Commit f4f3b55f authored by Arnaud Legrand's avatar Arnaud Legrand
Regenerate files
parent 1d29e1ab
......@@ -4,31 +4,31 @@
<h2>Table of Contents</h2>
<div id="text-table-of-contents">
<ul style="margin:0 0;">
<li style="margin-bottom:0;"><a href="#org8a3ae34">Additional Jupyter resources or tricks</a>
<li style="margin-bottom:0;"><a href="#org5cd0680">Additional Jupyter resources or tricks</a>
<li style="margin-bottom:0;"><a href="#org15943e2">Tips and tricks</a></li>
<li style="margin-bottom:0;"><a href="#orgf113d02">Running R and Python in the same notebook</a></li>
<li style="margin-bottom:0;"><a href="#org2ba4a8a">Exporting a notebook</a></li>
<li style="margin-bottom:0;"><a href="#org7fc56ab">Tips and tricks</a></li>
<li style="margin-bottom:0;"><a href="#org85c1748">Running R and Python in the same notebook</a></li>
<li style="margin-bottom:0;"><a href="#orgc80dcea">Exporting a notebook</a></li>
</ul>
</li>
<li style="margin-bottom:0;"><a href="#org97a2d04">Installing Jupyter on your own machine</a>
<li style="margin-bottom:0;"><a href="#orgfcddd6d">Installing Jupyter on your own machine</a>
<li style="margin-bottom:0;"><a href="#org9e75391">Installing jupyter</a></li>
<li style="margin-bottom:0;"><a href="#orgf9ac059">Exporting your notebooks with latex</a></li>
<li style="margin-bottom:0;"><a href="#org01b32de">Interesting extensions to improve notebook readability</a></li>
<li style="margin-bottom:0;"><a href="#org3eb7e0c">Installing jupyter</a></li>
<li style="margin-bottom:0;"><a href="#org807e282">Exporting your notebooks with latex</a></li>
<li style="margin-bottom:0;"><a href="#org0359fd8">Interesting extensions to improve notebook readability</a></li>
</ul>
</li>
</ul>
</div>
</div>
<div id="outline-container-org8a3ae34" class="outline-2">
<h2 id="org8a3ae34">Additional Jupyter resources or tricks</h2>
<div class="outline-text-2" id="text-org8a3ae34">
<div id="outline-container-org5cd0680" class="outline-2">
<h2 id="org5cd0680">Additional Jupyter resources or tricks</h2>
<div class="outline-text-2" id="text-org5cd0680">
</div>
<div id="outline-container-org15943e2" class="outline-3">
<h3 id="org15943e2">Tips and tricks</h3>
<div class="outline-text-3" id="text-org15943e2">
<div id="outline-container-org7fc56ab" class="outline-3">
<h3 id="org7fc56ab">Tips and tricks</h3>
<div class="outline-text-3" id="text-org7fc56ab">
<p>
The following <a href="https://www.dataquest.io/blog/jupyter-notebook-tips-tricks-shortcuts/">webpage</a> lists several Jupyter tricks (in particular, it
illustrates many <code>Ipython magic</code> commands) that should improve your
......@@ -38,9 +38,9 @@ now).
</p>
</div>
</div>
<div id="outline-container-orgf113d02" class="outline-3">
<h3 id="orgf113d02">Running R and Python in the same notebook</h3>
<div class="outline-text-3" id="text-orgf113d02">
<div id="outline-container-org85c1748" class="outline-3">
<h3 id="org85c1748">Running R and Python in the same notebook</h3>
<div class="outline-text-3" id="text-org85c1748">
<p>
The best solution to this is to install rpy2. On my machine, I have
installed the <code>python3-rpy2</code> debian package with <code>apt-get install</code>. E.g.,
......@@ -88,9 +88,9 @@ plot(df)
</ol>
</div>
</div>
<div id="outline-container-org2ba4a8a" class="outline-3">
<h3 id="org2ba4a8a">Exporting a notebook</h3>
<div class="outline-text-3" id="text-org2ba4a8a">
<div id="outline-container-orgc80dcea" class="outline-3">
<h3 id="orgc80dcea">Exporting a notebook</h3>
<div class="outline-text-3" id="text-orgc80dcea">
<p>
Obviously, you can convert to html or pdf using the using the <code>File &gt;
Download as &gt; HTML</code> (or <code>PDF</code>) menu option. This can also be done from
......@@ -117,20 +117,20 @@ taste.
</div>
</div>
</div>
<div id="outline-container-org97a2d04" class="outline-2">
<h2 id="org97a2d04">Installing Jupyter on your own machine</h2>
<div class="outline-text-2" id="text-org97a2d04">
<div id="outline-container-orgfcddd6d" class="outline-2">
<h2 id="orgfcddd6d">Installing Jupyter on your own machine</h2>
<div class="outline-text-2" id="text-orgfcddd6d">
</div>
<div id="outline-container-org9e75391" class="outline-3">
<h3 id="org9e75391">Installing jupyter</h3>
<div class="outline-text-3" id="text-org9e75391">
<div id="outline-container-org3eb7e0c" class="outline-3">
<h3 id="org3eb7e0c">Installing jupyter</h3>
<div class="outline-text-3" id="text-org3eb7e0c">
<p>
Follow these instructions if you wish to have a similar Jupyter environment on you own machine.
</p>
<p>
First, download and install <a href="https://www.anaconda.com/download/">Anaconda latest version</a>. We use Anaconda version <code>4.5.4</code> on our server .<br />
Anaconda includes Python, the Jupyter Notebook, and other commonly used packages for scientific computing and data science.
First, download and install <a href="https://conda.io/miniconda.html">Miniconda latest version</a>. We use Miniconda version <code>4.5.4</code> on our server .<br />
Miniconda is a light version of Anaconda which includes Python, the Jupyter Notebook, and other commonly used packages for scientific computing and data science.
</p>
<p>
......@@ -151,9 +151,9 @@ jupyter notebook
</div>
</div>
<div id="outline-container-orgf9ac059" class="outline-3">
<h3 id="orgf9ac059">Exporting your notebooks with latex</h3>
<div class="outline-text-3" id="text-orgf9ac059">
<div id="outline-container-org807e282" class="outline-3">
<h3 id="org807e282">Exporting your notebooks with latex</h3>
<div class="outline-text-3" id="text-org807e282">
<p>
Here is what I had to install on my recent debian machine to make sure
the notebook export via latex works:
......@@ -166,9 +166,9 @@ sudo apt-get install texlive-xetex
</div>
</div>
<div id="outline-container-org01b32de" class="outline-3">
<h3 id="org01b32de">Interesting extensions to improve notebook readability</h3>
<div class="outline-text-3" id="text-org01b32de">
<div id="outline-container-org0359fd8" class="outline-3">
<h3 id="org0359fd8">Interesting extensions to improve notebook readability</h3>
<div class="outline-text-3" id="text-org0359fd8">
<p>
Here are two interesting extensions that can improve readability:
</p>
Markdown is supported
0% or
You are about to add 0 people to the discussion. Proceed with caution.
Finish editing this message first!
Please register or to comment
