Learning Lab
f932bff5
Commit
f932bff5
by
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
parent
05dc6b5a
Changes
7
Hide whitespace changes
Inline
Side-by-side
Showing
7 changed files
with
94 additions
and
5 deletions
+94
-5
gitlab.org
module2/ressources/gitlab.org
+94
-5
module2/ressources/gitlab_images/adresse_depot.png
+0
-0
module2/ressources/gitlab_images/commit_git.png
+0
-0
module2/ressources/gitlab_images/rejected.png
+0
-0
module2/ressources/gitlab_images/status1.png
+0
-0
module2/ressources/gitlab_images/status2.png
+0
-0
module2/ressources/gitlab_images/status3.png
+0
-0
No files found.
View file @
f932bff5
@@ -12,11 +12,7 @@ ignored in a first step* *as we have closely integrated Jupyter and
GitLab in the context of this MOOC.*
So far, you only used git via the web interface from the GitLab we
deployed for the MOOC.
#+BEGIN_CENTER
https://app-learninglab.inria.fr/gitlab/
#+END_CENTER
deployed for the MOOC: https://app-learninglab.inria.fr/gitlab/
If you access this link from the FUN platform, you do not have to
authenticate and you can readily read and modify all your files. This
@@ -165,4 +161,97 @@ video:
#+BEGIN_EXPORT html
<iframe width="560" height="315" src="https://www.youtube.com/embed/54mxyLo3Mqk" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
#+END_EXPORT
* Using Git through the command line to synchronize your local files with Gitlab
This section describes a generic (through the command line) way to
synchronize your local files with Gitlab. You will not need this if
you follow the Jupyter course. If you follow the Rstudio course, all
these operations can be done through Rstudio and you may want to read
[[file:rstudio.org][the corresponding instructions]]. If you follow the Org-Mode course, all
these operations can be done through Magit and you may want to read
[[file:emacs_orgmode.org][the corresponding instructions]].
Here are other ways to learn Git through the command line:
- The [[http://swcarpentry.github.io/git-novice/][Software Carpentry git tutorial]]
- The (freely available) Pro Git book ([[https://git-scm.com/book/en/v2][in English]] or [[https://git-scm.com/book/fr/v2][in
French]]). Reading the first two chapters is enough to get a good start.
- [[https://learngitbranching.js.org/][Learn Git Branching]] will allow to interactively learn Git and to
understand with branches.
Now, let's start!
1. Obtain the repository URL
[[file:gitlab_images/adresse_depot.png]]
2. Cloning the repository
#+begin_src shell :results output :exports both
cd /the/directory/where/you/want/to/clone/your/repository
git clone https://app-learninglab.inria.fr/gitlab/xxx/mooc-rr.git
#+end_src
Alternatively, you may want to indicate now your login although I
rather suggest you follow the /Remembering your password locally/
instructions:
git clone https://xxx@app-learninglab.inria.fr/gitlab/xxx/mooc-rr.git
#+end_src
Now a directory =mooc-rr= has been created on your computer.
3. Inspect the repository
cd mooc-rr
ls # (Unix)
dir # (Windows)
#+end_src
4. Synchronizing to GitLab
You should indicate which files to track (=git add=) and commit them
locally (=git commit=) before they can be transfered (=git push=) to
GitLab. The =git status= will indicate you whether files are
tracked/modified/committed/...
Let's assume you just created a `fichier.txt` file on the top of
the =mooc-rr= directory.
git status
#+end_src
[[file:gitlab_images/status1.png]]
git add fichier.txt
git status
#+end_src
[[file:gitlab_images/status2.png]]
git commit -m "message commit"
#+end_src
[[file:gitlab_images/commit_git.png]]
git status
#+end_src
[[file:gitlab_images/status3.png]]
The file can then be transfered to GitLab:
git push
#+end_src
At this point, git will as you about your login/password unless
you followed the previous /Remembering your password locally/ instructions.
N.B.: you will not be allowed to propagate your modifications to
GitLab if other modifications (e.g., from someone else) have been
propagated in between
[[file:gitlab_images/rejected.png]]
5. Synchronizing from Gitlab: to avoid the previous problem, you need
to fetch the remote GitLab modifications first and apply them
locally.
git pull
#+end_src
Only then will you be able to =git push=.
0 → 100644
View file @
f932bff5
51.9 KB
0 → 100644
View file @
f932bff5
8.02 KB
0 → 100644
View file @
f932bff5
10.7 KB
0 → 100644
View file @
f932bff5
12.9 KB
0 → 100644
View file @
f932bff5
17.5 KB
0 → 100644
View file @
f932bff5
13.9 KB
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
You are about to add
people
to the discussion. Proceed with caution.
Finish editing this message first!
Please
register
or
sign in
to comment
