Commit 783fdc03 authored by Arnaud Legrand's avatar Arnaud Legrand
Move this archive to a "better" location
parent 2e8b1da1
......@@ -172,16 +172,16 @@ command (alternatively, it uses =curl=). Once downloaded, you may still read the
source ([[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.org][article.org]]) and understand how it works though.
#+begin_src shell :results output :exports none
make -C replicable_article/ all replicable_article.tgz
make -C replicable_article/ all ../replicable_article.tgz
Download the following [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/raw/master/module2/ressources/replicable_article/replicable_article.tgz][archive]], uncompress it and simply =make= to generate the
Download the following [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/raw/master/module2/ressources/replicable_article.tgz][archive]], uncompress it and simply =make= to generate the
article. You should then be able to open the [[https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.pdf][resulting article]]. This
is summarized in the following command:
#+begin_src sh :results output :exports both
wget --no-check-certificate -O replicable_article.tgz https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/raw/master/module2/ressources/replicable_article/replicable_article.tgz
wget --no-check-certificate -O replicable_article.tgz https://app-learninglab.inria.fr/gitlab/learning-lab/mooc-rr-ressources/raw/master/module2/ressources/replicable_article.tgz
tar zxf replicable_article.tgz; cd replicable_article; make ; evince article.pdf
......@@ -15,7 +15,7 @@ all: article.pdf
%.html: %.org
emacs -q -batch --eval "(setq enable-local-eval t)" --eval "(setq enable-local-variables t)" $^ --funcall org-html-export-to-html
$(ARCHIVE).tgz: $(ARCHIVE_FILES)
../$(ARCHIVE).tgz: $(ARCHIVE_FILES)
tar --xform "s|^|$(ARCHIVE)/|" -zcf $@ $^
clean:
