
Exporting ./module1/ressources/Module1_3_MaterielSupplementaire_fr.org
Exporting ./module1/ressources/Module1_5_MaterielSupplementaire_fr.org
Exporting ./module1/ressources/Module1_1_SupplementaryMaterial.org
Exporting ./module1/ressources/Module1_2_SupplementaryMaterial.org
Exporting ./module1/ressources/introduction_to_markdown_fr.org
Exporting ./module1/ressources/introduction_to_markdown.org
Exporting ./module1/ressources/module1_supplementary_material.org
Exporting ./module1/ressources/module1_additionalRessources.md
Exporting ./module1/ressources/sequence3_fr.org
Exporting ./module1/ressources/sequence5_fr.org
Exporting ./module1/ressources/sequence2_fr.org
Exporting ./module1/ressources/sequence1_fr.org
Exporting ./module4/ressources/resources_refs.org
Creating public/./module4/ressources
Exporting ./module4/ressources/resources_refs_fr.org
Exporting ./module4/ressources/exo1.org
Exporting ./module4/ressources/exo2.org
Exporting ./module4/ressources/exo3.org
Exporting ./module4/ressources/resources_environment.org
Exporting ./module4/ressources/resources_environment_fr.org
Exporting ./documents/notebooks/notebook_RStudio_SASmarkdown.md
Creating public/./documents/notebooks
Exporting ./documents/tuto_git_gtlab/tuto_git_gitlab.md
Creating public/./documents/tuto_git_gtlab
Exporting ./documents/tuto_rstudio_gitlab/tuto_rstudio_gitlab.md
Creating public/./documents/tuto_rstudio_gitlab
Exporting ./documents/tuto_magit/tuto_magit.md
Creating public/./documents/tuto_magit
Exporting ./documents/tuto_emacs_windows/tuto_emacs_windows.md
Creating public/./documents/tuto_emacs_windows
Exporting ./documents/tuto_jupyter_windows/tuto_jupyter_windows.md
Creating public/./documents/tuto_jupyter_windows
