Commit 7e717383 authored by Arnaud Legrand's avatar Arnaud Legrand
Fix a few typos and provide information on jupyter-git plugins.
parent ed7ab9da
......@@ -11,7 +11,7 @@
The following [[https://www.dataquest.io/blog/jupyter-notebook-tips-tricks-shortcuts/][webpage]] lists several Jupyter tricks (in particular, it
illustrates many =Ipython magic= commands) that should improve your
efficiency (note that this blog post is about two years old so some of
the tricks may have been integrated in the default behavior of jupyter
the tricks may have been integrated in the default behavior of Jupyter
now).
** Running R and Python in the same notebook
The best solution to this is to install rpy2. On my machine, I have
......@@ -58,13 +58,16 @@ nbconvert exporter, an other option consists in exporting to Markdown
and playing with [[https://pandoc.org/][pandoc]]. Both approaches work, it's rather a matter of
taste.
* Installing Jupyter on your own machine
** Installing jupyter
Follow these instructions if you wish to have a similar Jupyter environment on you own machine.
** Installing Jupyter
Follow these instructions if you wish to have a Jupyter environment on
your own machine similar to the one we set up for this MOOC.
First, download and install [[https://conda.io/miniconda.html][Miniconda latest version]]. We use Miniconda version =4.5.4= and Python version =3.6= on our server .\\
Miniconda is a light version of Anaconda which includes Python, the Jupyter Notebook, and other commonly used packages for scientific computing and data science.
First, download and install the [[https://conda.io/miniconda.html][latest version of Miniconda]]. We use
Miniconda version =4.5.4= and Python version =3.6= on our server.
Then download the [[https://gist.github.com/brospars/4671d9013f0d99e1c961482dab533c57][mooc_rr environment file]] and create it using conda:
Miniconda is a light version of Anaconda, which includes Python, the Jupyter Notebook, and other commonly used packages for scientific computing and data science.
Then download the [[https://gist.github.com/brospars/4671d9013f0d99e1c961482dab533c57][mooc_rr environment file]] and create the environment using conda:
conda env create -f environment.yml
......@@ -76,26 +79,56 @@ source activate mooc_rr
jupyter notebook
** Side note about Jupyter, JupyterLab, JupyterHub, ...
Note that Jupyter notebooks are only a small part of the picture and
that Jupyter is now part of a bigger project: [[https://blog.jupyter.org/jupyterlab-is-ready-for-users-5a6f039b8906][JupyterLab]], which allows
you to mix various components (including notebooks) in your
browser. In the context of this MOOC, our time frame was too short to
benefit from JupyterLab which was still under active development but
this is probably the best option now if you want to benefit from
cutting-edge Jupyter notebooks.
** Exporting your notebooks with latex
Here is what I had to install on my recent debian machine to make sure
Here is what we had to install on our recent debian machine to make sure
the notebook export via latex works:
sudo apt-get install wkhtmltopdf
sudo apt-get install texlive-xetex
sudo apt-get install texlive-xetex wkhtmltopdf
** Interesting extensions to improve notebook readability
Here are two interesting extensions that can improve readability:
- [[https://stackoverflow.com/questions/33159518/collapse-cell-in-jupyter-notebook][Code folding]]
** Jupyter extensions/plugins
*** Improving notebook readability
Here are a few extensions that can ease your life:
- [[https://stackoverflow.com/questions/33159518/collapse-cell-in-jupyter-notebook][Code folding]] to improve readability when browsing the notebook.
pip3 install jupyter_contrib_nbextensions
# jupyter contrib nbextension install --user # not done yet
- [[https://github.com/kirbs-/hide_code][Hiding code]]
- [[https://github.com/kirbs-/hide_code][Hiding code]] to improve readability when exporting.
#+begin_src sh :results output :exports both
sudo pip3 install hide_code
sudo jupyter-nbextension install --py hide_code
jupyter-nbextension enable --py hide_code
jupyter-serverextension enable --py hide_code
*** Interacting with GitLab and GitHub
To ease your experience, we added some pull/push buttons that allow
you to commit and sync with GitLab. This development was specific to
the MOOC but inspired from a previous [[https://github.com/Lab41/sunny-side-up][proof of concept]]. We have
recently discovered that someone else developed about at the same time
a [[https://github.com/sat28/githubcommit][rather generic version of this Jupyter plugin]]. Otherwise, remember
that it is very easy to insert a shell cell in Jupyter in which you
can easily issue git commands. This is how we work most of the time.
This being said, you may have noticed that Jupyter keeps a perfect
track of the sequence in which cells have been run by updating the
"output index". This is a very good property from the reproducibility
point of view but depending on your usage, you may find it a bit
painful when commiting. Some people have thus developped [[https://gist.github.com/pbugnion/ea2797393033b54674af][specific git
hooks]] to ignore these numbers when comitting Jupyter notebooks. There
is a long an interesting discussion about various options on
[[https://stackoverflow.com/questions/18734739/using-ipython-notebooks-under-version-control][StackOverflow]].
Last but not least, remembter that Jupyter notebooks are only a small
part of the picture and that Jupyter is now part of a bigger project:
[[https://blog.jupyter.org/jupyterlab-is-ready-for-users-5a6f039b8906][JupyterLab]], which allows you to mix various components (including
notebooks) in your browser. A specific [[https://github.com/jupyterlab/jupyterlab-git][JupyterLab git plugin]] has been
developed to offer a nice version control experience.
