Learning Lab
7a76e677
7a76e677
Update gitlab.org
Modif des liens vers les ressources associées à RStudio et Org-mode
6d3c433a
2 additions
2 deletions
+2
-2
gitlab.org
module2/ressources/gitlab.org
+2
-2
7a76e677
@@ -187,9 +187,9 @@ This section describes a generic (through the command line) way to
synchronize your local files with Gitlab. You will not need this if
you follow the Jupyter path. If you follow the RStudio path, all
these operations can be done through RStudio and you may want to read
file:rstudio.org
][the corresponding instructions]]. If you follow the Org-Mode path, all
/jump_to_id/1a4f58a1efed437c93a9f5c5f15df428
these operations can be done through Magit and you may want to read
file:emacs_orgmode.org
/jump_to_id/508299f7373449a3939faa5b11462bc4
Here are other ways to learn Git through the command line:
- The [[http://swcarpentry.github.io/git-novice/][Software Carpentry git tutorial]]
