Learning Lab
fa518547
Commit
fa518547
by
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
Improve the text on pip + information on R installed packages
parent
9df89c7e
Changes
1
Hide whitespace changes
Inline
Side-by-side
Showing
1 changed file
with
36 additions
and
10 deletions
+36
-10
resources.org
module4/ressources/resources.org
+36
-10
No files found.
View file @
fa518547
@@ -83,7 +83,11 @@ hash) will not be stored in the cell. This is not really a problem and
is
the
price
to
pay
for
running
git
from
within
the
notebook
itself
Getting
information
about
Python
3
libraries
Getting
the
list
of
installed
packages
and
their
version
https
stackoverflow
com
questions
20180543
how
to
check
version
of
python
modules
This
topic
is
discussed
on
https
stackoverflow
com
questions
20180543
how
to
check
version
of
python
modules
StackOverflow
When
using
pip
the
Python
package
installer
within
a
shell
command
it
is
easy
to
query
the
version
of
all
installed
packages
note
that
on
your
system
you
may
have
to
use
either
pip
or
pip3
depending
on
how
it
is
named
and
which
versions
of
Python
are
available
on
your
machine
begin_src
shell
results
output
exports
both
pip3
freeze
end_src
@@ -109,6 +113,10 @@ wcwidth==0.1.7
webencodings
0.5
end_example
Once
you
know
which
packages
are
installed
you
can
easily
get
additional
information
about
a
given
package
and
in
particular
check
whether
it
was
installed
"locally"
through
pip
or
whether
it
is
installed
system
wide
Again
in
a
shell
command
begin_src
shell
results
output
exports
both
pip3
show
pandas
echo
@@ -138,14 +146,12 @@ Location: /home/alegrand/.local/lib/python3.6/site-packages
Requires
patsy
pandas
end_example
begin_src
python
results
output
exports
both
end_src
How
to
list
imported
modules
Inspiring
from
https
stackoverflow
com
questions
4858100
how
to
list
imported
modules
StackOverflow
here
is
a
simple
function
that
lists
loaded
package
that
have
a
__version__
attribute
which
is
unfortunately
not
completely
standard
Without
resorting
to
pip
that
will
list
all
available
packages
you
may
want
to
know
which
modules
are
loaded
in
a
Python
session
as
well
as
their
version
Inspiring
from
https
stackoverflow
com
questions
4858100
how
to
list
imported
modules
StackOverflow
here
is
a
simple
function
that
lists
loaded
package
that
have
a
__version__
attribute
which
is
unfortunately
not
completely
standard
begin_src
python
results
output
exports
both
def
print_imported_modules
@@ -204,9 +210,9 @@ pip3 freeze > requirements.txt # to obtain the list of packages with their versi
pip3
install
r
requirements
txt
to
install
the
previous
list
of
packages
possibly
on
an
other
machine
end_src
If
you
want
to
have
several
installed
p
ython
environments
you
may
If
you
want
to
have
several
installed
P
ython
environments
you
may
want
to
use
https
docs
pipenv
org
Pipenv
I
doubt
it
allows
to
track
correctly
FORTRAN
or
C
dynamic
libraries
that
are
wrapped
by
Python
dynamic
libraries
that
are
wrapped
by
Python
though
Getting
information
about
R
libraries
The
best
way
seems
to
be
to
rely
on
the
devtools
package
@@ -267,3 +273,23 @@ Packages ----------------------------------------------------------------------
Some
actually
advocate
that
https
github
com
ropensci
rrrpkg
writing
a
reproducible
research
compendium
can
be
done
by
writing
an
R
package
Those
of
you
willing
to
have
a
clean
R
dependency
management
should
thus
have
a
look
at
https
rstudio
github
io
packrat
Packrat
Finally
it
is
good
to
know
that
there
is
a
built
in
R
command
installed
packages
allowing
to
retrieve
and
list
the
details
of
all
packages
installed
begin_src
R
results
table
session
R
exports
both
colnames
yes
head
installed
packages
end_src
RESULTS
Package
LibPath
Version
Priority
Depends
Imports
LinkingTo
Suggests
Enhances
License
License_is_FOSS
License_restricts_use
OS_type
MD5sum
NeedsCompilation
Built
BH
home
alegrand
R
x86_64
pc
linux
gnu
library
3.5
1.66.0
1
nil
nil
nil
nil
nil
nil
BSL
1.0
nil
nil
nil
nil
no
3.5.1
Formula
home
alegrand
R
x86_64
pc
linux
gnu
library
3.5
1.2
3
nil
R
2.0.0
stats
nil
nil
nil
nil
GPL
2
GPL
3
nil
nil
nil
nil
no
3.5.1
Hmisc
home
alegrand
R
x86_64
pc
linux
gnu
library
3.5
4.1
1
nil
lattice
survival
2.40
1
Formula
ggplot2
2.2
methods
latticeExtra
cluster
rpart
nnet
acepack
foreign
gtable
grid
gridExtra
data
table
htmlTable
1.11.0
viridis
htmltools
base64enc
nil
chron
rms
mice
tables
knitr
ff
ffbase
plotly
4.5.6
nil
GPL
2
nil
nil
nil
nil
yes
3.5.1
Matrix
home
alegrand
R
x86_64
pc
linux
gnu
library
3.5
1.2
14
recommended
R
3.2.0
methods
graphics
grid
stats
utils
lattice
nil
expm
MASS
MatrixModels
graph
SparseM
sfsmisc
GPL
2
file
LICENCE
nil
nil
nil
nil
yes
3.5.1
StanHeaders
home
alegrand
R
x86_64
pc
linux
gnu
library
3.5
2.17.2
nil
nil
nil
nil
RcppEigen
BH
nil
BSD_3_clause
file
LICENSE
nil
nil
nil
nil
yes
3.5.1
acepack
home
alegrand
R
x86_64
pc
linux
gnu
library
3.5
1.4.1
nil
nil
nil
nil
testthat
nil
MIT
file
LICENSE
nil
nil
nil
nil
yes
3.5.1
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
You are about to add
people
to the discussion. Proceed with caution.
Finish editing this message first!
Please
register
or
sign in
to comment
