Learning Lab
7b693302
Commit
7b693302
by
Marie-Gabrielle Dondon
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
typo + ajout balises #+BEGIN_CENTER, #+END_CENTER manquantes
parent
a007cab3
Changes
1
Hide whitespace changes
Inline
Side-by-side
Showing
1 changed file
with
18 additions
and
6 deletions
+18
-6
gitlab.org
module2/ressources/gitlab.org
+18
-6
No files found.
View file @
7b693302
@@ -200,7 +200,9 @@ Here are other ways to learn Git through the command line:
Now, let's start!
Now, let's start!
1. Obtain the repository URL
#+BEGIN_CENTER
[[file:rstudio_images/adresse_depot.png]]
#+END_CENTER
2. Cloning the repository
#+begin_src shell :results output :exports both
cd /the/directory/where/you/want/to/clone/your/repository
@@ -226,47 +228,57 @@ Now, let's start!
GitLab. The =git status= will indicate you whether files are
tracked/modified/committed/...
Let's assume you just created a
`fichier.txt`
file on the top of
=fichier.txt=
file on the top of
the =mooc-rr= directory.
git status
git status
#+end_src
#+end_src
#+BEGIN_CENTER
[[file:gitlab_images/status1.png]]
#+END_CENTER
git add fichier.txt
git add fichier.txt
git status
git status
#+end_src
#+end_src
#+BEGIN_CENTER
[[file:gitlab_images/status2.png]]
#+END_CENTER
git commit -m "message commit"
#+end_src
#+end_src
#+BEGIN_CENTER
[[file:gitlab_images/commit_git.png]]
#+END_CENTER
git status
git status
#+end_src
#+end_src
#+BEGIN_CENTER
[[file:gitlab_images/status3.png]]
#+END_CENTER
The file can then be transfered to GitLab:
git push
git push
#+end_src
#+end_src
At this point, git will as you about your login/password unless
k
you followed the previous /Remembering your password locally/ instructions.
N.B.: you will not be allowed to propagate your modifications to
GitLab if other modifications (e.g., from someone else) have been
propagated in between
#+BEGIN_CENTER
[[file:gitlab_images/rejected.png]]
#+END_CENTER
5. Synchronizing from Gitlab: to avoid the previous problem, you need
to fetch the remote GitLab modifications first and apply them
locally.
locally.
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
You are about to add
people
to the discussion. Proceed with caution.
Finish editing this message first!
Please
register
or
sign in
to comment
