Commit a9f144f4 authored by brospars's avatar brospars
Jupyter installation guide : add python version
parent f4f3b55f
...@@ -61,7 +61,7 @@ taste. ...@@ -61,7 +61,7 @@ taste.
** Installing jupyter ** Installing jupyter
Follow these instructions if you wish to have a similar Jupyter environment on you own machine. Follow these instructions if you wish to have a similar Jupyter environment on you own machine.
First, download and install [[https://conda.io/miniconda.html][Miniconda latest version]]. We use Miniconda version =4.5.4= on our server .\\ First, download and install [[https://conda.io/miniconda.html][Miniconda latest version]]. We use Miniconda version =4.5.4= and Python version =3.6= on our server .\\
Miniconda is a light version of Anaconda which includes Python, the Jupyter Notebook, and other commonly used packages for scientific computing and data science. Miniconda is a light version of Anaconda which includes Python, the Jupyter Notebook, and other commonly used packages for scientific computing and data science.
Then download the [[https://gist.github.com/brospars/4671d9013f0d99e1c961482dab533c57][mooc_rr environment file]] and create it using conda: Then download the [[https://gist.github.com/brospars/4671d9013f0d99e1c961482dab533c57][mooc_rr environment file]] and create it using conda:
Markdown is supported
0% or
You are about to add 0 people to the discussion. Proceed with caution.
Finish editing this message first!
Please register or to comment
