"The maximum likelyhood estimator of the intercept and of Temperature are thus $\\hat{\\alpha}=5.0849$ and $\\hat{\\beta}=-0.1156$. This **corresponds** to the values from the article of Dalal et al. The standard errors are $s_{\\hat{\\alpha}} = 7.477$ and $s_{\\hat{\\beta}} = 0.115$, which is **different** from the $3.052$ and $0.04702$ reported by Dallal et al. The deviance is $3.01444$ with 21 degrees of freedom. I cannot find any value similar to the Goodness of fit ($G^2=18.086$) reported by Dalal et al.\n",
"**I have therefore managed to partially replicate the results of the Dalal et. al. article**."
"**I have therefore managed to partially replicate the results of the Dalal et al. article**."
The maximum likelyhood estimator of the intercept and of Temperature are thus $\hat{\alpha}=5.0849$ and $\hat{\beta}=-0.1156$ and their standard errors are $s_{\hat{\alpha}} = 3.052$ and $s_{\hat{\beta}} = 0.04702$. The Residual deviance corresponds to the Goodness of fit $G^2=18.086$ with 21 degrees of freedom. **I have therefore managed to replicate the results of the Dalal et. al. article**.
The maximum likelyhood estimator of the intercept and of Temperature are thus $\hat{\alpha}=5.0849$ and $\hat{\beta}=-0.1156$ and their standard errors are $s_{\hat{\alpha}} = 3.052$ and $s_{\hat{\beta}} = 0.04702$. The Residual deviance corresponds to the Goodness of fit $G^2=18.086$ with 21 degrees of freedom. **I have therefore managed to replicate the results of the Dalal et al. article**.
# Predicting failure probability
The temperature when launching the shuttle was 31°F. Let's try to
