Commit d7d9a6dd authored by Arnaud Legrand's avatar Arnaud Legrand
Add minor comments
parent 1f8a5678
...@@ -68,8 +68,19 @@ git push ...@@ -68,8 +68,19 @@ git push
#+BEGIN_EXAMPLE #+BEGIN_EXAMPLE
[master 514fe2c1 ] Completing the section on getting Git information [master 514fe2c1 ] Completing the section on getting Git information
1 file changed, 61 insertions(+) 1 file changed, 61 insertions(+)
Counting objects: 25, done.
Delta compression using up to 4 threads.
Compressing objects: 100% (20/20), done.
Writing objects: 100% (25/25), 7.31 KiB | 499.00 KiB/s, done.
Total 25 (delta 11), reused 0 (delta 0)
To ssh://app-learninglab.inria.fr:9418/learning-lab/mooc-rr-ressources.git
6359f8c..1f8a567 master -> master
#+END_EXAMPLE #+END_EXAMPLE
Obviously, in this case you need to save the notebook before running
this cell, hence the output of this final command (with the new git
hash) will not be stored in the cell. This is not really a problem and
is the price to pay for running git from within the notebook itself.
* Getting information about Python(3) libraries * Getting information about Python(3) libraries
** Getting the list of installed packages and their version ** Getting the list of installed packages and their version
https://stackoverflow.com/questions/20180543/how-to-check-version-of-python-modules https://stackoverflow.com/questions/20180543/how-to-check-version-of-python-modules
Markdown is supported
0% or
You are about to add 0 people to the discussion. Proceed with caution.
Finish editing this message first!
Please register or to comment
