@@ -172,16 +172,16 @@ command (alternatively, it uses =curl=). Once downloaded, you may still read the
source ([[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.org][article.org]]) and understand how it works though.
#+begin_src shell :results output :exports none
make -C replicable_article/ all replicable_article.tgz
make -C replicable_article/ all ../replicable_article.tgz
#+end_src
#+RESULTS:
Download the following [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/raw/master/module2/ressources/replicable_article/replicable_article.tgz][archive]], uncompress it and simply =make= to generate the
Download the following [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/raw/master/module2/ressources/replicable_article.tgz][archive]], uncompress it and simply =make= to generate the
article. You should then be able to open the [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.pdf][resulting article]]. This
