Learning Lab
3e994b61
Commit
3e994b61
by
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
Move the introduction to magit by Marie-Gabrielle to our own documention
parent
04ceed10
Changes
2
Hide whitespace changes
Inline
Side-by-side
Showing
2 changed files
with
27 additions
and
4 deletions
+27
-4
emacs_orgmode.org
module2/ressources/emacs_orgmode.org
+27
-4
module2/ressources/emacs_orgmode_images/git1.png
+0
-0
No files found.
View file @
3e994b61
@@ -352,12 +352,35 @@ in the context of this MOOC in a [[https://www.fun-mooc.fr/courses/course-v1:inr
It is very powerful and we use it on a daily basis but you should
definitely understand what git does behind the scenes beforehand. If
you feel this would be useful for you, you should follow [[https://magit.vc/screenshots/][this visual
walk-through]] or [[https://www.emacswiki.org/emacs/Magit][this really short "crash course"]]. If you installed the
previous "/reproducible research/" emacs configuration, you can easily
invoke magit by using ~C-x g~.
If you installed the previous "/reproducible research/" emacs
configuration, you can easily invoke magit by using ~C-x g~. Magit will
then prompt you for the path of your local clone of the git repository
(the path to mooc-rr in the context of this MOOC).
[[file:emacs_orgmode_images/git1.png]]
If you do not rely on our "/reproducible research/" emacs configuration,
you should have a look at [[https://magit.vc/manual/magit/Installing-from-an-Elpa-Archive.html][how to install magit from an ELPA archive]].
The following method has been tested with Windows and worked like a charm:
- Add the following piece of text in your =.emacs.d/init.el= file:
#+begin_src emacs-lisp
(require 'package)
(add-to-list 'package-archives
'("melpa" . "http://melpa.org/packages/") t)
#+end_src
- Launch Emacs and run the following commands:
#+BEGIN_EXAMPLE
M-x package-refresh-contents RET
M-x package-install RET magit RET
#+END_EXAMPLE
NB: =M-= corresponds to the =<Alt>= key and =RET= corresponds to the
=<Return>= key.
** Other resources
- [[https://orgmode.org/orgguide.pdf][The compact Org-mode Guide]]
- A huge res
s
ource of emacs/org-mode magic is Bernt Hansen's «[[http://doc.norang.ca/org-mode.html][Organize
- A huge resource of emacs/org-mode magic is Bernt Hansen's «[[http://doc.norang.ca/org-mode.html][Organize
your life in plain text]]», whose source is obviously itself an
[[http://doc.norang.ca/org-mode.org][org-mode document]].
- [[https://github.com/dfeich/org-babel-examples][Many examples illustrating the use of different languages in
0 → 100755
View file @
3e994b61
12.9 KB
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
You are about to add
people
to the discussion. Proceed with caution.
Finish editing this message first!
Please
register
or
sign in
to comment
