@@ -293,48 +293,27 @@ This section is illustrated in a [[https://www.fun-mooc.fr/courses/course-v1:inr
réplicable avec Emacs/Orgmode"/ in French). Watching it before
following the instructions given in this section may help.
Remember, you need a working LaTeX and R environment. If you can't
To work with this article stub, you need working installations of LaTeX, R, and Python. If you can't open a terminal and run the commands =R=, =pdflatex=, and =python3=, you will not be able to generate this document. When being compiled, the article downloads the corresponding LaTeX packages, so you must have a working network connection.
open a terminal and run the commands =R=, =pdflatex=, and =python=, you will not be
Note for macOS users: Since the article is compiled using =make=, you need to put the Emacs executable on your shell's search path, as explained above under [[*Advanced topics - not required for following the MOOC][advanced topics]].
corresponding LaTeX packages so you also need to have a working =wget=
command (alternatively, it uses =curl=). Once downloaded, you may still read the
source ([[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.org]]) and understand how it works though.
#+begin_src shell :results output :exports none
make -C replicable_article/ all ../replicable_article.tgz
Download the following [[file:replicable_article.tgz][archive]], uncompress it and simply =make= to generate the
Download the following [[file:replicable_article.tgz][archive]] and uncompress it. The archive contains the compiled article, so you can start by looking at it.
article. You should then be able to open the [[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.pdf][resulting article]]. This
is summarized in the following command:
To rebuild the article, delete =article.pdf=, or rename it to something else. Otherwise the rebuild procedure will simply tell you that the article is already up to date. Then type =make= to build everything from scratch. Open the freshly built =article.pdf= to see if it looks OK.
tar zxf replicable_article.tgz; cd replicable_article; make ; evince article.pdf
*Possible issues*:
If you get tired of always re-executing all the source code when exporting, look for the following line in [[file:replicable_article/article.org][article.org]]:
- If the =make= command fails (especially on Mac), it may be because
Emacs or something else is not correctly installed. In that case,
open the article directly with the following command:
and export it to pdf with the following shortcut: =C-c C-e l o=
- If it still doesn't work and emacs complains about not finding ESS,
it may be because you installed ESS in your home instead of
system-wide. In that case, try to remove the =-q= in the previous
command line to load your personal emacs configuration.
Finally, when you'll be tired of always re-executing all the source
code when exporting, just look for the following line in [[https://gitlab.inria.fr/learninglab/mooc-rr/mooc-rr-ressources/blob/master/module2/ressources/replicable_article/article.org][article.org]]:
#+BEGIN_EXAMPLE
#+BEGIN_EXAMPLE
#+END_EXAMPLE
#+END_EXAMPLE
If you remove the =# = in the beginning of the line, it will not be a
If you remove the =# = in the beginning of the line, it will not be a comment anymore and will indicate org-mode to stop evaluating every chunk of code when exporting.
