Learning Lab
b896f9f5
b896f9f5
Regenerate toc...
9ee8b220
8 additions
8 deletions
+8
-8
emacs_orgmode.org
module2/ressources/emacs_orgmode.org
+8
-8
b896f9f5
@@ -17,18 +17,18 @@ the [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id
The next section provides information on how to install emacs.
* Table of Contents :TOC:
- [[#installing-emacs
-org-mode-ess-and-auctex][Installing emacs, org-mode, ess, and auctex.
][Installing Emacs
- [[#linux-debian-ubuntu][Linux (Debian, Ubuntu)]]
- [[#macos][macOS]]
- [[#windows][Windows]]
- [[#all-platforms-pretty-code-in-html-export][All platforms: pretty code in HTML export]]
- [[#a-simple-reproducible-research-emacs-configuration][A simple "reproducible research" emacs configuration]]
- [[#step-0-backup-and-download-our-configuration][Step 0: Backup and download our configuration]]
- [[#step-1-prepare-your-journal][Step 1: Prepare your journal]]
- [[#step-2-set-up-emacs-configuration][Step 2: Set up Emacs configuration]]
- [[#step-3-adapt-the-configuration-to-your-specific-needs-if-required][Step 3: Adapt the configuration to your specific needs if required]]
- [[#step-4-check-whether-the-installation-is-working-or-not][Step 4: Check whether the installation is working or not]]
- [[#step-5-open-and-play-with-your-journal][Step 5: Open and play with your journal:]]
- [[#step-0-backup-and-remove-your-previous-configuration][Step 0: Backup and remove your previous configuration]]
- [[#step-1-download-our-configuration][Step 1: Download our configuration]]
- [[#step-2-prepare-your-journal][Step 2: Prepare your journal]]
- [[#step-3-put-the-emacs-configuration-file-in-the-right-place][Step 3: Put the Emacs configuration file in the right place]]
- [[#step-4-adapt-the-configuration-to-your-specific-needs-if-required][Step 4: Adapt the configuration to your specific needs if required]]
- [[#step-5-check-whether-the-installation-is-working-or-not][Step 5: Check whether the installation is working or not]]
- [[#step-6-open-and-play-with-your-journal][Step 6: Open and play with your journal:]]
- [[#a-stub-of-a-replicable-article][A stub of a replicable article]]
- [[#emacs-tips-and-tricks][Emacs tips and tricks]]
- [[#cheat-sheets][Cheat-sheets]]
