Learning Lab
a6cf5d88
Commit
a6cf5d88
by
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
Clarify what is important and clearly mark tutorial/video as TODO
parent
574fd836
Changes
1
Hide whitespace changes
Inline
Side-by-side
Showing
1 changed file
with
16 additions
and
2 deletions
+16
-2
emacs_orgmode.org
module2/ressources/emacs_orgmode.org
+16
-2
No files found.
View file @
a6cf5d88
@@ -4,6 +4,12 @@
#+DATE: June, 2018
#+STARTUP: overview indent
#+OPTIONS: num:nil toc:t
#+PROPERTY: header-args :eval never-export
*Disclaimer:* The two sections _A simple "/reproducible research/"
emacs configuration_ and _A stub of replicable article_ explain how to
set up org-mode for this MOOC. *You really should follow them
carefully or you may have trouble doing the exercices later on*.
* Installing emacs, org-mode, ess, and auctex.
** OS-specific installation procedure
@@ -71,7 +77,11 @@ versions:
- Emacs 26.1
- Org-mode 9.1.13
- ESS 17.11
** A simple "/reproducible research/" emacs configuration
** TODO A simple "/reproducible research/" emacs configuration
#+BEGIN_QUOTE
There will be a mini video illustrating these steps at some point
#+END_QUOTE
Emacs comes with very basic default configuration and it appears like
everyone has its own taste. You will for example find [[https://www.emacswiki.org/emacs/StarterKits][here]] several
default Emacs configurations that reflect the preferences of their
@@ -144,7 +154,11 @@ In step 1, you were told to create an journal in
backed up in a revision control system like git. We leave it up to set
this up but if you have any trouble, feel free to ask on the FUN
forums.
** A stub of replicable article
** TODO A stub of replicable article
#+BEGIN_QUOTE
#+END_QUOTE
Remember, you need a working LaTeX and R environment. If you can't
open a terminal and run the commands =R=, =pdflatex=, and =python=, you will not be
able to generate this document. When being compiled, the article downloads the
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
You are about to add
people
to the discussion. Proceed with caution.
Finish editing this message first!
Please
register
or
sign in
to comment
