Commit 5e298cd5 authored by Arnaud Legrand's avatar Arnaud Legrand
Typo--
parent 27fc3431
...@@ -577,7 +577,7 @@ ...@@ -577,7 +577,7 @@
"metadata": {}, "metadata": {},
"source": [ "source": [
"The maximum likelyhood estimator of the intercept and of Temperature are thus $\\hat{\\alpha}=5.0849$ and $\\hat{\\beta}=-0.1156$. This **corresponds** to the values from the article of Dalal et al. The standard errors are $s_{\\hat{\\alpha}} = 7.477$ and $s_{\\hat{\\beta}} = 0.115$, which is **different** from the $3.052$ and $0.04702$ reported by Dallal et al. The deviance is $3.01444$ with 21 degrees of freedom. I cannot find any value similar to the Goodness of fit ($G^2=18.086$) reported by Dalal et al.\n", "The maximum likelyhood estimator of the intercept and of Temperature are thus $\\hat{\\alpha}=5.0849$ and $\\hat{\\beta}=-0.1156$. This **corresponds** to the values from the article of Dalal et al. The standard errors are $s_{\\hat{\\alpha}} = 7.477$ and $s_{\\hat{\\beta}} = 0.115$, which is **different** from the $3.052$ and $0.04702$ reported by Dallal et al. The deviance is $3.01444$ with 21 degrees of freedom. I cannot find any value similar to the Goodness of fit ($G^2=18.086$) reported by Dalal et al.\n",
"**I have therefore managed to partially replicate the results of the Dalal et. al. article**." "**I have therefore managed to partially replicate the results of the Dalal et al. article**."
...@@ -47,7 +47,7 @@ logistic_reg = glm(data=data, Malfunction/Count ~ Temperature, weights=Count, ...@@ -47,7 +47,7 @@ logistic_reg = glm(data=data, Malfunction/Count ~ Temperature, weights=Count,
summary(logistic_reg) summary(logistic_reg)
The maximum likelyhood estimator of the intercept and of Temperature are thus $\hat{\alpha}=5.0849$ and $\hat{\beta}=-0.1156$ and their standard errors are $s_{\hat{\alpha}} = 3.052$ and $s_{\hat{\beta}} = 0.04702$. The Residual deviance corresponds to the Goodness of fit $G^2=18.086$ with 21 degrees of freedom. **I have therefore managed to replicate the results of the Dalal et. al. article**. The maximum likelyhood estimator of the intercept and of Temperature are thus $\hat{\alpha}=5.0849$ and $\hat{\beta}=-0.1156$ and their standard errors are $s_{\hat{\alpha}} = 3.052$ and $s_{\hat{\beta}} = 0.04702$. The Residual deviance corresponds to the Goodness of fit $G^2=18.086$ with 21 degrees of freedom. **I have therefore managed to replicate the results of the Dalal et al. article**.
# Predicting failure probability # Predicting failure probability
The temperature when launching the shuttle was 31°F. Let's try to The temperature when launching the shuttle was 31°F. Let's try to
Markdown is supported
0% or
You are about to add 0 people to the discussion. Proceed with caution.
Finish editing this message first!
Please register or to comment
