The following [[https://www.dataquest.io/blog/jupyter-notebook-tips-tricks-shortcuts/][webpage]] lists several Jupyter tricks (in particular, it
illustrates many =Ipython magic= commands) that should improve your
efficiency (note that this blog post is about two years old so some of
the tricks may have been integrated in the default behavior of jupyter
the tricks may have been integrated in the default behavior of Jupyter
now).
now).
** Running R and Python in the same notebook
The best solution to this is to install rpy2. On my machine, I have
@@ -58,13 +58,16 @@ nbconvert exporter, an other option consists in exporting to Markdown
and playing with [[https://pandoc.org/][pandoc]]. Both approaches work, it's rather a matter of
taste.
taste.
* Installing Jupyter on your own machine
** Installing jupyter
** Installing Jupyter
Follow these instructions if you wish to have a similar Jupyter environment on you own machine.
Follow these instructions if you wish to have a Jupyter environment on
your own machine similar to the one we set up for this MOOC.
First, download and install [[https://conda.io/miniconda.html][Miniconda latest version]]. We use Miniconda version =4.5.4= and Python version =3.6= on our server .\\
First, download and install the [[https://conda.io/miniconda.html][latest version of Miniconda]]. We use
Miniconda is a light version of Anaconda which includes Python, the Jupyter Notebook, and other commonly used packages for scientific computing and data science.
Miniconda version =4.5.4= and Python version =3.6= on our server.
Then download the [[https://gist.github.com/brospars/4671d9013f0d99e1c961482dab533c57][mooc_rr environment file]] and create it using conda:
Miniconda is a light version of Anaconda, which includes Python, the Jupyter Notebook, and other commonly used packages for scientific computing and data science.
Then download the [[https://gist.github.com/brospars/4671d9013f0d99e1c961482dab533c57][mooc_rr environment file]] and create the environment using conda:
#+begin_src shell :results output :exports both
conda env create -f environment.yml
@@ -76,26 +79,56 @@ source activate mooc_rr
jupyter notebook
jupyter notebook
#+end_src
#+end_src
** Side note about Jupyter, JupyterLab, JupyterHub, ...
Note that Jupyter notebooks are only a small part of the picture and
that Jupyter is now part of a bigger project: [[https://blog.jupyter.org/jupyterlab-is-ready-for-users-5a6f039b8906][JupyterLab]], which allows
you to mix various components (including notebooks) in your
browser. In the context of this MOOC, our time frame was too short to
benefit from JupyterLab which was still under active development but
this is probably the best option now if you want to benefit from
cutting-edge Jupyter notebooks.
** Exporting your notebooks with latex
Here is what I had to install on my recent debian machine to make sure
Here is what we had to install on our recent debian machine to make sure
the notebook export via latex works:
sudo apt-get install wkhtmltopdf
sudo apt-get install texlive-xetex wkhtmltopdf
#+end_src
#+end_src
** Interesting extensions to improve notebook readability
** Jupyter extensions/plugins
Here are two interesting extensions that can improve readability:
